Old 04-25-2003, 09:28 AM   #1
Edvig
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Default bushing question: v4 STi vs v7 STi vs Stock WRX
I have a question for all the suspension gurus out there.
I have the opportunity to pick up a set of rear suspension trailing links and rear suspension rear lateral links with bushings from a low mileage v4 STi.
I believe these parts will fit my 02 WRX Wagon. How do these bushings compare to the newer STi bushings? How would they compare to my stock ones?
I've already upgraded the rear suspension front lateral link bushings with the ones that came with my SPT kit.
Thanks in advance, Edvig
Edvig is offline   Reply With Quote
Old 04-26-2003, 06:41 AM   #2
Edvig
Member#: 16147
no more turbo
Bump
You guru guys have always had answers to my questions.
Edvig
Old 04-26-2003, 10:23 AM   #3
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
I'm not sure that anyone knows, Edvig. For instance, the STi gets the same strut tops as the WRX. The "STi" strut tops that everyone refers to when discussing suspension top mounts are in fact the aftermarket, hardened Group N mounts.
I'm just not sure about the rest of the bushings on an STi, if they get a firmer bushing or not.
Kevin
gtguy is offline   Reply With Quote
Old 04-27-2003, 12:01 AM   #4
Edvig
Member#: 16147
no more turbo
Thanks...Kevin.
I may post this question on scoobynet. Those guys have more experience with the older STIs than we do. The idea of swapping GC STi parts came to me out of laziness and the desire not to ever have to squeeze bushings out ever again.
My other option is to go pink!
Edvig
version 8 STi cams vs V7 STi RA spec C cams singsing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-16-2011 12:35 PM
Stock STI Bypass Valve or a stock WRX Bypass Valve ASAP! Aleksey Private 'Wanted' Classifieds 1 11-04-2005 01:46 PM
Question: Would the Sti wing "holes" fit the stock WRX holes? chopaholix Texas Impreza Club Forum -- TXIC 4 03-04-2004 09:55 AM
Trade: white trunk with v7 wing for stock wrx trunk. dcgear Vancouver Impreza Club Forum -- VIC 4 12-29-2003 12:10 AM
