Old 04-30-2003, 04:14 PM   #1
bbbwrx
Member#: 32734
Default KYB AGX adjustable struts for WRX?
Will the KYB AGX adjustable struts work on a WRX? I have heard they will and I have heard they won't so maybe some that has them on can say the do and if they are good on a WRX. No I thinks please.
BEN
bbbwrx is offline   Reply With Quote
Old 04-30-2003, 04:18 PM   #2
teiva-boy
Member#: 22825
They work if you have rear camber bolts installed at the same time.
teiva-boy is offline   Reply With Quote
Old 04-30-2003, 04:27 PM   #3
bbbwrx
Member#: 32734
Like the eibach rear camber bolts? Or others specifically designed for these?
Old 04-30-2003, 04:39 PM   #4
teiva-boy
Member#: 22825
I guess you could use those if they give you at least 1.5 degrees of adjustment or more.
Old 04-30-2003, 05:53 PM   #5
JonnySubaru
Member#: 17901
Get konis. You simply cut around the top of the OEM strut and take out the original guts, replacing them with the koni insert. I just put in the koni inserts in an extra set of OEM struts- They get the best reviews.
Unfortunately, they are $150 each.
JonnySubaru is offline   Reply With Quote
Old 04-30-2003, 10:39 PM   #6
teiva-boy
Member#: 22825
I find $150 per a steal. look at Koni's track record, very high quality.
Old 04-30-2003, 11:19 PM   #7
bbbwrx
Member#: 32734
cut a car with a warrenty no thanks!!!!!!!!!!!!
Old 04-30-2003, 11:24 PM   #8
Gonz
Member#: 18642
2005 Impreza WRX STi
KYB's = Replace orginal strut housing.
Koni's = Modify original strut housing.
Any effect on your warranty would be the same with either choice.
Gonz is offline   Reply With Quote
Old 05-01-2003, 12:12 AM   #9
bbbwrx
Member#: 32734
Nevermind I though you ment the tower on the car itself. Not just the original strut
Old 05-01-2003, 09:51 AM   #10
STX_REX
Member#: 25255
MBP (I washed It)
The other thing to keep in mind is that the GC-8 AGX's have the spring perch about a 1/2" lower on the strut body. Resulting in a 1/2" drop in rear of the car.
Late
STX_REX is offline   Reply With Quote
Old 05-01-2003, 10:24 AM   #11
bbbwrx
Member#: 32734
That is ok I will be able to adjust that on my coilovers. Thanks for the info though
BEN
Old 05-01-2003, 04:44 PM   #12
00GTS
Member#: 10738
2003 WRX Sedan
"That is ok I will be able to adjust that on my coilovers."
You will be able to adjust *preload* on your coilovers. This indirectly adjusts ride height. It also changes the shock stroke and puts the stroke at different damping points in the shock. Whether or not this will have an adverse effect I can't say since I haven't tried it on the WRX but just be aware of it.
This is why high end adjustable coilovers have both adjustable spring perches (for preload) and threaded bodies to adjust ride height.
-Josh
00GTS is offline   Reply With Quote
[For Sale] KYB AGX adjustable struts (93-07 Imprezas) Back Road Runner Suspension/Brakes/Handling 12 03-29-2009 03:40 PM
WRX KYB AGX Adjustable struts $275 yellowscooby Private 'For Sale' Classifieds 12 08-27-2005 11:11 AM
KYB AGX Adjustable Struts for WRX yellowscooby Private 'For Sale' Classifieds 10 07-22-2005 10:50 PM
KYB AGX Adjustable struts 2 wks old 1/2 price!!! TN Fastech Private 'For Sale' Classifieds 15 03-01-2004 08:22 PM
