Old 04-28-2003, 10:01 PM   #1
ericjames
Member#: 31798
Default Car runs like ass.....sometimes
Ok guys I need your help. Last week I installed a vf22, fuel pump, and STi injectors and the car was running fine but it began to get worse and worse and I was kinda pissed. I tried to reset the ECU and it didn't do anything. So the next day I see I'm almost on empty so I go and fill up at a different gas station than I usually go to because I thought maybe it was running ****ty because of a bad tank of gas. Anyways it ran sooooo much better almost imediatly after filling up so I thought my problems were solved....untill today. My tank is about 1/4 full and the car is starting to run worse and worse. It feels really learchy and not smooth at all. It rumbles much more at idle than it should. My fuel pressure looks fine at all levels of boost so I'm kinda stumped. My only guess is that it has something to do with the fuel pump not being able to get enough fuel for some reason. What do you guys think???
Thanks in advance,
Eric
ericjames is offline   Reply With Quote
Old 04-28-2003, 10:12 PM   #2
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
I would try replacing the fuel filter.
I got a tank of bad gas and my car ran like crap till i replaced the fuel filter.
It might help...
~v6
V6TurboTA is offline   Reply With Quote
Old 04-28-2003, 10:24 PM   #3
Mother
Member#: 33829
2015 STI
Lightning Red
Do you have any engine management (utec, xede, reflash, etc.) to control the injectors, or are you relying on the stock ECU to control your STi injectors?
Mother is offline   Reply With Quote
Old 04-28-2003, 10:42 PM   #4
The Professor
Member#: 23183
2002 Cobb StageIIWRX
WR Blue
You are on the right track with the pump and the engine management definitely. The fact that it runs ok until a 1/4 tank should be a major clue for your local tuner.
The Professor is offline   Reply With Quote
Old 04-28-2003, 11:40 PM   #5
ericjames
Member#: 31798
Hey Guys,
I'm running a vishnu unichip to run the injectors and my fuel filter was just changed 2k ago.
Thanks,
Eric
My car rides like ass, need help KW900 Brakes, Steering & Suspension 19 02-26-2010 12:00 PM
ewg just installed. Runs like ass O Stylee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 10-07-2006 06:50 PM
please help car running on 3 sometimes 2 clinders turbocolin Normally Aspirated Powertrain 9 08-18-2004 07:38 PM
This site is really running like ass tonite. Brahmzy Off-Topic 2 08-01-2003 05:30 AM
Anybody's car run like crap after... Tokay Normally Aspirated Powertrain 1 07-17-2002 11:32 PM
