Old 04-25-2003, 05:36 PM   #1
SPeeDSiN
Member#: 4667
Black (well kinda)
Default What is stock fuel pressure?
I did a search but couldn't find any real numbers.
Thanks
SPeeDSiN is offline   Reply With Quote
Old 04-25-2003, 05:39 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
It's a rising rate fuel regulator. It 40ish psi + map pressure.
mbiker97 is offline   Reply With Quote
Old 04-25-2003, 06:44 PM   #3
hotrod
Member#: 14141
2002 Impreza WRX
Default Base fuel pressure
The fuel pressure regulator on the WRX is designed to hold 43.0 psi base fuel pressure with as posted above a 1:1 manifold referenced pressure rise on boost.
If you have metric gauges, 294 kPa or 3.00 kgf/cm^2
Larry
hotrod is offline   Reply With Quote
Old 04-26-2003, 04:52 AM   #4
john banks
Member#: 11669
Evo IX 345 WHP
At idle they often run higher than specced but closed loop correction/learning helps this. At least on the classics a Walbro pump often overpowers the tiny regulator and you can have 10 PSI more pressure than expected at idle.
Most injectors are specced at 43 PSI fuel pressure. If you increase the differential fuel pressure by a factor of say 1.2 to about 52 PSI, then the square root of 1.2 gives you the extra fuel volume - about 10% extra fuel for a given IDC.
john banks is offline   Reply With Quote
What should stock fuel pressure be? QwikRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 01-16-2006 08:08 AM
What is stock fuel pressure for 2.2 NA? reddevil Legacy Forum 5 07-14-2004 09:33 PM
What is base fuel pressure? Jgrahn555 Normally Aspirated Powertrain 4 03-26-2004 04:17 PM
What is everyones fuel pressure at idle and what pump/FPR are you using? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 20 05-30-2002 02:32 AM
What is a tire pressure for stock setup? S-WRX Brakes, Steering & Suspension 4 11-26-2001 03:19 PM
