Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 04-27-2003, 08:08 PM   #1
J-Spec Tuning
Vendor Sales Rating: (58)
Member#: 32267
2015 BMW M235
Default Hotchkis Products - Free Shipping
Edit for 9/7: Sway bars back in stock
Sport Sway Bar Set...$330 Shipped
Includes front and rear sway bars + reinforced rear mounting brackets.
End Link Set...$200 Shipped
Includes front and rear end links
Reinforced Rear Mounts...$80 shipped
Folks purchasing the sport sway bar set do not need to buy these since they are already included
Street Coil Spring Set...@180 shipped
Lowers the front by 1.5" and rear by .75"
All in stock ready for delivery. Order on-line
Thanks,
Thaison
J-Spec Tuning is offline
Old 04-27-2003, 08:13 PM   #2
J-Spec Tuning
Member#: 32267
2015 BMW M235
Default Rear Bracket Comparison
Here's the reason why you really need reinforced rear brackets instead of going with the stock ones when using a larger aftermarket rear sway bar.
Old 04-28-2003, 02:49 AM   #3
Austin
Member Sales Rating: (1)
Member#: 7089
2016 STi
Does Hotchkis make a linear high-rate spring set for the GD body style that maintains a more proper ride height (keeps the rear lower)?
Austin is offline
Old 04-28-2003, 08:36 AM   #4
jblaine
Member Sales Rating: (36)
Member#: 8512
2002 WRX chassis...
stage-infinity.com
- www.j-spectuning.com/suspension = Invalid page.
- Almost everyone has rear endlinks already. Please consider talking to Hotchkiss about getting the front endlinks separately or please consider selling them separately. There's no reason they need to be sold as F + R for $220.
- Can you please take a picture of the "inner" (under) side of the heavy duty rear swaybar mounts? Preferable from 8 inches away and not 3 feet
jblaine is offline
Old 04-28-2003, 10:27 AM   #5
Wrxified
Member Sales Rating: (6)
Member#: 16222
2005 STi
Platinum Silver Metallic
Ouch. The stock bracket looks like it takes a beating. Wouldn't you need reinforced brackets for the front as well?
Wrxified is offline
Old 04-28-2003, 08:15 PM   #6
J-Spec Tuning
Member#: 32267
2015 BMW M235
Austin - The spring setup has been tested by Hotchkis extensively on the track and has performed very well. I have Eibach's on mine and will be switching to the Hotchkis after seeing and driving a WRX that had this on. There will be a Competition Coil Spring set made by Hotchkis but I do not have the specs on those yet.
jblaine - Link fixed, thanks for the heads up. As for the end-links, we only have the F+R available from Hotchkis at this time but have relayed your message about selling them separately. And the pics you requested is attached to this post.
wrxified - I believe Hotchkis developed these rear support brackets based on field experience of lots of rear OEM support bracket breakage but very little front bracket breakage. I personally broke three ( two rights and one left) OEM rear support brackets and no front ones.
Old 04-28-2003, 08:17 PM   #7
J-Spec Tuning
Member#: 32267
2015 BMW M235
doh, forgot pics
Old 04-29-2003, 12:30 AM   #8
neverendingmods
Member#: 23796
2006 STi
white
Can you tell me the difference between the sport swaybars(hollow), and the comp. sway bars. Are the Comp bars 1" solid. Pleeaassee say yes.
neverendingmods is offline
Old 04-29-2003, 12:50 AM   #9
turboICE
Member Sales Rating: (9)
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Hey Thaison. Expanding your offerings again I see - bump.
Unfortunately I already got the 20mm sedan rear sway bar on its way - going to see how I like that with stiffer spring rates first.
Interesting shape on the rear endlinks. Any purpose to that shape as far as different leverage goes? What about the grease fittings? Seems they would be tighter than the usual bushings. Not sure I would say that everyone has these if there are some design benefits. The kit is exactly how I would want them.
I notice the mounts have those grease fittings as well. How do these compare to Group N's?
What is the recommended maintenance interval on the grease - every time I take out another Aussie equipped Subie?
You have e-mail.
turboICE is offline
Old 04-29-2003, 12:23 PM   #10
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
You've been PayPal'd. See, the pics were worth it
jblaine is offline
Old 04-29-2003, 07:36 PM   #11
J-Spec Tuning
Member#: 32267
2015 BMW M235
neverendingmods - The difference between Sport and street is the inclusion of the competition end links with the sway bar set. The 1" bar is hollow but the performance is incredible - first hand experience and the Hotchkis track numbers
jehcpa - Lots of questions, I need to do some research and get back to you.
jblaine - thanks for your order, your package has been shipped.
Old 05-03-2003, 12:46 AM   #12
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Will these fit the wagon front sway bar and 20mm sedan rear sway bar? End Link Set...$220 I assume they will.
My guess is the bushings are made for the Hotchkis sway bar on these - Reinforced Rear Mounts...$90? If that is the case will the stock bushing bracket fit on the mounts? Would you consider selling the mounts without the bushings?
turboICE is offline
Old 05-03-2003, 01:22 AM   #13
J-Spec Tuning
Member#: 32267
2015 BMW M235
jehcpa,
The end-links will fit the wagon and any aftermarket sway bar you have.
Due to the design of the reinforced rear mounts, you will need the bushings that come with it. The Hotchkis bushings attach to the reinforced rear mounts via two bolts. Aftermarket/Subaru Bushings attach to the OEM rear mounts via one metal tab and one bolt. I was informed that the bushings will work on your 20mm rear sway bars as well as the Hotchkis sway bars.
Thanks,
Thaison
QUOTE]Originally posted by jehcpa
[/quote]
Old 05-03-2003, 02:15 AM   #14
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Thaison,
Thanks as always for answering my plethora of questions. You have an order. Have a good weekend.
Ed.
turboICE is offline
Old 05-15-2003, 12:02 AM   #15
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Bump for more questions.
What are the spring rates on those springs? (If they will disclose)
What is the expected drop on a wagon? (assume those are sedan drop measurements)
Is the wagon still expected to be able to tow within stock specs? (2,000 lbs and 200 lbs tongue weight)
Is it expected that the stock struts will dampen the drop adequately?
I have tracking for Friday on the end links and rear mounts.
Sorry for so many questions - looking at springs to tide me over until I can stomach a set of coilovers.
Ed.
turboICE is offline
Old 05-15-2003, 02:29 AM   #16
WRXWES
Member#: 5756
2004 Jeep Rubicon
Are the springs linear or progressive?
WRXWES is offline
Old 05-20-2003, 12:11 PM   #17
J-Spec Tuning
Member#: 32267
2015 BMW M235
jehcpa - Spring spec's
Front: 230 lbs/in.
Rear : 146 lbs/in.
Progressive rate
Was told that the drop on wagons would be same as sedans. Does work with the stock struts though will be carrying aftermarket ones soon...
Still looking for an answer on the tow question - you come up with some good ones...
WRXWES - answer above.
Old 06-01-2003, 01:16 AM   #18
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Default Reinforced rear mounts & endlinks
On a 2003 wagon with 02 sedan sway bar.
Have to use the 20mm bushings rather than the Hotchkis ones, not a perfect fit for the mounts but very close and functional except you can't use Hotchkis' grease fittings since the bushing is not designed for it.
J-Spec - if Hotchkis does make 20mm bushings that work with the grease fittings later - shoot me over a set!
Also for the end links what is the recommend grease for the fittings - just normal bearing/joint grease?
Thanks J-Spec, good stuff here.
turboICE is offline
Old 09-07-2003, 03:26 PM   #19
J-Spec Tuning
Member#: 32267
2015 BMW M235
Bump for Sway Bar sets back in stock.
COBB Products+FREE Shipping=FUN smartservice Suspension/Brakes/Handling 0 06-14-2006 02:09 PM
Free Shipping Whiteline , Hotchkis, Progress, EBC, DBA + Check Clearance Items RenickMotorsports Suspension/Brakes/Handling 6 11-16-2005 10:59 AM
Exhaust products free shipping DCH Motorsports Engine/Power/Exhaust 2 01-11-2005 11:37 AM
As Always, Free Shipping On All Kartboy Products! OAKOS Automotive Vendor 'For Sale' Classifieds 169 03-05-2004 12:03 PM
new products- free shipping Modified Toys Vendor 'For Sale' Classifieds 102 11-14-2003 10:50 PM
