04-28-2003, 08:29 AM | #1 |
Member#: 4647
Vehicle:2003 WRX Wagon Sedonia Red |
Floor Jack?
I ordered a set of takeoffs (wheels) and tires for my 2003 WRX Wagon.
Can I jack the car up, using a floor jack, under the factory jack points? Thanks
04-28-2003, 09:43 AM | #2 |
Member#: 10119
The safest way is to jack up the car from the rear differential and front crossmember and use jackstands at the jackpoints to hold the car. Jackstands are cheap and really a wise investment - you can buy 2 and do the fronts then the rears, or buy 4 and jack the front and rear at the same time. Having 4 makes it easy to rotate your tires too.
04-28-2003, 10:47 AM | #3 |
Member#: 24463
Vehicle:2003 Chevy S10 91 Hunduh Civic BASE |
Yes you can jack it up at the factory jack points.
04-28-2003, 11:15 AM | #4 |
Member#: 24475
Vehicle:1999 Forester L Dirty |
That is why there are jack points.
04-28-2003, 04:06 PM | #5 |
Member#: 8225
My floor jack and the jack points are not totally compatible. The ridge along the jack point doesn't have a good place to land on the jack "lifter part thingy." I use a scrap of strong oak in between. My usual 2x4s were cracking and creaking.
04-28-2003, 05:41 PM | #6 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
Be careful, you can dent the underbody if you jack at the jack point only using the outside edge. Get a 2x4 and cut a slot in it, VOILA a non scratching universal jack adapter!
Slickdeal Sears Craftsman 2 1/4 ton Floor jack w/jack stands $27.50 | plunk10 | Off-Topic | 18 | 02-17-2006 01:11 PM |
Where should I jack up my car using a floor jack? | Loki | General Community | 1 | 04-16-2004 02:53 PM |
floor jack or bottle type jack | SocialButterfly | Service & Maintenance | 11 | 11-27-2003 09:52 AM |
Where to jack up my car with a floor jack? | Sordid Philosopher | General Community | 1 | 11-17-2002 03:52 PM |
