Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 04-29-2003, 05:51 AM   #1
WRXTuner
Vendor
Vendor Sales Rating: (0)
Member#: 17778
WR Bluw
Default Fix all your CEL's for $30!
You have an up-pipe or down-pipe cel?
We have the fix $30 and they are both yours
This is for the 02/03 WRX only at the moment and the up-pipe fix will work on the 04
Individually they are $10 for up-pipe and $20 for the down-pipe.
PayPal us at Sale@WRXTuner.com or call us and place your order 1-866-WRXTuner
We look forward to speaking with all of you
www.WRXTuner.com
WRXTuner is offline
Old 04-30-2003, 02:46 AM   #2
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Your telling me no one has a CEL?
I guess no one has a CEL they need to fix
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 05-21-2003, 05:29 PM   #3
Subiemax
Member Sales Rating: (15)
Member#: 30691
2013 FRS
RED
Default CEL's
Still selling a fix for both for $30.
Only link I can find is about street racing cops?
Subiemax is offline
Old 05-21-2003, 06:23 PM   #4
rexorama
Member Sales Rating: (1)
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Default Re: Your telling me no one has a CEL?
Nick
www.WRXTuner.com
Most up pipes and down pipes come with the resistor mods. Mine did and I wouldn't have bought it if it didn't.
rexorama is offline
Old 05-22-2003, 02:21 AM   #5
wolf8314
Member#: 9185
2012 Toyota Tundra
Default Re: Re: Your telling me no one has a CEL?
and then you'd be rcvng a repair order when your car failed emissions ........
wolf8314 is offline
Old 05-22-2003, 07:29 AM   #6
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Default Re: Re: Re: Your telling me no one has a CEL?
There isn't an emissions test (sniffer) here in NY. Only a visual check. But I have friends that inspect. So mind your own buisness. This thread isn't about will your car pass emissions, it's about CEL fixes.
rexorama is offline
Old 05-23-2003, 12:33 AM   #7
wolf8314
Member#: 9185
2012 Toyota Tundra
Default Re: Re: Re: Re: Your telling me no one has a CEL?
.............excuse me?
Ok for those that want to be educated....... Most states dont use the sniffer test on newer cars(Im sure New York has a sniffer test). They hook the car up to a OBD. This reads the cars ECU for codes. Certain codes will cause you to fail this test.....such as ........Removing CATS. Now some of you brillant kids are thinking "Well hey I'll just reset my ECU right before I go to the emissions testing center". Well this wont work. The OBD checks for readiness codes that are stored within the ECU. When you reset the ECU these codes are wiped out, and wont return until the car is drivin several miles(forget the exzact mileage needed). If the OBD doesnt see these readiness codes "You will fail". Now Kids this is why we have CEL fixes. The CEL fix will trick the ECU.................................So New York not having a sniffer has nothing to do with CEL fixes.
Your right your car isnt my business but you passing on false information and giving moronic advice to newbies .....is. Did you enjoy your flaming?
Wolfie
wolf8314 is offline
Old 05-23-2003, 01:59 AM   #8
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default In stock :)
You can just paypal us $30 to Sales@WRXTuner.com put in the notes what you want and we will ship it out.
Talk to you soon,
Nick
P.S. you can also call us directly 321-377-0841 and place an order over the phone with your credit card.
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 05-23-2003, 06:47 AM   #9
idiotsavnt
Member#: 19106
Default ??
Can you elaborate on what it is that you are selling? Is it just a resistor that needs to be soldered in or is it a plug in assembly?
Thanks
idiotsavnt is offline
Old 05-23-2003, 08:19 AM   #10
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Default Re: Re: Re: Re: Re: Your telling me no one has a CEL?
Wolfie
You post has nothing to do with anythng Ive said. All I stated previously is most people that have bought catless stuff already have CEL fixes. There was no discussion here about why we have them. And FYI, Upstate NY doesn't check you obdII either. They do a visual inspection only. NYC has there own rules.
Man I hate explaining things to you modern do E-Thugs. Nothing better to do but argue with people when all you do is assume your reading something your not.
rexorama is offline
Old 05-23-2003, 08:22 AM   #11
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
See, your the one who started flaming, not me buddy. Now go argue with your mom or something and stop wasting my time.
rexorama is offline
Old 05-23-2003, 11:34 AM   #12
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Re: ??
Thanks
Now to answer someone who actaully should have posted here, hint, hint (DROP IT ALREADY!!!)
The cell fix for the front will require nothing more then installing the resistor mod by plugging it into the harness. The rear O2 sensor will not need to be soldered it will need to be crimped on which is all included and ready for you to crimp, just snip the wires, strip them and crimp'em
I hope this helps,
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 05-23-2003, 12:09 PM   #13
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
i need a CEL fix for my rear sensor. went with a catless DP and i keep gettin the light. however i have an autometer a/f guage running off the rear 02 sensor. i know its kinda useless but i still want it to be functional. will installing this part from you affect this guage?
ZoomnWRX is offline
Old 05-23-2003, 02:01 PM   #14
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Answer :)
If you install the CEL fix after the sensor wiring for your A/F gauge you should be just fine so you would basically have this.
Ignore the periods I had to put them in to space it right.
...................____A/F wire ________to A/F gauge
Sensor -----<____Cel fix wire______to ECU
...................____A/F wire________to A/F gauge
Sensor____untouched_____to ECU
The light blue is the white wire
I hope this helps
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 05-23-2003, 02:41 PM   #15
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
sorta haha
the guage only taps off one wire on the ecu... i forgot what color i did it a long time ago.. but if i'm right it will go like this...
rear 02 sensor--->tap for a/f guage-->CEL fix (resistor i guess?) --> into ecu
is that right?
oh wait i think i got why you showed 2... one for the front and one for rear? heh. can you buy the rear only??
ZoomnWRX is offline
Old 05-23-2003, 03:16 PM   #16
tEkkGOD
Member#: 10110
what does it look like?
tEkkGOD is offline
Old 05-23-2003, 04:29 PM   #17
phat pat
Member#: 20655
2002 wrx
white
I need the fix for the rear sensor. How much for just that one? One more question with this fix do I have to have the o2 sensor in the down pipe. Reason I ask is I am building my own downpipe and need to know if I need to weld in the stock bung.
phat pat is offline
Old 05-23-2003, 07:28 PM   #18
rexorama
Member#: 25912
03 MBP Sedan
02 PSM Wagon
Default Re: Re: ??
www.WRXTuner.com
Sorry dude. no disrespect. At least ya got some free bumps out of it.
rexorama is offline
Old 05-23-2003, 07:55 PM   #19
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Rear O2 fix
I would have to say yes you need it since it only modifies the signal from the sensor not replace it. However, I have never tried myself so I can't say for sure , but to be on the safe side I would put it in.
The O2 fix is $20 shipped
Let me know,
Nick
__________________
Paypal:
Contact:
WRXTuner is offline
Old 05-23-2003, 10:54 PM   #20
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
so 20 bucks for an inline rear o2 CEL fix?
where do i send $$
ZoomnWRX is offline
Old 05-24-2003, 04:45 AM   #21
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Payment info...
where do i send $$
You can call us at 321-377-0841 and place your order over the phone or you can PayPal us at Sales@WRXTuner.com
Talk to you soon,
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 05-24-2003, 09:55 AM   #22
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
is shipping included in that 20?
ZoomnWRX is offline
Old 05-24-2003, 02:40 PM   #23
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Of course!
That it is
Nick
www.WRXTuner.com
__________________
Paypal:
Contact:
WRXTuner is offline
Old 05-24-2003, 10:00 PM   #24
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
20 bucks sent via paypal just now (the email addy will be obvious heh). thanks for answering my questions
ZoomnWRX is offline
Old 05-24-2003, 10:26 PM   #25
mkitchen
Member#: 33202
2003 WRX
Nick,
I've got a 545 and 420 CEL.
will your product fix these?
mkitchen is offline
It turns all your bad feelings into good feelings, its a nightmare!!! - CC Debt fixes Mud Pig Off-Topic 74 07-22-2009 10:19 AM
how to fix all those little hood paint chips without repaint? sick1.8t Car Care & Detailing 8 06-20-2005 08:59 AM
FS: Blitz Version one style BOV brand new in the box fix all Subaru Turbo Model JunGdb Private 'For Sale' Classifieds 0 04-12-2005 07:31 AM
Cel Fix All Years MrFeebs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-30-2003 07:42 PM
Come over if your bored! 3-30-03 saggioWRX North West Impreza Club Forum -- NWIC 15 03-31-2003 12:42 PM
