#1 |
Member#: 28968
SCIC
Vehicle:1997 BG Outback Ltd black riding on MR. |
I was just wondering if people might want to start a thread, listing all the current and future planned mods on their OBs? Just so people can see what's been done, what can be done, get some inspiration, or just drool.
![]() You should include: Year and exact model (e.g. '97 Limited) Current Mods (cosmetic and performance) Planned Mods (cosmetic and performance) I'll start it off: Year and Model: 1997 Outback Limited, 5MT Current Mods (as of 11/18/05): Engine/Power/Brake Mods K&N Air Filter snorkusectomy Perrin lightened pulley Cryoslot rotors Hawk HPS pads Goodridge SS Brake Lines (WRX lines) Drivetrain/Handling Mods Kartboy short shifter and bushings Momo F16 shift knob Group-N hardened tranny mount Group-N pitch stop mount Redline Heavy Shockproof gear oil (okay it's not really a mod, but it's not stock!) Megan Racing coilovers (for '02 WRX) Whiteline rear endlinks (the old-school "clunkers", not the nice new ones) Prodrive P1s, with 235/45/17 Pirelli Nero rubber 16" WRX stockers with RE-92s (my "winter" tires) Electrical/Cosmetic Mods Sylvania Silverstars (the ones everybody talks about) OEM subwoofer WRX Head Unit Optima Yellowtop battery grounding kit that I paid too much for. ![]() Window tints (scratched up of course) bumper scratches falling object dents (dumb trees) annoying loose heatshield rattle (sort-of fixed by Steve at Suby Specialties!) [11/18/05 Edit: Finally updated the list... modding is addicting! ]
#2 |
Member#: 27261
NWIC
Vehicle:1999 www.prjct1.com I'm Ron Burgundy? |
Year and Model:
1999 Legacy Outback Limited, 4EAT Mods(current): 5% limo tint on back 3 windows 35% on front 4 windows Debadged 4 point grounding mod snorkusectomy K&N panel filter Whiteline front and rear strut tower braces alpine CDA-7892 CD receiver Alpine Type S 6.5'' door speakers Xtant 1001D sub amplifier 1- 15'' Kicker Comp VR subwoofer Optima Battery Corbeau TRS wide Drivers seat Corbeau double release 3 point Harness Painted interior trim flat black tinted rear tailights DEI alarm system Monster Cable stereo cable Hella 500 driving lights in stock location Piaa Xtreme headlights (safe for Subaru harness) 18 inch Centerline RPM wheels Powdercoated flat black Autometer air-fuel ratio guage Autometer Voltage Guage Dual guage piller pod for the Impreza or CRX (they both fit) Hella supertones horns Planned; Flowmaster 40 series muffler w/ custom 2.5'' exhaust Borla Gen 4 header DBA rotors (front) SS brake lines EBC pads Cams Lightened crank pulley (Perrin) whiteline 22 mm front swaybar 24 mm rear Perrin Endlinks and Mounts Legacy GT suspension Swap MRT strut top hats KYB GR2 struts A-pexi S-AFC Automter Trans temp guage And thats pretty much it Keep posting Russell Last edited by Russell Rogers; 06-24-2003 at 01:05 PM. |
#3 |
Member#: 15135
NWIC
Vehicle:95 GF WRX Black |
My car:1997 Outback 5 Speed
a pic and the mod list below... http://forums.nasioc.com/forums/show...hreadid=354143 ![]() |
#4 |
Member#: 30754
NESIC
'98 Outback Ltd. 5MT
Mods (current): Blown headgasket (again) Mods (planned): New headgasket ![]() |
#5 |
Member#: 4615
BAIC
Vehicle:05 STi, 97 Leg OB |
Mod list:
Interior/Exterior Momo Daytona Carbon, 350mm, on Dai Kei hub Working Cruise Control (don't ask, PITA) Brushed aluminum gauge surround JDM WRX E-brake, leather w/ red stitching Tint, rears 5%, driver and passenger 50%. Hella 500 clear fogs, PIAA 100w ion plasma bulbs, Hella clear covers JDM amber sidemarkers JDM BG rear lights Zerosports replica mesh grill Morette headlights (Hella projector low beams, Hella driving pattern highs) Yakima Doublecross towers Tein BG hood struts Zerosports replica radiator shroud Audio/Electronics Pioneer Premier DEH-P8MP (F) 6.5 inch 3-way coaxials (need to install my Premier components) (R) 6.5 inch 3-way coaxials Alpine MRV100m mono sub amp, mounted under rear load floor Kicker Solobaric 10" in fiberglass box iPod integrated through changer input Hella Supertones Valentine 1 (hardwired) Suspension/Brakes: Tein Flex coilovers, 04 STi fitment Whiteline Race ALK Whiteline 22mm front sway bar Whiteline rear swaybar links (18mm bar) Whiteline rear strut tower bar w/ QR's (F) Stoptech ST-40 calipers on 328mm slotted rotors, Axxis Ultimate pads (R) Axxis Ultimate pads, Power Slot rotors. ATE Blue fluid 17x7.5, ET48 Rota Actions, Bronze 225/45/17 Bridgestone RE070's 17x7.5, ET48 Rota SDR's, flat black 225/45/17 Pirelli P-Zero Nero M+S's. Power (ha!): Port/polished heads Borla SS headers Apex'i N1 2.5 inch header-back w/ hi-flo cat. Lots of other little things that aren't important ![]() Figured it was time for a slight update..... Last edited by sybir; 11-29-2005 at 01:20 AM. |
#6 |
Member#: 28968
SCIC
Just thought I'd bump this thread to the top again.
Keep posting, I'm sure there're more people out there with modded OBs, right??And what's this 4 point ground mod about? I'm curious... |
#7 |
Member#: 4615
BAIC
basically, the stock subaru chassis ground is *really* poor.
Enough so that you get hesitation, light dimming during normal situations, etc. By grounding points on the car to the negative battery terminal. you can utilize the superior ground fo that cable to eartht he car more completely. The intake manifold seems to make the most difference, before/after; I just got a bunch of ring terminals, and bolted them in under the brackets that hold the sparkplug wires (did one on each side of the manifold, not that it makes much difference; I put one on one of the factory ground points on the left shock tower, and one to another ground point I can't recall right now Got rid of mid-RPM hesitation '(which had become more apparent after an intake), my lights are brighter, and the car turns over quicker; this on a car with 130k miles on it, so some of it may have helped with degraded systems. |
#8 | |
Member#: 31962
Vehicle:2005 Legacy GT Wagon |
sorry if this sounds ignorant... but would static electricity be another sympton of the poor grounding? i notice i always have a small static electric shock after driving my car, getting out, and touching something metal (like a mail box). i am just curious if that is typical of other Subys or maybe just mine. i never had that issue in my previous Audi's that I owned, but i did have that in an old '90 Toyota Corrolla. Do you think the grounding mod would help this "feature"? |
#9 |
Member#: 30874
Vehicle:0897 OUTBACKS and 2003 TS wagon |
What kind of seats do you have?
Just curious, because I don't have the static problem in my OB (leather) but do in the TS (cloth). I think it would be static from the seat materials, not any grounding issue. Any other ideas? |
#10 | |
Member#: 31962
now that you mention it, my Subie does have cloth seats. my old Toyota also had cloth seats too. my Audi S4 and my Audi A4 both had leather seats and no static issues.... i definitely see a trend here.... i just never thought about that. |
#11 |
Member#: 4615
BAIC
Yeah, I've got leather, so I couldn't say whether it helped. Some WRX guys have reported that it does reduce/eliminate the effect, however......
#12 |
Member#: 15135
NWIC
Regardless of your seats (cloth, leather, or heated), the stock grounds are weak.
I did notice on an '03 Outback the grounds look much better, perhaps due to all of the input they have recieved... ![]() |
#13 |
Member#: 28968
SCIC
Paisan (hope you read this),
Maybe if someone posted how to do the grounding mod, you could make it a sticky? Just a suggestion. I know I sure want to know how to do one now!! |
#14 |
Member#: 27261
NWIC
I am busy tonight but I will post directions on doing this tommorrow night. It is a very easy mod. once you have all of the materials it takes about an hour to do. It works too
Russell |
#15 |
Member#: 28968
SCIC
Just thought I'd bump this to the top, since I've had my brakes upgraded, and changed some other future upgrade plans... Opie, any chance you might want to sticky this, as a constant reference? I'm thinking that other OB owners who're planning on mods can check it, see who's done what, and find out more from those guys specifically.
kmin. |
#16 |
Member#: 5211
Vehicle:1997 Legacy Outback Spruce Pearl green |
Year and Model:
1997 Outback, 5MT Current Mods: K&N Air Filter Graham Goode short shifter and Cusco bushings Leather Subaru shifter knob Tinted windows Whiteline adj. rear swaybar Whiteline end links F and R Snorkusektomy (partial, pulls air from fendwell but kept all resonators) 2.25" catback with big resonator and Superturbo muffler and 3" unbaffled stainless tip Yakima crossbars, fairing and bike trays Impreza RS wheels ('01? The 6 spoke version...) 205/55-16 RE92s (came on wheels) Planned Mods: Install Metalmaster brake pads that have been lying around forever... Install Sony CD headunit and speakers that have been lying around forever... replace struts (wait for OB GR2s or lower and go with AGXs?) Subaru engine guard Replace rear swaybar bushings ( one is torn up) Replace headlight harness and get brighter bulbs? |
#17 |
Member#: 27261
NWIC
up we go. bump
I did more so I edited my post Russell |
#18 |
Member#: 27261
NWIC
woohoo and we're up at the top.
I modified my stock grill. I'll get some pics up as soon as it gets back from paint. Russell |
#19 |
Member#: 38460
Vehicle:2005 Liberty 3.0R B Obsidian Black |
List of mods for my Outback H6 (I'm in Australia). Colour is pearl white monotone:
17x7" rims with 235/50 tires DBA slotted front rotors tinted windows rear sway bar grounding mod ![]() |
#20 |
Member#: 20381
Vehicle:11 Ford Fiesta Silver |
97 Legacy OB / 5Spd.
Current: -Borla Headers -Custom cat-back -K&N replacement filter -COBB short shifter -STi tranny mount -Sylvania Silverstar headlights -Nitto 470 -Brembo sloted rotors -COBB Pads Planned: -Syms rear strut bar -Rear sway bar(dont know which one yet) -WRX rims and some new tires |
#21 |
Member#: 41022
98 Outback Sport (Black)
Current Mods:
In Progress:
Planned:
of course, first thing I need to fix my transmission woes ![]() |
#22 |
Member#: 38400
Vehicle:2004 WRX Wagon DRZ400SM |
White 1999 Legacy Outback Wagon Limited 2.5l/DOHC/4EAT
Modifications (Installed) Rallitek Intake KYB GR2 struts Ground Control Coilovers w/ Eibach Springs (340 lb/ft front, 250 lb/ft rear) Front and Rear Cusco strut tower braces 19-21mm adjustable Cusco rear sway bar (at 21mm) Toyo Proxes RA-1 tires (205/55/16) on 16" OEM WRX wheels Hella FF300 Driving Lights Hardwired Escot Passport 8500 Escort Passport G-Timer GT1 Perrin Lightweight Crankshaft Pulley Modifications (Waiting to be Installed) MRT Exhaust System (header/cat/catback) Yokohama AVS-ES100 tires (205/55/16) Planned Modifications TWE or Cobb Tuning Cams ProECM Chip |
#23 |
Member#: 71034
Vehicle:2001 Outback Ltd. Sedan - White |
wanted to bump this just to see what else you all had/have.
2001 Subaru Outback Ltd. Sedan AT "Mods" 50% Tint JL Audio 12" w3 JL Audio 250/1 Amp Dynamat Trunk 3" A'PEXi Muffler (gotta get rid of this and get a catback) Planned Pioneer DEH-P7600MP Headunit? Cobb Tuning CAI? 17" Limited Type 359 Wheels? OR just get a 02' WRX....? =\ what about the rest of you guys? |
#24 |
Member#: 63399
Vehicle:1998 Land Cruiser TD Black |
2002 Legacy Outback Ltd Wagon
Modification: Borla header Stromung cat, mid pipe and exhaust Blitz nur-spec exhaust KYB GR2 H&R sport springs Whiteline adjstable rear stabilizer H1 HID Window tint Jensen DVD player Subwoofer and amplifier 18 inch excel RS-GT wheels 225/45/18 Fuzion tires Chargespeed front bumper ![]() Last edited by project lancaster; 11-29-2005 at 02:53 AM. |
#25 |
Member#: 64060
NWIC
Vehicle:98 lifted FOZ M/Ts glacier white |
I guess I'm one of the few offroad fans out there. Here's my mods on my
'03 Legacy Outback wagon EXTERIOR: Mudrat designs offroad front bumper w/DOT reflective strips Primitive front skid/bashplate custom Factory diff guard PIAA 520's fogs Hella FF75 driving lights wired in factory fog light switch Sylvania silverstars hi /lo beam '03 Legacy grille custom painted goshawk black 35% window tint side windows/hatch windshield top 6" tinted Clear bra Rear dust deflector custom cut front splash guards DRIVETRAIN/SUSPENSION/CHASSIS/BRAKES: Valvoline 75-90w syn front/rear diffs. Rear LSD WRX 16" wheels BFG Traction ta's 225/60/R16 street Konig 10 15" wheels 40mm offset w/Yokohama Geolander AT+II's 215/75R15 (offroad setup) King springs lifted 2" ksfr-32, ksrr-29 IPD front/rear 22mm swaybars Brakes-PBR Metal masters custom ground front calipers(painted black) 1/4" to clear 15" wheels Valvoline syn DOT 4 brake fluid ENGINE: EJ25 SOHC 2.5l N/A Perfect Power SMT6 (piggyback ecu) Paranoid fabrications grounding kit Perrin crank pulley WR "secret weapon CAI" Borla header 2.25" catback w/Magnaflow muffler Valvoline full syn 5-30w TRANS: 4EAT auto Redline syn ATF INTERIOR: STI seatbelt pads(front) MB quart speakers factory tweeter kit modded w/MB Quart tweeter fit Pioneer 6cd changer Subaru all weather mats Subiesport/drive magazines in back of front seats mesh holder ACCESSORIES: Thule rack/fairing/cascade 1100 cargo box Rockymounts bike rack DIY cargo basket MUD!!! SNOW!!! SAND!!! DIRT!!! ![]() Last edited by outbackwbeer!; 01-04-2006 at 05:55 AM. |
| Thread Tools | |
| Display Modes | |
| A Years Worth of Mods... the official mod lists of 2008 and expected mods of 2009 | blackout801 | Member's Car Gallery | 37 | 01-05-2009 01:32 AM |
| 05 STi selling!! 37,000k nice list of aftermarket mods, moved and need to sell ASAP!! | subaruby | Private Vehicle 'For Sale' Classifieds | 13 | 03-22-2008 03:40 PM |
| Pics of my modded Legacy OB | whtlegacy | Legacy Forum | 10 | 08-22-2003 10:10 AM |
| Pics of my modded Legacy OB | whtlegacy | Outback Forum | 1 | 08-21-2003 02:28 AM |
| (Pics) got pix of my car finally +list of mods | bluesaint | General Forum Archive | 19 | 02-07-2001 05:30 AM |
