Old 04-28-2003, 01:16 AM   #1
WRX_Sir
Member#: 31489
2005 6 Slow Speeds
Jet Black
Default What ECU mod system should I get with current mod?
Here are my current mod:
Uppipe
Downpipe
Full system exhaust
MBC 16psi
I am not going to change my turbo any time soon but I do planning to upgrade to Samco piping stuffs.
Thanks,
Mack
WRX_Sir is offline   Reply With Quote
Old 04-28-2003, 11:39 AM   #2
KJR
Member#: 16879
you can use the Cobb access ecu reflash, stage 2. i am doing mine real soon and possibly adding a slightly more aggressive map for my larger TMIC.
KJR is offline   Reply With Quote
Old 04-28-2003, 03:36 PM   #3
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Are you looking to be able to make changes yourself. Also were are you located, if you are wanting someone else to tune if you may want to look at what is availible from distributers close to you. Other wise if you want to do it your slef I would look at the UTEC, good product, strong user base.
roybfr is offline   Reply With Quote
Old 04-29-2003, 12:11 PM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
remove mbs and sell it
then get a cobb reflash
What blow off valve should I get? I am new so bear with me tricked-out Factory 2.0L Turbo Powertrain 32 04-19-2012 10:16 AM
what sound system should i get? gindobuck Car Audio, Video & Security 23 03-29-2009 03:57 AM
What tires should I get with my 18 inch P1's Roswellj07 Tire & Wheel 7 08-17-2003 01:40 PM
What awhp should I make with these mods? Electronsmurf Factory 2.0L Turbo Powertrain 7 02-28-2003 12:35 PM
should i get a current impreza or new one?? impreza_power General Forum Archive 5 08-30-2000 07:38 PM
Message Board Statistics All times are GMT -4. The time now is 04:12 AM.
