Old 04-29-2003, 02:00 PM   #1
chobits
Member#: 22489
Question fuel regulator
anyone has it?
do you think i need it to make my car smoother since i have 16 psi and unichip stage 1 because i feel sometimes the car won't get enough fuel when i hammer it
i have A/F ratio (i know it's not accurate) and it shows that i'm running LEAN when i hammer the car
thanks
chobits is offline   Reply With Quote
Old 04-30-2003, 08:25 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Is this on an aftermarket turbo setup? Can you give a little more details?
Most likely you do need more fuel. There's the right way to do it, and half arse way.
The right way would be get a larger fuel pump and then get a fuel regulator that will bypass enough fuel at idle to maintain the proper fuel pressure at idle.
Other way to do it would be to get a rising rate fuel pressure regulator. They come in different varieties, 2:1, 4:1, etc.
Depending on the setup, fuel pump, etc. a combo of both suggestions may be the best way to go.
Legacy777 is offline   Reply With Quote
Old 04-30-2003, 11:28 AM   #3
chobits
Member#: 22489
it's only stock turbo w/ unichip stage 1 and 16 psi mbc
what if i use S AFC to control my fuel?
Old 04-30-2003, 01:58 PM   #4
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
You may want to try the factory forced induction forums. no stock turbo's here.
Poppa smurf is offline   Reply With Quote
Old 04-30-2003, 03:03 PM   #5
Legacy777
Member#: 4800
Yeah.....the factory forced induction forums may be of more help.
What I said though...pretty much holds true......get a bigger fuel pump. It can make quite a difference.
Old 04-30-2003, 03:04 PM   #6
chobits
Member#: 22489
how much is the fuel pump?
Old 05-01-2003, 08:18 AM   #7
Legacy777
Member#: 4800
not really sure, there are different ones out there in different price ranges. Ask in the fact. forced induction forum and see who is running an upgraded pump, what it can flow, and how much it costs.
FS - So Cal: SX Fuel Regulator and Denso 290 LPH High Flow Fuel Pump (SOLD) CuscoSTI Engine/Power/Exhaust 1 05-11-2010 06:51 PM
WTB (RI) stock WRX top feed fuel rails and fuel regulator tro8 NESIC Private Classifieds 4 11-05-2009 06:59 PM
Need Fuel rail or fuel regulator vortectoy Private 'Wanted' Classifieds 0 05-04-2005 01:26 AM
SX Fuel regulator and perin fuel rails IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-19-2002 08:55 AM
Weapon R Fuel Regulator tt17ct Normally Aspirated Powertrain 6 05-14-2001 08:33 AM
