Old 04-27-2003, 11:09 PM   #1
Thumper23
Member#: 11571
Question Worn tires after auto-x
Well, I got back from my first auto-x today and damn it was fun. Quite a bit different from my last rally-x. Anyways, the outside edge of my right front Kumho is badly worn. This tire took most of the abuse throughout the day. The other 3 are slightly worn but nothing like this one. Is there anything I can do to help this out. I'm about to get Prodrive springs installed so I'm gonna get the tires rotated too. I'm guessing that's all I can do.
Suggestions?
Thumper23 is offline   Reply With Quote
Old 04-27-2003, 11:23 PM   #2
mofugga
Member#: 19540
2000 old skool RS
BRP
put more air in 'em next time!
mofugga is offline   Reply With Quote
Old 04-28-2003, 12:06 AM   #3
dunk
Member#: 15359
Wouldn't be a bad idea to have the alignment checked too, and see what the camber was in that wheel. Some shops will do alignment checks for free.
-Duncan
dunk is offline   Reply With Quote
Old 04-28-2003, 11:18 PM   #4
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Yep,
1. Get alignment checked/set - have the shop get you as much negative camber as possible in the front. Unless you have camber plates, this should be approx. -1 degree or a little more.
2. rotate the tires - front to back.
3. use more air pressure next time - I'd start with at least 45lb in the front and 43lb in the back. Chalk the tires, so you can tell if they're rolling over past the edge of the tread (look for little triangles on your tires, marking the tread edge).
-Steve
MNbiker is offline   Reply With Quote
Old 04-29-2003, 10:32 AM   #5
ltoohey
Member#: 20753
02 WRX Wagon
Sedona Red
There was a thread in our local autocross club, (www.spokes.org) a while back about Kuhmo tires needing to be shaved before using them in events like autocrossing.
Check with Luke at Tirerack I believe he knows about this....
ltoohey is offline   Reply With Quote
Old 04-30-2003, 08:44 AM   #6
AWMIII
Member#: 3980
2004 SVT Focus
Screaming Yellow!
You might also try adjusting the nut behind the wheel for the next event.
AWMIII is offline   Reply With Quote
Old 04-30-2003, 11:42 AM   #7
Achilles38WRX
Member#: 4419
2002 S2K - 2013 ISP
i don't have a wrx
i dunno what size or type of kuhmo your running, but like the others said, try running more pressure in them next time, rotate them, etc. With that being said, I did experince a lot more wear on the outer edge with my kuhmo 712's (215/45/17) from last season, i think those tires just tend to wear the outer edge more severly.
Achilles38WRX is offline   Reply With Quote
New Tires mixed with worn tires... JourdanWithaU Tire & Wheel 8 02-13-2008 08:54 PM
Azenis worn out after 4 months? scobaru Tire & Wheel 20 11-16-2004 12:56 PM
Tire pressue for 50% worn tires Craig02WRX Brakes, Steering & Suspension 3 04-13-2003 08:27 PM
Worn Tires? MarkZ Newbies & FAQs 14 10-31-2002 01:36 AM
Worn Tire Question SLKWrx Tri-State Area Forum 9 05-10-2002 11:15 AM
