Closed Thread
Old 04-25-2003, 06:23 PM   #1
bowenx
Member#: 6439
2002 Impreza WRX
Default wheels frozen/stuck, can't budge them
Hey folks,
for a few times now I have tried to get my steelies off and put on my summer wheels/tires, but the buggers are frozen on.
I have tried liquid wrench (spraying all spots that I think might help) and have whacked the snot out of it with a hard rubber mallet, to no avail.
I just tried using a metal mallet and have done nothing more than put a few dings in the wheel (now I am glad i have steelies).
anybody have any suggestions as to how to get the blasted things off?
I was thinking that an airhammer might do the trick, but seeing as I don't have one, that is out of the scope.
I might just have to bring to a garage and let them beat the things off....
any help is appreciated.
thanks
peter
bowenx is offline
Old 04-25-2003, 07:50 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
undo the lug nuts before trying to pull.
tora is offline
Old 04-25-2003, 08:30 PM   #3
thechickencow
Member#: 16840
07 fsxt
03 ktm 640 adventure
You could try loosening the lug nuts then setting the car down on the wheel, that might break them loose (and hopefully won't break your studs).
thechickencow is offline
Old 04-25-2003, 09:04 PM   #4
BluSuby
Member#: 12154
04 Sti
99 Outback
Try sitting on the ground and kicking the tire as hard as you can with your heel. A rubber mallet will just bounce off if you hit the tire with it and won't do much. Even if you hit the wheel with it, it won't exert as much force on it as your heel would while kicking it near the outside of the tire,
Bryan
BluSuby is offline
Old 04-25-2003, 09:05 PM   #5
bowenx
Member#: 6439
2002 Impreza WRX
lugnuts?
what are these lugnuts you speak of??
yes, removed them first, and yes, even tried to lower the car without them, at this point I am convinced that I don't even need lugnuts, the wheels will just stay on!
will have to figure something out.
bowenx is offline
Old 04-25-2003, 09:09 PM   #6
jaycee
Member#: 11104
2000 Impreza 2.5RS
Sedona Red Pearl
Get one of those "X" (or cross) lug wrenches. On one side, you pull. On the other side, you push or lean by using your body weight. It worked for me. Try that. Or get a long breaker bar.
jaycee is offline
Old 04-25-2003, 10:01 PM   #7
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
I had the same problem with my 9 year old talon... I took the lugs off , sat on my butt and pushed both feet to one side of the wheel, that broke it off.
You may want to leave a lug on so the wheel doesnt jump off and scratch your car.
MikeWRX-NJ is offline
Old 04-26-2003, 02:24 PM   #8
ForceFed4
Member#: 7370
SGM
I had this problem not 2 weeks ago, there's a thread I started if you want to search for it.
Brief synopsis: Penetrating oil sprayed onto hub & into each lug nut hole, then left to sit O/N. Came back the next morning and used the "sit on ground and kick the tire w/ your heels" method to break them loose. It took a surprisingly forceful kick to get them to pop off; I was afraid the car was going to fall off the jack, but it didn't.
Good luck.
Edit: If you're gonig to do that, make sure you have some brake cleaner handy to take the oil off the hub/brakes/studs. You might also get some anti-seize grease and use that in the future to stop it from happening again.
ForceFed4 is offline
Old 04-27-2003, 09:42 AM   #9
bowenx
Member#: 6439
2002 Impreza WRX
well, sounds like the sit and kick method is the way to go....
I will try spraying it again for extra measure, and good idea about the brake cleaner, would suck to finally get my summers on but not be able to stop!
thanks all.
bowenx is offline
Old 05-01-2003, 01:56 PM   #10
bowenx
Member#: 6439
2002 Impreza WRX
Ok, here's the update....
the blasted steelies are still on the car.
I have been spraying the liquid wrench all over the dang place (well, ok, only in the lugnut holes, the hub, and also was able to get some in via the air/vent holes in the wheels themselves but only where the wheel touches the main hub -as to not spray the brakes!).
I have used so far:
Hard Rubber Mallet- no effect.
Metal Hammer - no effect
Sit and Kick method - no effect
Loosen lugnuts and drive car 50' - no effect
Whacking the snot out of the wheels with a 3 foot log while swearing - no effect.
I have kept up with the spraying of the LW, will probably try again tomorrow.
This is seriously hamper my attempts to autox this weekend.
Well, I can always go for a bike ride!
thanks folks.
Peter
(I was tempted to just go to a garage and ask them to swap out my wheels for me, but have a feeling that they would get pissed and just cut the dang things off - I have thought of doing that myselft too!)
bowenx is offline
Old 05-01-2003, 02:15 PM   #11
mch
Member#: 30039
2002 wrx wagon
dirt slvr
Have you tried hitting/pushing/swearing from the inside>out. that is, get under the car (with it WELL BRACED ON JACKSTANDS!!) and pushing directly outward. If you are working only from the outside>in, you are relying on the rim leveraging against the hub. Force applied from the inside>out works directly on the rim only.
Just a thought. Good luck.
mch is offline
Old 05-01-2003, 04:06 PM   #12
bowenx
Member#: 6439
2002 Impreza WRX
Yeah, was thinking of that as well.
next time I try to take them off, (soon) I will make sure to try that, and hopefully the extra sparying of that liquid wrench will help as well....
thanks folks!
P.
(I guess I need to put some goop on there next year to prevent this again, however at the rate I am going, they will still be on there for next winter, a little bald probably, but there!)
bowenx is offline
Old 05-01-2003, 04:40 PM   #13
ForceFed4
Member#: 7370
SGM
Wow... and I thought I had a bad time with my steelies.
If you're going to get under the car, even on jackstands, and start kicking things, PLEASE be careful.
Good luck though, and definately pick up a wire brush and some anti-seize lube (should be real thick and usually silver). Make sure you remove as much of the rust as possible before putting any wheels back on.
Also, make sure there's no oil left on your wheel studs or lug nuts when you put the wheels back on, they're not supposd to be lubricated, and the torque specs will be all off if you do them on a lubricated nut. Not to mention the possibility of them backing off...
Old 05-01-2003, 07:38 PM   #14
dead-eye
Member#: 43
1999 2.5RS no T
RBP
I used a combination of the methods to get the rims off my wife's Camry. They were never removed in over 4 years so they were stuck on real tight. After loosening the lug nuts 1/4 of the way and spraying Liquid Wrench, we raised the car and then slowly lowered it. When the weight of the car didn't loosen them, we just rocked the car back and forth and the wheels came loose. If you do try this method, remember to loosen the lugnuts 1/4 of the way or LESS and do one wheel at a time only. Don't remove the lugnuts completely!
dead-eye is offline
Old 05-01-2003, 10:04 PM   #15
Jack ffr1846
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Default Easy solution....
Loosen the lugnuts....tighten them just finger tight. Lower the car. Drive about 4 feet and nail the brakes. Back up, jack it up and take off the wheels with no problem.
jack
Jack ffr1846 is offline
Old 06-15-2011, 11:07 PM   #16
PassportOwner
Member#: 285762
Default Loosen the lugnuts, drive...and brake.
jack
I had this same problem once. And did this exact same thing. Loosened the lugnuts. Drove a short distance slowly. Hit the brakes hard. Backed up slowly. Hit the brakes hard. Repeated a few times.
Jacked the car up. Removed lugnuts. Kicked tire. Boom. Tire off.
The hard braking torqued the hub just enough to break the lock on whatever was binding the rim to the hub.
Worked for me anyway.
PassportOwner is offline
Old 06-15-2011, 11:49 PM   #17
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
impressive first post in a zombie thread
nhat is offline
Closed Thread
Compressor Maps - Since alot of people can't find them sherifx Factory 2.0L Turbo Powertrain 81 08-25-2005 07:01 PM
Can't have them as pets, can't toss em, what can you do with them? m750 Off-Topic 12 11-25-2003 09:19 PM
If you can't drift them... dazz1 Texas Impreza Club Forum -- TXIC 21 12-07-2002 02:53 PM
So how the heck am I supposed to talk to the Imprezidents if I can't PM them? oops General Community 3 09-12-2002 09:33 AM
Heavy duty swaybar mounts, read this if you can't get them to fit the passenger side! Sean General Forum Archive 13 10-04-2000 12:55 AM
Message Board Statistics All times are GMT -4. The time now is 07:15 PM.
