Old 04-28-2003, 04:27 PM   #1
WRXURV8
Member#: 14848
2007 Tribeca
TS w/ 20" OZ's
Default 225's on 17" x 7" Wheel?
I have OZ SLs in 17" x 7". I was told to go with a 215/45 rather than a 225/45 due to my wheel width. However, many people, including the Tire Rack, seem to recommend a 225/45. This is not a wheel diameter, gearing, speedometer accuracy, etc. question. I just want to know if a 225/45 can be used on a 17" x 7" and if some brands work better than others. Will this have any effects on the sidewall?
WRXURV8 is offline   Reply With Quote
Old 04-28-2003, 04:51 PM   #2
KJR
Member#: 16879
i had dunlop 225/45 on those same wheels and they fit/looked nice. however, i think 215/45 is better suited from a performance aspect. with the wider tire, depending on the manufacturer of course due to different sizing, you may lose performance with the wider tire cuz the area of load on the sidewall will move to weaker points on the tire.
KJR is offline   Reply With Quote
Old 04-28-2003, 05:30 PM   #3
lark6
Member#: 2715
70 911T
I can't speak to a 225/45 on the Superlegs but I currently have a set of 225/50s on mine. Then again, I have mine mounted on a Forester.
Ed
lark6 is offline   Reply With Quote
Old 04-28-2003, 07:02 PM   #4
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
I have 225/45 mounted on BBS RK's - they're 17x7". They work very well. When it comes time to replace them however, I might go with a 215/45 simply because there's a little extra tire hangover around the rim edge. This can actually be a good thing though... brushing a curb won't hurt your wheels, and like I mentioned performance (at least from my Goodyear F1's) is outstanding.
heffergm is offline   Reply With Quote
Old 04-28-2003, 07:58 PM   #5
tora
Member#: 5851
09 Forester XT
+ NA Miata
225's are fine on a 7 inch wheel. Even a 6.5 inch wheel would be ok, but getting to a 6 inch wheel is pinching it a bit. Some Miata guys at auto-x run a 225 on a 6 inch wheel, but then they have lower profiles as well...
Anyways, no problem IMO.
tora is offline   Reply With Quote
Old 04-28-2003, 10:08 PM   #6
rkkwan
Member#: 5596
2010 Honda Fit Sport
Just go to the tire manufacturer's website and check the specs on the tires you want to mount.
You cannot just assume all 225 tires will be okay on a 7" wheel. It depends on the diameter of the wheel as well as aspect ratio.
For example, with Bridgestone S-03, 225/50r16 is approved on 6" to 8" wheels.
225/45R17 is 7" to 8".
225/40R18 is 7.5" to 9".
Etc, etc.
-Ray
rkkwan is offline   Reply With Quote
225's on stock 02 wrx wheel? bigolrig Tire & Wheel 4 03-05-2009 11:12 PM
FA: Sport Edition Fox 2 17" x 7" Wheels for WRX, Legacy, etc. rlavalle North West Impreza Club Forum -- NWIC 5 12-06-2004 06:38 PM
Tires on 17" UKDM WRX Wheels chewbakarox Tire & Wheel 19 05-20-2004 05:24 PM
215 vs 225 on 17" 7.5 Wheel Rally Punx Brakes, Steering & Suspension 10 10-15-2002 01:37 AM
225's on stock 2000 RS wheels? Evan J. Kelly Brakes, Steering & Suspension 16 02-15-2002 10:47 PM
