Vancouver Impreza Club
Old 04-28-2003, 05:25 AM   #1
STi-Mulation
Member#: 34722
05 BMX
Default Add HIDs to canadian STi?
We all know that the Canadian STi is coming without the HIDs.
What do you guys think is the best way to ractify this oversight?
1) Order the original HID kit form the US or Japan and do a direct swap.
2) Buy a Philips HID kit for ~C$1,000 and install it yourself/at your garage/at dealer.
3) Order it through your local Subaru Dealer.
Comments?
STi-Mulation is offline   Reply With Quote
Old 04-28-2003, 06:18 AM   #2
Toast
Member#: 11163
2010 Mercedes C300
Calcite White
By saying "the best way", do you mean:
1) the most cost effective way, or
2) the way which yields the best results?
If you're after #1, then just get a philips HID kit locally. The'yre not $1000, more like $600 installed. But since the headlight housing is not designed for the HID system, you may result in unsatisfactory lighting. And you run the risk of being pulled over by cops and geting ticketed.
If you're after #2, then suck up the cost and order the lights from a US dealer (don't get the JDM ones, they have way different meab patterns). Sure it costs a boatload of $, but it gives you the best results and since it is DOT approved, its technically legal in Canada.
If I were you, I'd skip lunch for a few months and get the real deal, since you're getting an expensive car already.
I guess that's it, enjoy your new car!
Toast is offline   Reply With Quote
Old 04-28-2003, 01:13 PM   #3
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
I agree. A philips HID kit is really just a bandaid to add so you can say you have HIDs. I'm sure the real deal is vastly superior since the assemblies were designed with HID in mind. Lights are very carefuly designed and things like fillement placement are critical to getting a good beam pattern. I just don't believe a drop-in HID kit will work anywhere close to optimally with stock optics.
AllWheelDrift is offline   Reply With Quote
Old 04-28-2003, 06:32 PM   #4
etam
Member#: 439
www
go to ebay and buy yourself a set of bixenon hid projectors and hid hardware ~US$500 and retrofit into your stock headlights and you will be bright and legal and unique!
etam is offline   Reply With Quote
Old 04-28-2003, 06:38 PM   #5
Toast
Member#: 11163
2010 Mercedes C300
Calcite White
Is this a joke? Cutting up your existing headlight housing and adding ANYTHING to it is far from legal. And I would think Bi-xenons will be ten times harder to retrofit than normal xenons, siince you need to wire the motor behind the lamp to move up when you switch on high beam.
Unique? Probably...
Bright? Probably, but you could blind other drivers if not aimed properly...
Legal?
Old 04-28-2003, 06:53 PM   #6
STi-Mulation
Member#: 34722
05 BMX
I believe that the Kit which is C$600 is the 4100K kit. From what I know, the 6000K kit is much more expensive and give out a more "blue" beam.
Doing a reasearch for the current 02 WRX, the Original Subaru HID kit is around ~ 3G CAD. Humm... so the total sticker is somewhere around 59-60Gs after taxes and including HIDs... ouch!
Old 04-28-2003, 06:55 PM   #7
etam
Member#: 439
www
oops.. I forget to say it is not easy.. and btw, those are DOT approved bi-xenon projectors as used in BMW and I am sure they are legal!
Old 04-28-2003, 07:28 PM   #8
etam
Member#: 439
www
a local guy putting bixenon in his bugeye!
http://www.pbase.com/honzy/car_pictures
Old 04-28-2003, 07:43 PM   #9
etam
Member#: 439
www
don't waste money on anything more than 4100 or 4300k, 6000k looks cool but they are not as bright as 4x00k. Also, 6000k sucks in foul weather. All OEM car come with 4x00k, some of them look blue when look right in front because of the projector len/shield effect. Also, as the bulb gets more burn time, it will up to ~5000k.
Old 04-28-2003, 09:08 PM   #10
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Yeah, the are legal but... ONLY ON THE BMW.
Old 04-28-2003, 10:56 PM   #11
etam
Member#: 439
www
some more retrofit in gallery section: http://www.illusion-lighting.com/
I don't know why it makes you think it is illegal on other car when the projector is exactly the same as those in BMW.
Anyway, I will sure enjoy my new found lighting when I got it done.
Old 04-29-2003, 03:25 AM   #12
Toast
Member#: 11163
2010 Mercedes C300
Calcite White
Umm... let me get this straight. The reason why the lights on the BMW are legal may be because of the fact that they are factory options?
Actually, what makes you think its legal? Some guy please point this clown to the motor vehichel act.
I'm sure you'll enjoy your new lights, but don't be pissed off and argue with the cop when you get pulled over (touchwood). IT IS ILLEGAL.
Old 04-29-2003, 03:27 AM   #13
Toast
Member#: 11163
2010 Mercedes C300
Calcite White
To save you some footwork, here's what the site you posted says:
From phase 1 to phase 3, all of our retrofits are designed to offer our customers the most effective lighting available on the market whether for show, race, or off-road.
If you're still convinced that these are legal, good for you.
edit: After looking through the photo gallery of the site, a lot of lights has been retrofitted with BMW E39 (5 series) projectors. Has anybody ever wondered where did all those lights came from?
Old 04-29-2003, 11:17 AM   #14
etam
Member#: 439
www
A lot of people have connections with junk yard.. and 5 series has been around for quite a while.. actually, I won't comment on where they get the OEM projector units.
Why I think they are legal? That's because they are DOT approved and those projector units are designed for the HID bulbs from the beginning.
It is illegal to just slap in HID kit into your OEM reflector headlights because they are designed for halogen not HID and the beam pattern will cause glare to on-coming traffic.
edit: are those morrette headlight legal? I believe they have DOT or E-code lens too and should be legal.
edit again: after doing some more search and looks like morette are NOT dot and so they are illegal.
I guess if you really want hid, then go buy US unit then.
Old 04-29-2003, 04:21 PM   #15
-S-
Member#: 6979
Ahh, the halfassed researching skills
Morettes (for the GD at least), are not DOT approved. You're absolutely correct. The next part is where you messed it all up E-codes are legal in BC, if not Canada.
-S- is offline   Reply With Quote
Old 04-30-2003, 02:02 AM   #16
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Talking
My Morettes have both DOT and E-Code marking on the outer lens, but only E-Code marking (I believe) on the inner lens.
kgb is offline   Reply With Quote
Old 05-02-2003, 05:31 PM   #17
STi-Mulation
Member#: 34722
05 BMX
I was informed few days ago that the reason the STi in Canada does not have HIDs is that it is a LAW here that the driving lights are turned on once the engine is started.
If that is so, why are there so many cars with original HIDs in Canada? One may argue that there are daytime driving lights but visually I can see 2 sets of bulbs in the light clusters of the 04' Imprezas. Also most Jap Imports I know of have driving lights just that in Asia, you have to activate it yourself manually.
Is there something which I am missing out??
Old 05-02-2003, 07:06 PM   #18
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Unhappy
Technically, what Subaru should have done is to drive the DRL on low-powered high beam, leaving the HIDs off which is exactly how the European cars here do it. That's a difference coming from a manufacturer that's much much more concerned about the bottom line.
Attn Canadian STi owners - HID install OttawaSTi Electrical & Lighting 2 04-07-2006 06:29 PM
Attn Canadian STi owners - HID install OttawaSTi Canada Region Forum 31 11-16-2005 10:07 AM
STi - HID for Canadian models 2cati Electrical & Lighting 6 01-03-2004 01:38 AM
Converting the CANADIAN Sti to OEM HID? RickDaTuner Electrical & Lighting 4 11-14-2003 04:48 PM
US STi HID ---> Canadian STi / US WRX Extraze STi Forum Archive 6 06-25-2003 06:22 PM
Message Board Statistics All times are GMT -4. The time now is 11:32 AM.
