Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 04-25-2003, 06:39 PM   #1
SCOOBER
Member#: 223
1999 Impreza 2.5RS-T
Default WRX/RS Hybrid-Crossmember Question
I have a legacy turbo crossmember (i think) that I have installed in my '99RS so I can use the up/down/turbo setup on my car. The problem is that the RS front swaybar will not fit.
I have the stock center mounts that work (the tabs/holes match) but the sway bar hits the dent for the uppipe (my crossmember only has one dent) and will not fit. If you put it in upside down, it will fit....but obviously that is not an option. Does anyone have a picture of the WRX front swaybar installed or off the car? I am running into lots of little snags on this project....big shock there, eh?
SCOOBER is offline   Reply With Quote
Old 04-25-2003, 08:56 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Try just putting a Wanted ad up in the Wanted Classifieds for a WRX front sway bar. I'm sure someone has upgraded and you can get theirs for a decent price. I *think* it should work, but don't quote me on it.
Old 04-25-2003, 09:25 PM   #3
SCOOBER
Member#: 223
I had heard there were fitment issues....but that it was just in the center mounts....never anything about clearance problems. I am hoping to finish this little escapade without too many more "surprises".
Old 04-26-2003, 11:38 AM   #4
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
last week i installed the wrx crossmember on my 01 rs and the stock bar will not work. You have to use a sway bar off a WRX wagon. The sedan and wagon bars are slightly different, and the wagon is the one you want, i purchased a 22mm bar made by whiteline for $120. bucks from Exeter Subaru in NH. It fits perfect.
bryan2.5rs is offline   Reply With Quote
Old 04-27-2003, 02:19 AM   #5
mechboy
Member#: 24692
1998 Legacy GT
i read that there is a diffrent aftermarket swaybar for turbo and non turbo applications...might want to check itno it
not 100% sure just what i read
mechboy is offline   Reply With Quote
wrx, rs hybrid. walksamongyou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-23-2008 04:16 PM
WRX/EJ22T hybrid, EM questions... deamon64 Open Source Reflashes 1 05-06-2008 11:04 PM
WANTED: RS fuel tank, RS rear crossmember RoundtheBend NWIC Private Classifieds 4 08-19-2007 12:27 PM
questions on wrx/sti hybrid setup legacy2003 Subaru Conversions 3 12-02-2005 12:27 PM
WRX crossmember question THAWA Brakes, Steering & Suspension 10 08-06-2005 08:38 PM
