Old 04-30-2003, 01:07 PM   #1
nick robinson
Member#: 25959
02 WRX
Default reliablity of a WRX swap?
I am pretty darn close to doing a WRX swap into a 2.5rs. I am waiting to see if this one higher milage RS will be cheap enough (negoating price). I am goign to have LaChute do this swap. I am curious as the reliablity of this car. It will be my every day car, driving between Maine and New York a few times. I figure this car should be fully capable but Id like to hear from you guys. There are few of you with swaps so lets here what you have to say!
nick robinson is offline   Reply With Quote
Old 04-30-2003, 01:17 PM   #2
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Are you talking about a USDM WRX swap? Regardless, as with any used engine, you never know. However, there is no reason that the engine would be any less reliable in your car than in the car it came in.
Bottom line, not knowing what type of use/abuse the engine took in it's former body, expect it to be as reliable as any used car (engine only, in this case) you've ever bought with the same mileage.
Lachute does great work. You'll be pleased. Good luck.
- Trent
peepshow is offline   Reply With Quote
Old 04-30-2003, 02:10 PM   #3
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
The reliability depends on how good your donor parts are.
There have been NO issues with any of the ten USDM conversions we have completed. Well, actually the one issue that all the conversion people tend to have is ...boost itch. Meaning, once they go turbo, it isn't too long before they want more boost
Good luck
chris
Crawford/I-Speed is offline   Reply With Quote
Old 04-30-2003, 02:42 PM   #4
nick robinson
Member#: 25959
02 WRX
- Trent
Trent,
Did you have LaChute do a swap for you?
Old 05-01-2003, 08:30 AM   #5
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Yup, Lachute sourced the parts (they already had them in their garage when I called them to ask about doing a swap) and performed all the labor. At the time (Oct. '02), I think my car was about the 9th or 10th JDM swap they'd done. I'm sure they are well into the 20s now. Julien called me and let me listen to the car start-up and run just 3 DAYS after they started the work.
My experience was absolutely first rate. Feel free to ask me any questions you might have. Julien, Mark, Yves and co. are a fantastic bunch. I just wish Montreal was closer!!!
- Trent
Old 05-02-2003, 01:21 AM   #6
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Rallispec did my jdm EJ20 swap, and it gave me 20k miles of driving thrill before I made a mistake on one of my favorate sandy back roads and put it into a tree at 50 mph Fortunately I walked away unscathed, and the car only had $2500 of damage when all was said and done, but I sold it, and now its rippin' around in Tennessee with its new owner.
I'm in the process of doing another jdm EJ20 swap myself this time.
There is no reason you should have any less reliable a car for doing a swap. Its a great way to build quite the sleeper, and save on insurance costs, for one. Plus you'll inevitably end up with a far lighter car by doing the swap. My '94 Impreza swap was 2700 lbs after the swap. So that's 400 lbs lighter than a WRX. Its no wonder that the 325 hp went so far when it only had to pull 2700 lbs.
annointed is offline   Reply With Quote
Old 05-02-2003, 01:38 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Think about it this way, if you run the WRX engine at stock levels and the vehicle is Lighter than the WRX it should last longer if not equal right?
Old 05-13-2003, 07:31 PM   #8
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
QS Motorsports in CT did mine. its been in for almost a year now, with about 20,000 miles put on it. No problems except for a bad TPS sensor. Knock on wood.
Frank
luvmyrs is offline   Reply With Quote
Old 05-13-2003, 07:47 PM   #9
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
If you don't mind, How much is QS charging for labor, and how many have they done. You can pm me the info or email it if you prefer. Thanks.
Soon2Bgreat is offline   Reply With Quote
Old 05-13-2003, 08:38 PM   #10
luvmyrs
Member#: 1048
to POS thieves.
QS did mine a little under a year ago. Mine was the first that they had done. I dont know if they have done anymore, I know that they have a pretty hectic schedule over there building rally cars. All together it was about $2500.00 in labor.
Frank
Old 05-14-2003, 09:33 AM   #11
peepshow
Member#: 1777
2005 LGT
#92 FZippy
FWIW, that is almost the exact same total for labor that I got from Lachute. Lachute has done a TON of JDM swaps. I would guess probably 20+ at this point. When they did mine last September, I was no. 10 or 11.
If the price is the same, it comes down to who can more closely meet your schedule and who is closer to drive to!
- Trent
Old 05-15-2003, 12:13 AM   #12
Eggroll
Member#: 22737
What makes the WRX heavier? I was considering a '03 WRX but my friend suggested gettinng an RS and doing a turbo conversion since he has his stock WRX turbo that he'd give me for free. How strong is the 2.5 compared to the 2.0 engine?
Ed
Eggroll is offline   Reply With Quote
Old 05-19-2003, 09:23 AM   #13
bluimpreza00
Member#: 19094
2004 Forester XT
Red
I am trying to gather as much info as I can b/c Im wanting to do a US WRX swap or a JDM WRX swap as soon as I can save the money.
What are the negiative and positive aspects of a US vs. JDM WRX swaps?
Costs, Horsepower, availability, etc.
Im in Tennessee, how do I get ahold of Lachute to get the parts.
I have already talked to a Subaru mechanic and he said that he would do the swap on the side.
Matthew
bluimpreza00 is offline   Reply With Quote
Old 05-19-2003, 09:43 AM   #14
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
USDM WRX Pros:
Fewer miles on motor (in most cases)
OBD2 compilant
Easier to source replacement parts if necessary.
USDM WRX Motor Cons:
Less HP than JDM motors (in most cases)
Lose the "cool guy" JDM swap bragging rights.
JDM WRX Motor Pros:
More abundant (right now anyway)
More HP than USDM motors (in most cases)
JDM WRX Motor Cons:
Most motors not OBD2 compilant.
Many don't come w/ECU & wiring harnesses making the use of standalone EMS necessary.
More miles on motor (in many cases)
Click here for Lachute Subaru Talk to Mark in the motorsports department. Great guy and very willing to work things out for you.
The physical part of the swap is not a problem; it's the wiring that's the PITA.
Good luck.
-mykr.
mykrrrr is offline   Reply With Quote
Old 05-19-2003, 02:58 PM   #15
bluimpreza00
Member#: 19094
2004 Forester XT
Red
Thanks Mykrrrr
Alot of good info. When I get the money I will definatly get in touch with Lachute.
Any more info is greatly appriecated
I think Im going with the USDM WRX b/c it seems to be alot less of a pain and alot less hassle to get everything together.
Matthew
Old 05-19-2003, 03:26 PM   #16
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
actually i might beg to differ about the usdm being easier to gather everything. From what i've seen most usdm engine's for sale are engine (turbo, intercooler) and that's it. Sometimes they include a downpipe. You still need
-xmember, swaybar
-downpipe, rest of exhaust
-fuel pump
-fuel controller
-maf sensor and airbox
Usually if you get jdm engine's they come with downpipe and the maf sensor. So that makes a few less things to get. If you get a front clip then you get it all, sans fuel pump. But it's also more likely to be able to see if usdm engine is in good condition before you buy, and see it yourself, this is harder with jdm.
Old 05-19-2003, 03:44 PM   #17
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Yet another reason to go with a shop like Lachute or RalliSpec. You could probably source a front clip a *little* cheaper if you did it on your own, but these shops perform leak-down tests, etc. If you buy your swap parts from a reputable dealer, you cut down on the stress of worrying about mis-represented parts/mileage/condition/etc. by a huge amount. Something to think about.
- Trent
Old 05-20-2003, 09:24 AM   #18
mykrrrr
Member#: 733
'16 Fiesta ST
Good advice Trent.
When the time is right I'm still going with a place like Lachute because of all the extra stuff they'll do to the motor to assure it's road worthy and won't cause you problems after the install.
This is well worth the extra cost IMO.
-mykr.
reliability of a 1.8 to 2.5 swap sublime447 Subaru Conversions 10 03-25-2012 11:26 PM
reliability of 04 WRX?? DjBij099 Newbies & FAQs 16 06-02-2009 03:47 PM
Reliability of usdm wrx engine 012.5RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-03-2007 12:37 PM
Realistic Reliability of Used WRX? Jesse Jericho Newbies & FAQs 11 07-27-2006 01:26 AM
Any idea the cost of a WRX swap totalburnout Subaru Conversions 23 10-30-2004 03:14 PM
