Old 03-11-2001, 06:52 PM   #1
TimCat
Member#: 2451
2000 2.5 RS Coupes
BRP and a STM
Post Why is my car dying on startup?
Sometimes when I startup my car it will idle so low it dies. And then other times it will go to 1500 RPM and stay there. What the hell is going on? It is driving me nuts. Should I do a ECU reset?
TimCat is offline   Reply With Quote
Old 03-11-2001, 07:13 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Electronic choke freaking out? ECU reset might fix it I suppose. I dunno.
CosmoTheCat is offline   Reply With Quote
Old 03-11-2001, 08:08 PM   #3
98mpreziveRS
Member#: 972
Post
check all your vacuum lines, esp. the one leading to the bottom of the airbox..
98mpreziveRS is offline   Reply With Quote
Old 03-12-2001, 02:30 AM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Post
That was my first thought, but when I read his post it sounds like it's an intermittant problem.
Does it only happen when it's cold? Give us a little more to go on man!
Old 03-12-2001, 04:46 AM   #5
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Post
Gary - what do you know about Scoobies...you've got a BMW...ahahha
-myk
mykrrrr is offline   Reply With Quote
Old 03-12-2001, 04:50 AM   #6
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Post
This happened to my 00 BRP coupe, too. Only for the first month or so... doesnt do it anymore. I think the factory set engine parameters needed some actual driving time to be reprogrammed (you know, like an ecu reset, only much slower). You might want to try and reset the ECU.
----Roy
LUME is offline   Reply With Quote
Old 03-12-2001, 05:00 AM   #7
D-Rock
Member#: 3651
2001 2.5 RS Coupe
Post
This happens to my 2001 every few weeks or so. Only does it on a cold start. It's ussualy in the 30s to 40s out when it happens I think. Once I start the car up again it's fine.
D-Rock is offline   Reply With Quote
Old 03-12-2001, 07:41 AM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
even tho it's an 01....
it could be the crap stock battery they give you... in the cold, it's not so powerful
just a thought...
j.
Old 03-12-2001, 09:02 AM   #9
TimCat
Member#: 2451
2000 2.5 RS Coupes
BRP and a STM
Post
Well...it happens when it is cold outside. And when it is nice outside. When it has been running for a while and when it hasnt ben running all day. Its crazy. I did a ECU reset back when I got a Ganzflow CAI not to long ago. I just put on a new muffler too. Gonna do a ECU reset and check that vacuum hose that BMW boy is talking about.
Old 03-12-2001, 01:02 PM   #10
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Post
mine only does it if... 1 it's pretty cold out, say sub 20 degrees, and if I leave some accessories on. I think it doesn't have enough juice in the batt to keep it all going right after a cold start. Just my 02.
Aaron
m750 is offline   Reply With Quote
Old 03-12-2001, 01:44 PM   #11
Skirvdawg
Member#: 3375
2002 VW Jetta Wagon
Post
My car does this, too. It will start up, spin at about 1500rpm for a second or so, then die. Then I'll start it up again and it'll be fine. I haven't noticed any other problems with it. When I take it in for the first oil change I'll ask the dealer about it and see if they tell me something besides "It's that intake you have on there."
Skirvdawg is offline   Reply With Quote
Old 03-12-2001, 02:08 PM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
guys...
my GT did that after a bit...
i swapped out the crap battery to a die hard gold... and all was well...
not sure tho as something like that could be several things...
j. www.subiegal.com
Old 03-12-2001, 02:51 PM   #13
TimCat
Member#: 2451
2000 2.5 RS Coupes
BRP and a STM
Post
Ya. I do believe I will go get some platinum Bosch sparkplugs and a new battery soon. This is driving me nuts. And is very embarassing. I dont like to have to rev my motor up on stratup to keep it going. That and my exhaust is loud as hell. I am sure the other people in my apartment complex hate me. I work and clean my car all hours of the day/night. And then I come in with stereo bumping and muffler rumbling all the time. Its a wonder I havent been evicted yet. Hehe. Thx for the input. I will do what I can and hope it fixes it. I am taking in my baby to have 2 dents pulled on Thursday at the dealer. Will have them look at it too. Hopefully they wont give me the "its your intake" BS too. Hehe I will let you all know.
Old 03-12-2001, 03:00 PM   #14
ScoobyNRG
Member#: 2839
2000 Impreza 2.5 RS
Silverthorn Metallic
Post
TimCat - When it speeds up to 1500, that is the cold idle setting, that is normal. If you let it warm up without touching the gas pedal, it will drop back down to its normal idle speed. The stalling sounds like a ECU reset might be in order. When I first removed the silencer from my car I only removed the positive lead from the battery to reset it, and it ran kind of funky after that (i.e. stalled and sputtered every now and then) I did a full reset by unhooking both positive and negative leads for 1 hour and since then it runs like a champ and seems to have a little more power and gets a little better gas mileage.
Tim
ScoobyNRG is offline   Reply With Quote
Old 03-12-2001, 04:00 PM   #15
D-Rock
Member#: 3651
2001 2.5 RS Coupe
Post
I was thinking it had somthing to do with the fuel pump or fuel related. If it was a fuel problem I wouldn't have a clue how to fix it anyways. Hopefully it's just the battery though. Would I need a bigger battery if I wanted to add a few more fogs?
Thanks,
D
Old 03-12-2001, 10:03 PM   #16
TimCat
Member#: 2451
2000 2.5 RS Coupes
BRP and a STM
Post
Well I reset the ECU and my car runs alot better! But I need time to see if the startup problem persists or not. I guess we will see.
Old 03-13-2001, 12:57 AM   #17
TimmyD
Member#: 1309
Post
Mine did it this morning for the first time after a year of ownership.
TimmyD is offline   Reply With Quote
Is my 4EAT dying on me? mc2 Transmission (AT/MT) & Driveline 4 04-10-2009 12:20 PM
So my car died on me..... 04STiLover Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 05-23-2007 04:38 PM
My cars dieing on me.... repair or swap? Aaron'z 2.5RS Mid West Subaru Owners Club Forum -- MWSOC 12 04-23-2007 10:54 AM
Why is my car nearly as fast as 350+ hp muscle cars? HAL1 General Community 53 05-04-2006 10:48 PM
Damn my Car died on me! HoOn South East Region Forum 21 05-07-2004 01:49 PM
