Old 04-29-2003, 07:33 PM   #1
scoobydrew06
Member#: 32951
Question Legacy multispoke fit on Impreza LS?
Just wondering if the Legacy multispokes will fit on a 93 impreza LS...and also if the stock tires on the legacy will fit nicely in the wheel wells or if i'll have to purchase new tires.
-thanx
scoobydrew06 is offline   Reply With Quote
Old 04-30-2003, 08:41 AM   #2
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Yup, the wheels will fit just fine. Tires are another matter, however. I'm guessing that the OEM tire size for the Legacy is something more like 215/60/16? The tires currently on the wheels *may* be a bit too big for your Impreza.
However, if you're on the stock suspension, then you probably won't rub, it'll just throw your speedo off a little bit.
- Trent
peepshow is offline   Reply With Quote
Old 04-30-2003, 12:00 PM   #3
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
I believe the overall size of the wheel and tire combo should be comparable. Legacies w/ 16" use the exact same tire as WRX's w/ 16" I think it's 205/50R16.
If your Impreza has 15's...then the tire is going to be taller...but it should all be the same in the end.
maciek
maciek is offline   Reply With Quote
Old 04-30-2003, 01:06 PM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
The stock Legacy tire(on that rim) like the WRX is 205/55-16. It will be taller than the stock tire on that Impreza, but will likely work with minimal or no rubbing.
I put WRX wheels on my BF and they were ~3/4" taller than the stock tires and had no probs.
ss
subysouth is offline   Reply With Quote
will 99-01 speedo fit on 94 Ls IlikeTofu Newbies & FAQs 0 08-05-2006 11:30 PM
Will Legacy mirrors fit my Impreza? t3hWIT Interior & Exterior Modification 4 03-15-2006 02:38 PM
WRX axleback: Fit on '95 LS? Siper2 Legacy Forum 2 07-31-2004 12:36 AM
'00 RS exhaust axleback: Fit on '95 LS? Siper2 Legacy Forum 4 06-21-2004 10:27 AM
Will Legacy seats fit an Impreza? Buzz General Forum Archive 0 12-30-2000 08:33 AM
