#1 |
Member#: 22321
I wasnt sure where to post this, but since i have a wrx, and its factory forced inducted. ... i figure i can post here..
WHY DOES THE STUPID AC TURN ON AND OFF.. COLD AIR...warm air... COLD air.... warm air... anyway to disable that stupid fuinction? makes the car feel like crap when ur driving and u can actually feel the power differences.
#2 |
Member#: 10757
Vehicle:2013 BRZ Limited 6MT DGM |
Not exactly sure what you're talking about here?
Under what conditions are you experiencing this? If you are going WOT, this will cause the A/C to be turned off until you get off the gas. Calvin |
#3 |
Member#: 25399
Vehicle:2003 Impreza WRX Black |
If you are talking about using the Defroster, it cycles the AC.
There is a mod you can do to make it not use AC unless you press the AC button as well which will remove the issue completely. |
#4 |
Member#: 22321
normal driving.
ac on, not defroster mode. no one has noticed this on their car? |
#5 |
Member#: 14930
Vehicle:2006 Evolution Graphite gray |
Mine does the same thing. Its like super cold for a few seconds, turns to like regular air for a few seconds, back to super cold. I tried doing some investigating on this last year but I couldn't find any info on it. And I was too lazy to have a mechanic look at it.
#6 |
Member#: 22321
exactly! why would subaru make the AC do something so stupid.
#7 |
Member#: 14930
Maybe its just our silver rex's
#8 |
Member#: 16738
Vehicle:2006 STi Crystal Gray Metallic |
yeah I think it's a silver thing mine does it too.
#9 |
Member#: 17851
Vehicle:2003 WRX R.I.P. 7.27.2005 |
I think its to keep too much load off the engine.
Basically it only really works when the revs are up. At idle it slows down to keep work the engine has to do at a minimum, and at WOT it does the same to give you power (kinda like on the new M3, at WOT the alternator stops working, good for something like 8hp)... So I guess in stop and go traffic it would suck...maybe put it in neutral and rev the eingine at like 2-3K and see if it comes back on. |
#10 |
Member#: 14264
Vehicle:'03 wrx wrblue |
i have has 2 wrx's both with this problem a 2002 and now a 2003
you can feel the compressor turning on and off and really does make the car feel bad my 2002 i took to the dealer because of the air going from hot to cold and they said nothing could be done the air never gets really cold either like for example in my parents car you take a 20 min drive and you have to turn the air down because it is so cold but last summer i took a trip from st. louis to chicago and had the air full blast the entire time and i was still HOT |
#11 |
Member#: 16738
sounds pretty much the same as mine, maybe someone in the electrical forum can figure something out.
#12 |
Member#: 19221
South East
Vehicle:2005 Legacy GT (STi) UR35R/Rotated Intake Mani |
If your compressor is cycling hot and cold air then that usually means your A/C systems is low on freon. If you are only getting hot air then I would definitely get the A/C system checked. This is a common problem with cars and I service A/C systems all the time especially during the summer time season.
This may or may not be a solve to the problem, but this would be a good place to start. Just my .02 cents. -Matt |
#13 |
Member#: 33368
Vehicle:2003 WRX wagon Sedona Red |
Mine is a brand new 03, it's red, and it does the same exact thing.
#14 |
Member#: 34661
There is a technical service bulletin for this. A sensor on the evaporator core designed to detect icing of the system freezes up more than it should, causing the compressor to shut off frequently. In Dec 01 production they moved the sensor to a different part of the core. But that didn't help all cases. Then in Oct. 02 they changed the sensor to an internal sensor.
Unfortunately, this is not a DIY job. I haven't had a chance to take my car to the dealer yet and I have the EXACT same problem. |
#15 | |
John Wayne Toilet Paper
Moderator Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
-Nick |
#16 |
Member#: 34672
Vehicle:2003 wrx WR Blue Pearl |
The compressor turning itself on and off is normal... any car with A/C will do this.
However, it's not normal for it to start blowing cold air, then warm air, etc. You should feel the compressor cycling, but the air should remain cold. Bring it in and complain... it's not right. |
#17 |
Member#: 25603
Vehicle:2003 WRX Wagon 5mt WRB |
I found the same quirk with my ac. However i first noticed it late last year after walking to my car with my friend in the rain. The AC was anable to defog the windows even on the highest fan setting. the ac would go on for 8 secs and then off for 20 secs. That was in cold 40 deg weather. Now with the warmer temperatures it stays on much longer at least half the time now. I found that its not too bad but the AC does have a hard time getting the car a comfortable temperature when it is warm and very sunny out. This might be better later in the summer when i'm wearing shorts and not long pants. If you really want it to get colder try putting the ac on recirculate. I found the ac to get much colder when its not sucking hot air from the outside. If there really is a techinal bulletin on this i should definetly goto dealer to have it performed. But i think i'll hold off until i can try the ac in the summer.
Franklin |
#18 |
Member#: 23974
Vehicle:2003 WRX Wagon Sonic Yellow |
Not it is not just a silver thing, my Sonic Yellow does it too.
#19 |
Member#: 11443
Vehicle:2002 WRX Midnight Black |
My black does it too. Has from day 1. Really sucks when it is 100 out. Air temp out the vents is 90, 50, 90, 50, 90, 50 and it never cools a black car fully.
~PC |
#20 |
Member#: 17974
To twist the question a little:
does the "AC mod" thus aleviate the constant cycling of the AC compressor? or does it only affect the defroster setting? Wrx300 |
#21 |
Member#: 25187
Vehicle:'08 Foz Prem TGM '10 Challenger R/T Blk |
Mine does the same thing and it's not something I would consider "normal". It gets downright uncomfortable when it's warm outside. It's annoying to have the A/C cycle cold and warm air constantly. I've read the service bulletin Rick Schu described and it made sense to me. I'm waiting until the weather begins to warm up enough so the problem will be more apparent when I bring it in.
#22 |
Member#: 26014
Vehicle:2006 WRX Wagon Black |
Hehehehe! My little blue one does it too!
#23 |
Member#: 6954
RMIC
Vehicle:05 FXT Pre: 02WRX, 98RS, 99RS |
Um, mine goes on and off too...
but it's usually due to me pushing the A/C button on and off when i need power stopped at traffic light about to turn green : A/C off once cruising at steady speed : A/C on need power to pass someone : A/C off Moral of the story... this A/C sucks... i guess if yer not turning it off/on by yourself it'll do it anyway, just at different times... what a pain... |
#24 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
Have the same issue. The AC cycles on/off pretty constantly while cruising. Its annoying and I want to fix it. Will the dealer do something about this?
-- Ed |
#25 |
Member#: 24729
Vehicle:1993 Legacy gtb- sti black wagon |
hmmm, our legacy doesn't
| Thread Tools | |
| Display Modes | |
| My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? | nicksamba_18 | Off-Topic | 9 | 08-21-2009 07:37 PM |
| My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? | nicksamba_18 | Service & Maintenance | 0 | 08-21-2009 07:21 PM |
| A/C Compressor kicks on and off, on and off - AC Clutch?? IT's HOT here! | ogboot | Service & Maintenance | 9 | 06-20-2009 11:18 AM |
| AC kicks off and on?? | MY2ND04WRX | Subaru Conversions | 6 | 07-14-2007 08:42 PM |
| AC on or off? | ALEXSB3 | Newbies & FAQs | 6 | 08-29-2006 12:33 PM |
