Old 04-27-2003, 09:39 PM   #1
T33
Member#: 30050
2009 STI
Default Are these gauge readings correct? post yours too please!
I just installed Omori 45mm Oil Pressure, EGT and Boost.
These are my readings:
Boost: -15 to -20 psi at idle, slightly higher under throttle, 13max under WOT.
Oil Pressure: Start the car and it's at 80lbs, 85lbs. Under drive it's between 40-90. At idle after warm: about 30lbs.
EGT: between 1000 and 1300 deg. F. Sensor was installed at piston #3, 3" down on exhaust manif.
Boost seems low, but that's probably right considering I have an up-pipe leak.
Oil Pressure seems odd that it would fluctuate so much under driving conditions - I guess. Shouldn't it hover at about 70-80lbs and stay there?
EGT seems ok, I guess.
Could people please post their readings and advize on how my readings seem in relationship to the norm - They're now and I'm trying to decipher if they're ok or need any additional attention.
Thank you.
T33 is offline   Reply With Quote
Old 04-27-2003, 09:43 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Those readings look about right assuming the only mod you have is an uppipe. Oil pressure will fluctuate depending on whether your at idle or on the throttle. Your boost won't be higher with a uppipe. In order to increase boost, you'll need a boost controller or engine management that controls the FBC, i.e. Ecutek, Access ECU, etc.
Calvin
cnk is offline   Reply With Quote
Old 04-27-2003, 09:44 PM   #3
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Stock boost should be around 13psi.
Those reading seem pretty normal. Not too sure about the EGT tho.
The oil pressure is one of the best ways to really know when your car is warmed up or not.
90psi = not so good
Let the car warm up till the oil pressure drops before you beat on it.
Otherwise they seem normal to me.
V6TurboTA is offline   Reply With Quote
Old 04-28-2003, 11:15 AM   #4
T33
Member#: 30050
2009 STI
Thanks guys. That's awesome. My buddy installed the gauges and he did a great job - just checking to see what the normal readings are - thanks again!
T.
Old 04-28-2003, 11:53 AM   #5
BlueRex28
Member#: 34658
EGT danger zone is above 1500/1600 degrees. That would mean that your running lean so the solution would be to turn down the boost or add fuel.
BlueRex28 is offline   Reply With Quote
Old 04-28-2003, 12:11 PM   #6
tdxflex
Member#: 13634
everything's fine. your EGTs should never get that high. right now i'm running an uppipe, stealthback, and TMIC, factory boost control (get roughly 15psi), no engine management and my EGTs never go above 800C (1472F).
tdxflex is offline   Reply With Quote
Old 04-28-2003, 12:26 PM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
I can vouch for your boost and oil pressure readings being normal (this is close to what I get on my 52mm Omori's).
Just a tid-bit: when you read your boost gauge, anything below zero (vacuum) is represented in "inHg" (inches of mercury). Above zero is in PSI.
Regards,
Kean
Kean is offline   Reply With Quote
Old 04-28-2003, 01:35 PM   #8
newsman
Member#: 25904
2003 WRX
WR Blue/Gold
T33, what max boost do you get in 1st gear? I get .02-.03 Mpa peak. My max boost is .095Mpa in 3rd (I think) ,4th and 5th (for sure .
newsman is offline   Reply With Quote
Is my Boost Gauge Reading correctly? wlit Electrical & Lighting 9 06-11-2008 06:50 PM
Are these gauges crap? Hawk55 Newbies & FAQs 17 09-12-2007 09:20 PM
are these boost readings correct w/ cobb stg. 2 reflash? ASpec818 Engine Management & Tuning 0 06-07-2004 12:17 AM
Are these gauge readings correct? sdseagles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-09-2002 06:15 PM
Boost Gauge Readings Suddenly Way Off: Help Please TV3WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-28-2001 02:05 PM
