Old 04-30-2003, 02:36 AM   #1
HighTachPrez
Member#: 15247
99 2.5 RS
Default Sigh, may have to take apart 2.5 engine
I believe my head gasket has gone ka-put in my MY99 2.5 RS. Upon the process of fixing the problem... is there some reliability/performance mods that i should look into buying before we start working?? Hopefully this will be the only time i have to take apart the engine, so i might as well take advantage of the situation
Thanks
HighTachPrez is offline   Reply With Quote
Old 04-30-2003, 03:29 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
you could get cams while you are at it.
I changed the headgaskets in my '98. It's easier to pull the motor and really saves your back. Make sure you torque the head bolts properly, and use new gasket material on the valve covers.
rhdude is offline   Reply With Quote
Need some help on '04 2.0 going to 06-07 2.5 engine and tranny Samurai_jim Subaru Conversions 2 11-25-2008 02:12 PM
Do you have to check NA 2.5L engines oil level often? mgreen Normally Aspirated Powertrain 15 01-17-2008 01:56 AM
Next week it is going to take me 2.5 hours to travel 45 miles. Jimmy S. Off-Topic 11 03-06-2006 02:51 AM
Do I have to take apart my new tranny? Cavadini Transmission (AT/MT) & Driveline 0 12-11-2005 03:34 PM
How much oil does a 2.5 Engine take? PASS Service & Maintenance 12 05-16-2003 11:44 PM
