Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 04-28-2003, 07:25 PM   #1
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
Default Ok, need some help on mod decisions...
Hey guys,
You all know me....I ask questions about stuff, then ask them again, and still i ask more questions before I spend my money....so I need some help from here...
I've been going back and forth about which route I should go with first....Here's my options:
UTEC - $1000 - +35whp
GTSpec V2 headers + uppipe, Perrin catless DP, JIC 505Ti catback - $1900 - ~+50whp
Any other suggestions?!?
My current mods are listed here:
Clear Signal Lights
HKS Type 1 Turbo Timer
Turbo Timer Harness
Ociari Wing painted/installed
Ociari 3rd Brake eliminator
STi Group N HD Tranny Mount
Kartboy Shifter Bushings
HKS SSQV BOV
Perrin Shortram Intake
STi Group N HD Engine Mounts
Sylvania SilverStar Headlight Bulbs
Hella YellowStar Fog Bulbs
Hella Supertone horns
Cusco Front Sway Bar
Cusco Rear Sway Bar
Cusco V2 Brace Bar
Defi Gauge Pod
LT A-Pillar
Defi BF Gauges (6)
Tint
Perrin Rear Endlinks
GFB Pulley Set
Whiteline Subframe Lock Kit
Sti Group N HD Pitch Mount
Kuhmo MX 225/50R16
Fenderwell Blocking Plate
Cusco Front Strut Tower Bar
Thanks guys!!
~sf~
ScreaminFast is offline   Reply With Quote
Old 04-28-2003, 08:07 PM   #2
Mr.Hanky
Member#: 22053
2002 Black WRX Wagon
Stage 3, Element Tuned
That's a tough one. Both suggestions are great.
I got my turboback first, then the UTEC. Either way both will complement each other, you could add the UTEC later and use stage2 after the exhaust.
The UTEC would be cheaper, easier to install and very stealthy.
You could also pull it out easily for "warantee related issues" that would not be the case with the other option.
It is also something that can adapt to any mod you do later on, stage 2, 3, 4.... 23, ect.
So, in short, I have no opinion, sorry for wasting your time.
Either way you can't loose.
Steve..
Mr.Hanky is offline   Reply With Quote
Old 04-28-2003, 08:57 PM   #3
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Headers are a waste of money.
~v6
V6TurboTA is offline   Reply With Quote
Old 04-28-2003, 09:41 PM   #4
fastfood
Member#: 7202
2002 Impreza WRX
TrackWhore #09
MRT turbo-back + uppipe ~ $1350 (30hp)
Next,
AccessECU reflash ~ $400
This combo alone will net you about 300hp. Also there is an Access port coming late next month which will allow YOU to do the reflash. You can also tune the car with the reflash as you add other mods (just like a UTEC, but cheaper and stealthier)
fastfood is offline   Reply With Quote
Old 04-28-2003, 09:55 PM   #5
Mattr762
Member#: 31624
02 WRX White
uppipe, turbo-back, MBC
Next,
Your a little high on your hp estimate.
Stock WRX = 165ish whp
Turboback = 25ish whp
uppipe = 10ish whp
AccessECU = 25ish whp
Total = 225 wheel HP
Total = 285 Crank HP
Of course this all depends on which dyno you use.
Mattr762 is offline   Reply With Quote
Old 04-28-2003, 10:15 PM   #6
V6TurboTA
Member#: 9090
09 Forester Gump
To add up hp figures based on parts... It to count your chickens before they hatch.
Its a very good way to impress your friends tho.
~v6
Old 04-28-2003, 11:46 PM   #7
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
hmm, i'm actually looking to talk to the guys as massimo performance (thewrxstore.com), and seeing if I can get a stage 2 package price using one of their DP's and the JIC 505 Ti. Maybe a total package of like $2200, and have the UTEC come tuned for Stage 2. Then all I'd have to do would be to tweak the map for my intake and the pulleys, and I'd probably have some serious hp...
Old 04-29-2003, 01:19 PM   #8
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
anyone else got any suggestions?
A/V guys, I need some help on a decision. aod Off-Topic 87 10-29-2009 05:54 PM
I need some help on making a decision rb22b Brakes, Steering & Suspension 5 04-22-2008 09:45 PM
Ok..need some advice on 1st mod elk29n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-27-2003 07:58 AM
I need some help on a brake decision? waitandbleed92 Brakes, Steering & Suspension 2 11-07-2003 08:33 AM
New WRX and need some help on some mods 02WRXguy Texas Impreza Club Forum -- TXIC 19 07-17-2002 12:49 AM
