Old 04-25-2003, 09:38 AM   #1
Romuir
Member#: 23994
2008 LegAcy Spec. B
Something Grey
Default Wiring Request: How do you wire up the Prodrive/ Hella FF1000?
Replaced the fogs with Driving lamps. I would like to have the new lamps come on with High Beam only using the High Beam stalk on the steering column.
Can't make heads or tails on their suggested rewire for this setup. The instructions talk about "35 wire connector" which for the life of me I can't find. Currently the driving lamps come on when the button is pushed and the low beams are on.
Thanks
Romuir is offline   Reply With Quote
Old 04-26-2003, 12:38 PM   #2
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
Did you use the stock relay and wiring?
Chris
Subie2 is offline   Reply With Quote
Old 04-26-2003, 12:56 PM   #3
wrxinfx
Member#: 10515
2002 WRX Sedan
check the www.rallylights.com - he's got some simple schematics. Scoobymods.com will have info as well.
I believe the FF1000's are 55w? If they are, you can use the stock wiring. To have them come on with the brights - there are some mods listed on scoobymods that can help ya there.
Casey
wrxinfx is offline   Reply With Quote
Old 04-27-2003, 02:08 AM   #4
tdxflex
Member#: 13634
i have my hella 500s wired the way you describe, but i'm using the relay that hella provided. all of the wiring is right at the battery because the drivers side headlight is where all the wires are being tapped and the battery + and ground. literally the wiring for the relay was under 10" long (except for the wire going to the pass light location). to me it was simpler to just do new wiring than to go under the dash and reroute wires there.
85- blue wire from headlight harness (common power)
86- red wire from headlight harness (switched ground for high beam)
diode across the 85 and 86 coil
30- battery and fuse
87- driving lamp
the only time there will be current flow from the 85 to 86 terminals is when the high beams are on. if you want me to break down all of the conditions let me know and i'll draw up a chart. the diode is there to supress current when the coil is energized/de-energized.
if you want to use the stock wiring, i think the relay is controlled by the high beam wire's ground. when that wire goes ground, then the lights turn off. so if you switch it with the low beam wire for control it should work but i really haven't put much thought into it.
tdxflex is offline   Reply With Quote
Old 04-28-2003, 12:06 AM   #5
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
I just got new 500's for my WRX 'cause I had to replace the front bumper after an accident. Can you tell me how you mounted them in the bumper? Also, I want to have my 500's come on with the high beams, but be able to defeat them using a switch. Would that modify your wiring much?
TIA
Steve
87- driving lamp
fragment is offline   Reply With Quote
Old 04-28-2003, 01:46 AM   #6
tdxflex
Member#: 13634
TIA
Steve
instructions come with the hella lights to do this, or actually i think they just have instructions on how to just use it with a switch (without the high beam control). you'll need an additional relay to control the switch, or in this case it might be worth it to do the fog light mod with the stock wiring. i don't know why you would want it controlled by a switch though.
if you want just general info of how to add aux lights, these are good links,
http://www.classictruckshop.com/club...h/foglites.htm
http://www.classictruckshop.com/club...osch/relay.htm
Old 04-28-2003, 10:42 AM   #7
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Thanks tdxflex. Actually, I was more interested in how you physically bolted the light to the bumper. Did you drill a hole through the bottom of the bumper cover and bolt it to the bumper beam? I really don't want to hack up the new bumper cover I just paid for and painted.
Old 04-28-2003, 11:07 AM   #8
tdxflex
Member#: 13634
i used the kartboy mounts in the stock location. i'm going to make a fiberglass light bar this week since it warmed up but not sure when that will be finished. i'm going to make it 3 parts, the two brackets to the car, and the the bar will actually be removable so i can install/remove it in a snap and i won't have to drive around during the day with all of those lights, just keep it in the trunk until i need it.
couples; how do you split up the housework? jacobsen1 Off-Topic 152 06-08-2009 07:37 AM
newb boost question....how do you turn up the boost Meat Supply Newbies & FAQs 9 03-16-2009 07:25 PM
how do you hook up the hpbc w/a UTEC frdawg Engine Management & Tuning 1 04-17-2003 01:00 PM
AutoX - how do you heat up the brakes? bemani Motorsports 13 04-13-2003 01:31 AM
How do you take up the slack in throttle cable? 96Lconversion Normally Aspirated Powertrain 2 02-22-2001 08:48 PM
