Old 04-25-2003, 09:58 AM   #1
willguidry
Member#: 16388
Default Pulling a CEL?
Ok, as I don't want the Autozone monkey messing around with my car, how and where do I find the ODB-II hookup in the impreza RS? I checked the net, but couldn't find anything.
Cheers
Will
willguidry is offline   Reply With Quote
Old 04-25-2003, 11:46 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
There should be a little access door on the left side of the steering wheel, or it should be directly under the dash.
Gotta remember OBD2 was introduced for emissions purposes & testing.....so the placement of the connector must be in a place that testing facilities can easily access it.
Legacy777 is offline   Reply With Quote
Old 04-25-2003, 11:57 AM   #3
willguidry
Member#: 16388
Anyone know exactly where it is?
Cheers
Old 04-25-2003, 01:10 PM   #4
BlueTDimly
Member#: 24475
1999 Forester L
Dirty
Do you have an OBD scanner? Look at the connector (it will be long and fairly thick). Play hide and seek under the dash on the driver's side. It shouldn't take you long to find. On my Forester it is near the hood release lever and below the coin tray (left side of steering wheel, as Josh said).
BlueTDimly is offline   Reply With Quote
Old 04-25-2003, 01:58 PM   #5
Teamugi
Member#: 7771
under your steering wheel, to the left slightly. it is recessed inside the dash. just run your hands down there and you can feel the hole and the connectors.
Teamugi is offline   Reply With Quote
Old 04-25-2003, 02:02 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If CT is your real location ( ) try posting in Tri-State. There are quite a few of us there with scanners and chances are someone near you has one and can pull the code for you.
Can anyone pull a CEL code for me tomorrow(Friday) six6sicks North West Impreza Club Forum -- NWIC 5 06-27-2003 02:58 PM
Can anyone pull a CEL in the SFV? Double-R-WRX Southern California Impreza Club Forum -- SCIC 7 05-13-2003 11:30 AM
Who can pull a CEL? Evegan Normally Aspirated Powertrain 6 01-10-2003 09:22 AM
Is there anyone who can pull my CEL code? legacyej22 North West Impreza Club Forum -- NWIC 2 12-25-2002 02:45 PM
OT: $120 to pull Honda CEL? topcover Bay Area Impreza Club Forum -- BAIC 4 07-12-2002 07:59 PM
