Old 04-29-2003, 03:08 AM   #1
wayoutwest
Member#: 14379
2005 GT30R STI
white, 360/360 @ 20PSI
Arrow Basslink owners MUST read! ....
If you have a Basslink (or any amplifier for that matter) hooked up to the stock headunit via tapping into the speaker wiring, do yourself a favor and buy a LOC from www.davidnavone.com ... I can't even explain how much of a difference this one little piece makes. Trust me you won't be disappointed ... I got the 4-speaker version so I can add an amp later, but if you dont need that the 2-speaker version should work just fine ... make sure to get the adjustable one, it comes in handy ... almost like a remote gain control for your sub.
Heres a couple threads with pics of the acutal unit, and the rest of my setup as well..
http://forums.nasioc.com/forums/show...hreadid=353273
http://forums.nasioc.com/forums/show...hreadid=353279
Cheers!!
Dave
wayoutwest is offline   Reply With Quote
Old 04-29-2003, 09:33 AM   #2
coreybyrnes
Member#: 35776
2004 forester XS
black
i am actually looking into buying the infinity basslink to put in the rear of my 2003 forester. i bought the OEM sub/amp but it sucks so i wanna upgrade but save space. does the basslink put out pretty well? i was just gonna unplug the sub/amp that i have now underneath the seat and use those wires to run to the basslink. is that an ok setup or do i need this converter thing?
coreybyrnes is offline   Reply With Quote
Old 04-29-2003, 01:25 PM   #3
wayoutwest
Member#: 14379
2005 GT30R STI
Its not that easy You actually can't use any of the wires from the factory sub at all.
You have to run power wire from the battery thru the firewall and back the driver side .... hook up the LOC into the back of the deck, then run your RCA down the passenger side .... it took me maybe 2-3 hours, but if i had to do it again, maybe 1-1.5 hours ...
Its pretty easy, just takes time to do it right. As for the output, it can pretty much shake the whole car, ... no complaints there.... unless you are a bass fanatic I doubt you will be left unsatisfied.
hth,
Dave
Old 04-30-2003, 02:03 AM   #4
edkwon
Member#: 453
2013 VT
Installing the Basslink is about as involved as installing a separate amp/sub combination, except the placement is more simplified. I spent about 4 hrs with my friends tearing apart my dash, center console to route my power, remote control, RCA line outs, green poweron wire that'll activae the basslink when the car is started.
Even tho i installed the same unit in my older RS, it wasn't any faster of a job because i wanted to change my approach make the installtion more clean without any obvious wires.
Ed
edkwon is offline   Reply With Quote
Old 10-06-2003, 01:08 AM   #5
superhawk44
Member#: 20264
05 LGT arrestmered
07 Aprilia Tuono
bump
superhawk44 is offline   Reply With Quote
Old 10-28-2003, 04:58 PM   #6
03WRXMA
Member#: 35081
2012 WRX
Ed
What did you tap the green power on wire into?
-Thanks
03WRXMA is offline   Reply With Quote
Attention all Cobb stage 2.5 owners, must read! scooby1220 Factory 2.0L Turbo Powertrain 3 01-29-2007 11:58 PM
wrb owners must read/FS 02 wrb sti parts vtimpreza NESIC Private Classifieds 2 01-25-2006 08:50 PM
Mn Wrx Owners Must Read!!! eebrains Mid West Subaru Owners Club Forum -- MWSOC 16 10-28-2004 05:17 AM
Attention Outback Owners! You MUST read this thread! d4d4d4d4 Outback Forum 0 08-25-2003 03:53 PM
wrx owners a must read thread!!! kwrx Factory 2.0L Turbo Powertrain 3 12-14-2002 06:09 PM
Message Board Statistics All times are GMT -4. The time now is 08:55 PM.
