Old 04-28-2003, 07:21 AM   #1
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
Default pulling HP
ok so im kind a turbo head seeing that my last car was a turbo, I know where to pull the HP with a turbo, but on an N/A how do i make the HP ? ( playing with a FWD 2.5 )
cindergarden is offline   Reply With Quote
Old 04-28-2003, 07:53 AM   #2
bigdweeb
Member#: 31035
13 Ford Explorer
13 Mazda3 Skyactiv
Do you mean you are looking for ways to increase HP or where in the powerband the car is making the most HP?
bigdweeb is offline   Reply With Quote
Old 04-28-2003, 01:18 PM   #3
xfrickx
Member#: 7267
1994 Honda VFR RC-36
2002 Subaru 2.5RS
Did they make a Front Wheel Drive 2.5 Liter?
xfrickx is offline   Reply With Quote
Old 04-28-2003, 02:03 PM   #4
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
To my understanding they didn't make 2.5's for any 94 L.
Maybe mistaken for 2.2? Or perhaps a 2.5 swap he did we didn't know
-paK +1
Pakin is offline   Reply With Quote
Old 04-29-2003, 09:17 AM   #5
Hawk296
Member#: 14555
1995 L (Apex Tiger)
Battle Ready Baja
I think he's working on a 2.5L swap....
Hawk296 is offline   Reply With Quote
Old 05-01-2003, 07:14 AM   #6
cindergarden
Member#: 21158
94 FWD 2.5
Acardia Green
correct they dont make one, Im goin to be undertaking the swap project as soon as i graduate, hopefull that weekend, but yes the end result will be a 2.5 FWD car, im looking more for a mid range high range power, i know the car will pull as is but i want just a little bit more
Old 05-01-2003, 11:37 AM   #7
dcoty
Member#: 3149
01 V7 GC/R32 sky
Well for mid-high range power, I think (depending on your budget) why not put some cams into the engine while its out of the car, and perhaps port you heads at a shop if you are able to.
Take advantage of the fact that the motor is out of the car and the performance hot spots are readily acessable for modification. Once you do whatever you can to the motor (heads, cams etc), put the motor in the car.
Then, when you are willing and able, continue with the bolt ons such as exhaust, intake, pully etc. And later down the road, put some engine management icing on the cake with a piggy back system such as Unichip.
But please do the cams and heads now while the motor is out of the car, that is a big advantage for you, forget about the easy to install bolt ons for now and do the tough stuff you cant normally do without removing the motor anyway.
For cylinder heads at a good price (as well as anything that goes in a subaru, even STi motors/trannys) go to www.lachutesubaru.com and call them (1-450-562-0262) and talk to Ben, Julien or Mark, these guys will help you out. All prices are in canadian dollars so you save on the exchange rate, whch is great.
Good luck, and please do the big stuff now!
Dan
dcoty is offline   Reply With Quote
Wheel HP to Flywheel HP or Crank HP Ultimate Newbies & FAQs 16 12-13-2007 05:46 PM
HP pulled me over for STOCK STi EXHAUST! teamipr Bay Area Impreza Club Forum -- BAIC 15 10-02-2003 10:12 PM
Pulling the coolant lines to TB HP! Lit4 Factory 2.0L Turbo Powertrain 9 05-17-2003 01:54 PM
When pulling the engine, which Engine mount bolts to pull? Eric SS Normally Aspirated Powertrain 3 10-04-2001 02:46 PM
Pull to the left... pull to the right... why? mb2k Brakes, Steering & Suspension 17 10-13-2000 11:14 AM
Message Board Statistics All times are GMT -4. The time now is 07:34 AM.
