#1 |
Member#: 3149
Vehicle:01 V7 GC/R32 sky |
No more waiting!
I got back form lachute yesterday to complete the tuning on the new motor. It was a bit fo work to tune it and we did have fuel issues as well. The first thing we did when I got there was do some quick number changes on the lower powerband, then we changed the rev limit to 8,000rpm and took it for a spin. The car sounded amazing that high (around 7,000 rpm) but I had to stop b/c we were running very lean after that. So we installed a fuel pressure riser and that fixed the problem (as well as replaced two bad spark plug wires). So we went back out and we took a few pulls on the highway. The car makes a very very different sound after the stock redline and its not a gradual sound change, it changes sounds like it was on a switch to a higher note subaru sound, but a very good sound thats for sure (love it!). Im am shifting a 7,500 rpm for now because we couldnt really tell if it was worth staying in a gear up to 8,000 rpm, it diddnt have anough power near there from what we could tell but we think this is due to intake manifold restriction and lack of fuel b/c the unichip is maxxed out for adding fuel. The 1/4 mile track wil help me determine this. On the highway, we did a long pull in third up to 7,500 rpm and I looked at my speedometer and we were going 145 klm/hr (87 mph) in third which was pretty neat. But the car still has great low end tourque, but when you hit the gas at around 4,000 rpm it pulls all the way up to 7,500 rpm amazingly. Its a different car, but its still subaru in terms of how it drives. But after tuning with ben at lachute, we dicided that the engine could still be much faster with stand alone engine management, so Im selling my unichip and old zex kit locally. So the stand alone management will go in next week hopefully alog with the 9lb flywheel which I have, but it diddnt arrive on time for the engine install. The car will also make power up to 8,000 rpm (likley 8,500 if all goes well). The unichip is not up to this task, if I had known i was going to go this way I would have bought a stand alone in the first place, but I diddnt think Id go this far, so at the time unichip suited my needs percectly. We can squeese 20-30% more power out of the car with stand alone easily I was told, it will make a world of a difference. Anyway, i thought Id update you guys, feel free to ask questions! Dan ![]() ![]() ![]() PS: Mod list can be posted if anyone is curious.
#2 |
Member#: 7267
BAIC
Vehicle:1994 Honda VFR RC-36 2002 Subaru 2.5RS |
DROOOOOL!!!!!!!!!!
I wanna win the lottery! xfrickx |
#3 |
Member#: 2958
NWIC
Vehicle:2001 WRX (GC8) |
Yes... please please post what you have done.
Have you done any actual dyno pulls or are you just tuning on the street? J |
#4 |
Member#: 16803
International
Videos, dammit!
![]() -Matt |
#5 |
Member#: 232
Vehicle:99 RS-T RIP 02 Forster-S |
Dan, 2 words... extrude hone
you're likely at the intake manifold's limit, port that sucker. Good job so far though! |
#6 |
Member#: 3149
Heres the mods, and i am going to the 1/4 mile track this weekend on saturday, so that should be fun. I have no clue what it will run, but its going to be a comparison run for when i go stand alone management soon.
We tuned it on the street/highway and lachute is booking me for a dyno tuning session as soon as it opens here in montreal. Il post everything too. my buddy has a digi cam so he will do some vids for everyone. I cant describe the sound it makes! strommung cat back 2.25" random tech high flow cat borla headers cobb cai UD pulley Closed deck block lightend/balanced/knife edged crankshaft custom billet con rods from Oliver custom 11:1 compression pistons from CP (coated for future nitrous use) Bored out to 2.55+ litres (torque plate boring) custom ported and poished cylinder heads Cobb racer camshafts ported/port matched intake manifold Cobb springs Cobb retainers custom made stainless valves (3 angle valve job) fully blurprinted fully balanced Tuned with Unichip Redline set at 8,000rpm 9lb flywheel (14 lb flywheel right now, the 9lb came too late) ACT clutch STi engine mounts STi tranny mounts ARP Head studs...not bolts anymore. Upgraded fuel pump Fuel pressure riser So, we will see what can be squeezed out the car with the stand alone (definitly more power and more inportantly...safety), but right now Im still getting used to it...100klm/hr in 2nd is different for me. Id give everyone a ride if I could! Dan ![]() |
#7 |
Member#: 3149
BOY- I did get the intake manifold ported out, but it still not so great, Tattoo Collector is working on a manifold for his car and eventually mine. That will be neat if everything goes well, that isnt an easy job.
Thanks guys! Dan |
#8 |
Member#: 232
Dan, retracting my previous suggestion
.Have you thought about injectors? also, ditch the 2.25" exhaust for a 2.5" (you're one of the few RSs that NEEDS it) also, consider ditching the Borla for an MRT or brullen (or have a header built like I did). |
#9 |
Member#: 19313
South East
Vehicle:2007 Scion tC Black Sand Pearl |
WOW!!! That sounds like one amazing piece of machinery you have there. Congrats.
#10 |
Member#: 23472
Vehicle:2004 STi Silver |
dcoty
If you are ever passing though Kingston on your way to Toronto or something let me know I would love to see your car man. |
#11 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
How much was the tunning @ lachute?
-paK +1 |
#12 |
Member#: 7022
Vehicle:2013 BRZ Limited SWP |
yay! so you are going with engine management
good to hear that. Now you can also get bigger injectors and fuel that puppy! congrats! |
#13 |
Member#: 3149
BOY- I like the 2.5" suggestion, I think i might need it I suppose (especially to really get the high end gains). As for the headers, i love the sound of my borlas, but then again, if Ive gone this far, why would I intentionally sacrifice hp becuase I like the sound of the headers...Ill eventually get a set of equal lenghts, btu Ill miss the sound!
Pakin- Tuning is 56$/hr, if you are a member of the montreal subaru club...you get 10% off. Its worth every penny for ben tuning the car, very worth it. Doctor Nick- Ben has WRX fuel injectors on his supercharged RS and he has unichip for tuning, the only problem is he is running super rich at idle, he's removing close to the max you can with the unichip. We are going to see if the stand alone will fix the issue, if not...in go the WRX injectors and we'll compensate. Thanks for the replies guys, its nice to know people care! We'll show them the power of N/A Dan ![]() Im nervous about the 1/4 mile though, I want good times so badly!!! |
#14 | |
Member#: 17315
International
Thanks in advance. -paK +1 |
#15 |
Member#: 3149
Funny money it is.
Lucky you for the exchange rate! |
#16 |
Member#: 20444
Vehicle:2006 Outback 2.5 XT Garnet Red Pearl 5MT |
Must...
have..... numbers!!!!!!!!! Whenever you get the chance to do a G-tech run or dyno your N/A behemoth, post the results ASAP. I'm interested to see how it turns out. |
#17 |
Member#: 3149
Well, if everythign goes well, im going to the track this saturday, Im nervous, i want to get good times, but even if i dont, the new mangement sure will improve them!
Dan ![]() |
#18 |
Member#: 11786
Vehicle:02 TS Black on White |
You HAVE to get a video! I need to hear this! I was wanting to run mine to 7000-7500 when I went turbo.
#19 |
Member#: 2272
BAIC
Vehicle:95 L AWD LIFTED!!! 1970 Subaru FF-1 Coupe |
Im thinking custom intake manifold + TWE headers, 2.5" high flow cat with a 2.5" catback would add a bit more power at the high end
#20 |
Member#: 2462
SCIC
Vehicle:2012 Volvo S60 T5 2005 Triumph Sprint ST |
Danny boy, I sent ya a PM. Make sure you call me if you go draggin this weekend! I wanna come see THE BEAST!
And I'll race your ass on the strip .....and get my ass blown away! ![]() |
#21 |
Member#: 18074
Vehicle:2008 Speed3 Black |
Damn, dude, glad she's up and running. It's been fun to keep up with this car. I can't imagine the cash-ola that's gone into that engine.
How streetable is she with all of this done? |
#22 |
Member#: 3149
The car is extremely streetable. Still has low end torque for driving around, the clutch dosent bother me, but Ill tell you how it is with the 9lb flywheel, it shouldnt be too bad. the only downside is findign 94 octane in areas im not familiar with.
Goose! Sure thing man, I might have to work on saturday, so i hope napierville is open class time trials on sunday! Dan ![]() |
#23 |
Member#: 2462
SCIC
ok man! lemme know. I wanna see if I can beat my 15.3 I got a few years ago
#24 |
Member#: 19364
Vehicle:1998 Impreza RS Black Mica Pearl |
Well Dan, thanks for the fire. Once I get done with the 1950 Ford Coupe and the 455 olds motor that I have to do, the Subaru is getting my full attention. I think I will have the intake manifold all welded up for some prelim. flow numbers by the middle or end of next week. Have you heard anything on an ECU and wiring harness? I am still looking for those 2 things so I can run my engine on the dyno. Also, tell Ben I am going to need to call him and bug him about some stuff that he did with your car. I need to know if I should go with a bigger fuel pump or a fuel pressure riser or something else along with the unichip. I'll keep you posted on everything. You have intake manifold #2 once I get mine on my car and functioning properly. Keep in touch. Congrats on the car.
Nathan |
#25 |
Member#: 13745
RMIC
Vehicle:2004 STI Silver |
Yeah, you should get the TWE Header, run catless, and get a Brullen 2.5" catback. Personally, I'm glad I got the Borlas, my car received a pretty good kick in the ass after I removed the cat after I installed the header.
| Thread Tools | |
| Display Modes | |
| How to make a stock 2.5L rev to 8,000 RPM | DasWRX | Newbies & FAQs | 9 | 10-25-2009 11:53 AM |
| My N/A 1/4 mile time no nitrous (11:1 comp 8,000 rpm redline)! | dcoty | Proven Power Bragging | 90 | 10-01-2004 12:46 AM |
| 8,000+rpm!!! | Akarui | Normally Aspirated Powertrain | 40 | 08-13-2004 12:55 PM |
| 8,000 RPM in a WRX | WRXThis | Factory 2.0L Turbo Powertrain | 13 | 06-19-2002 11:31 PM |
| 8,000+ rpm = Bulletproof engine or Fragged motor soon to be? | ImprezaRS dot com | Normally Aspirated Powertrain | 23 | 12-22-2000 12:06 AM |
