Old 04-30-2003, 11:40 AM   #1
MK2TMR2
Member#: 18501
1996 Eunos Roadster
R2-Limited
Default Drilling Carbon Fiber - what should I know?
I've done the research and decided that my new VIS Racing hood should probably have hood pins (hood locks, actually) since I see a lot of highway driving.
Is there anything I need to know before I drill this hood? Any special procedures, techniques, or things to look out for when drilling the CF?
Thanks.
MK2TMR2 is offline   Reply With Quote
Old 04-30-2003, 12:02 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
Place tape on both the top and bottom of the area you want to drill. This will help the CF from splintering around the hole.
Carefully drill the hole thru the bottom of the hood UP by gradually starting with smaller bits and working your way up to the overall size of the hood pin +1mm of clearance around. Its ok if you drill a little bigger, if you'll be installing the silver kickplates so the pin itself won't scratch the hood.
install the pins and adjust the height so that the pins create gentle pressure down on the hood.
thats all there is to it.
J
jeffg is offline   Reply With Quote
Old 04-30-2003, 12:12 PM   #3
MK2TMR2
Member#: 18501
1996 Eunos Roadster
R2-Limited
Much appreciated!
Old 04-30-2003, 01:01 PM   #4
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
And AVOID all contact with CF dust. Inhaling it is VERY bad and it's highly carcinogenic.
Undepelo is offline   Reply With Quote
Old 04-30-2003, 02:33 PM   #5
MK2TMR2
Member#: 18501
1996 Eunos Roadster
R2-Limited
That's good info. I'll pick up a mask or 2. Thanks!
Old 04-04-2007, 12:32 PM   #6
duece_bugeye
Member#: 133894
Lightbulb
Why do you drill up..? It seems like you would want to drill down. I am also lookiung for advice about to install pins on my Seibon tommrow! Thanks guys
duece_bugeye is offline   Reply With Quote
Old 04-04-2007, 12:37 PM   #7
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
I would do the tape thing but if you have a step bit I would use that. If your drilling a pretty big hole a step bit makes a very clean hole.
Johann
Bad Wagon is offline   Reply With Quote
Old 04-04-2007, 12:40 PM   #8
Member#: 67
1999 Outlasting
the competition.
put a block of wood to drill into.
Old 04-04-2007, 12:41 PM   #9
shemoves
Member#: 80663
2005 STi
seriously?
IBohno
shemoves is offline   Reply With Quote
Old 04-04-2007, 12:45 PM   #10
12sechatch
Member#: 132458
Okie Dokie Fine
carbon fiber will dull blades and drill bits VERY quickly so what you need if you are going to drill more than one hole is a carbide bit or even a diamond carbide bit.
12sechatch is offline   Reply With Quote
Old 04-04-2007, 12:47 PM   #11
12sechatch
Member#: 132458
Okie Dokie Fine
not necessarily....it is the resin that is carcinogenic and there are thousand upon thousands of different resins.
Old 04-04-2007, 12:57 PM   #12
shemoves
Member#: 80663
2005 STi
ahh...well let's hope they used the 'good stuff'
Old 04-04-2007, 02:02 PM   #13
wacerx
Member#: 96075
07 Schwinn
Candy green
its all about going slwo and starting with a very small drill bit and working up. i did this on my old carbon hood and it worked very well. do tape top and bottom of your drilling location and it wont splinter at all as long as you are slow about it. get the hole a bit larger than the pin being used and i recommend a dremel to clean up the edges when youre done.
wacerx is offline   Reply With Quote
Old 04-04-2007, 04:35 PM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
DO NOT touch the CF Splinters. They are a NIGHTMARE to get out. (Dont ask...just follow the advice)
Old 04-04-2007, 04:52 PM   #15
gotboost02
Member#: 83764
02 02 WRX/00 RS
yes the carbon dust is very bad for you ... and the splinters are just as bad ... i work with advanced composites daily, +1 on the block of wood ... wont be perfect but will be good enough
gotboost02 is online now   Reply With Quote
Old 04-04-2007, 08:31 PM   #16
STi-JDM
Top Scoob 023
Member#: 90373
05' STi. 89' GT-R
00' GT-R ; LCM x WFC
I always use tape when I have to drill and it works all the time
STi-JDM is offline   Reply With Quote
Old 04-04-2007, 08:57 PM   #17
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
how are you marking on the bottom of the hood where to drill? i have an idea but im not sure if its the best way to do it...
skate enjoi is offline   Reply With Quote
Old 04-04-2007, 09:02 PM   #18
wacerx
Member#: 96075
07 Schwinn
Candy green
make a small square of tape. stick it on the tip of the hood post. set the hood down onto it and it should leave the small square on the udnerside of the hood.
i cut a square of about 1" by 1" on the inside of the hood for the post to pass through. then i used my method of marking the hood so it was on the underside of the carbon and drilled a tiny pilot hole before drilling out from the top.
Old 04-04-2007, 09:02 PM   #19
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
I usually put lipstick (DONT STEAL YOUR GIRLFRIEND'S!) on the post you screw into the core support, close the hood on it, and drill from the bottom up with a tiny bit. Then working from the top, enlarge the hole and shift the hole if needed.
Old 04-04-2007, 09:38 PM   #20
Zypper
Member#: 5201
'02 WRX Wagon
'11 Versys 650
CF splinters are a lot like fiberglass splinters, if you get any wash your hands in as hot of water that you can stand with some mild detergent, it helps open up the pores, wipe on a paper towel or something disposable.
Zypper is offline   Reply With Quote
Old 04-05-2007, 08:20 AM   #21
skate enjoi
Member#: 120716
2002 psm ver7 wrx
yeah thats exactly what i was going to do, i was just making sure there wasnt a better way.. thanks
Old 04-05-2007, 10:24 AM   #22
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
it will itch you crazy
vwown3d is offline   Reply With Quote
Old 04-05-2007, 03:39 PM   #23
SubiFTW
Member#: 138728
MY06 2.5i Impreza
I honestly don't think hoodpins are necessary. If your hood utilizes the OEM latch then it should be fine. I've had mine on a month and ran as high as 140 km and no problems at all. No flex/bend/shake it stays on like it should.. It's really personal preference I think, seeing as how I've read some of the horror stories of peoples hoods flying up and smashing their windshields.
But good luck to you !
SubiFTW is offline   Reply With Quote
Old 04-08-2007, 06:23 PM   #24
Chas Metivier
Member#: 27504
2002 WRX sedan
WR blue
Use stepped drill bits designed for sheet metal. They are cone shaped and gradually increase in size starting at about 1/8 inch. I used these with my hood pin install and they where gentle on the carbon fiber as long as you go slow.
Chas Metivier is offline   Reply With Quote
Old 04-11-2007, 12:08 PM   #25
duece_bugeye
Member#: 133894
I would get pins.. especially if you are running an STi scoop. I have taken many rides is a friends wrx with an Sti scoop and you should see the flex that hood gets at anything over 60mph! even on the al. hood, which is stronger!
the hood looks like this ----> ~~~~~
Restore Carbon Fiber [What I did] Pics inside fearmywrx Car Care & Detailing 31 03-26-2010 09:53 PM
drill carbon fiber breadstick Interior & Exterior Modification 26 03-08-2009 08:28 PM
front bumper-added carbon fiber? what do u think binkman88 Interior & Exterior Modification 1 12-10-2007 04:27 PM
Drilling Carbon Fiber atmosphere Interior & Exterior Modification 27 08-25-2004 09:49 PM
