Old 04-26-2003, 11:24 PM   #1
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
Default So has anyone noticed the rubber seal on the oil filter being crushed after removal?
mine was, hence the slight leak
Big_Hitter is offline   Reply With Quote
Old 04-27-2003, 01:18 AM   #2
tdxflex
Member#: 13634
did you put the oil filter on with your hands, or did you use an oil filter wrench? or was this the first oil change from factory? sounds like the filter was overtightened.
tdxflex is offline   Reply With Quote
Old 04-27-2003, 07:44 AM   #3
Big_Hitter
Member#: 10831
2009 FXT VF52/E85
Initially, yes it was a hand-tighten, then it had a small leak so I tightened it with a wrench.
I must have crushed it with the hand-tighten.
RUUUUUUUUUHH
<--- needs to lay off the protein
Old 04-27-2003, 08:42 AM   #4
Karl
Member#: 13110
How do you put the filter on?
(i.e. Did you clean off the mating surface and then put some oil on the rubber seal?)
Karl is offline   Reply With Quote
Old 04-28-2003, 07:41 AM   #5
Big_Hitter
Member#: 10831
2009 FXT VF52/E85
I made sure the mating surface was clean this time.
There was some gunk on it, ostensibly due to the leak.
Old 04-28-2003, 06:52 PM   #6
redforester
Member#: 30816
2003 Forester XS
Cayenne Red Pearl
Replace it with a new one, could be a manufacturing defect. The rubber seal should conform to the mating surface and stop the leak. Naturally, it should be compressed, but not crushed.
redforester is offline   Reply With Quote
Has anyone ever written a paper on the BPP? Absolut Off-Topic 9 05-10-2004 02:37 PM
Has anyone ever written a paper on the BPP? Absolut Off-Topic 0 05-09-2004 10:16 PM
So has anyone replaced a timing belt on a dohc ej25 lag Service & Maintenance 2 04-25-2004 02:40 AM
So has anyone ever blown a motor on a Cobb ecu? Swine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-19-2004 11:05 AM
So has anyone seen an SRT-4 on the street yet? Big_Hitter Texas Impreza Club Forum -- TXIC 34 03-04-2003 09:14 PM
