Old 04-30-2003, 09:36 PM   #1
wrxin'
Member#: 15207
2005 STI
Crystal Grey Metallic
Default loosing boost any idea or is it normal
Well i just installed a header up-pipe downpipe and apexi gt cat back. i found a leak where the uppipe meets the header i corrected that tonight but im getting max boost .11 mpa until about 5800 rpm's then it drops off to about .07mpa by 6500 rpm's i also have a Turbo XS MBC. i never lost boost like this with the factory exhaust. it would hit .11 mpa and hold it all the way to 7k rpm.
Any idea's what might be my problem, i cannot hear any leaks at this point or is it the stock turbo just cannot hold boost with a catless exhaust??
Thanks for any help you can give me.
Kris
P.S. although it doesnt hold boost like before it still feels soooo much faster then before
wrxin' is offline   Reply With Quote
Old 05-01-2003, 09:34 AM   #2
wrxin'
Member#: 15207
2005 STI
Well last night i couldnt hear any leaks, but this morning going to work i hear a leak as i was getting into boost.....makeing a ticking noise almost and gets louder under more boost.......Is this the uppipe leak many talk about???
Old 05-01-2003, 12:55 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The stock turbo cannot hold that much boost for that long. It's normal.
mbiker97 is offline   Reply With Quote
Old 05-01-2003, 01:24 PM   #4
SlvWgnCO
Member#: 34686
My uppipe leak sounded high pitched. When the pipes are cool, spray some soapy water on any suspected leak points. Big bubbles = leak.
SlvWgnCO is offline   Reply With Quote
Old 05-01-2003, 06:50 PM   #5
wrxin'
Member#: 15207
2005 STI
Default okay, found the leak
Well i found the leak. its in the same place as before........where the up pipe meets the manifold. this is the second time ive had the leak here. anyone have any tips on installing this part of the job........i seem to be having trouble here.......the turbo part of the up pipe and downpipe are leak free.
thanks in advance
Kris
low boost in heat? or is it time to buy an '08? madsociety Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-22-2008 06:05 PM
The E30 rear battery, a great idea...or is it? (56k gets points from Luke) teh Phil Off-Topic 18 03-24-2008 02:46 PM
BOOST SPIKE FIXED! or is it? HELP! toekneeyo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 04-28-2006 08:51 PM
Slightly sputering with new mods. Any ideas, or is this normal? SolidSnake Newbies & FAQs 3 03-26-2006 09:58 AM
is it normal for the boost to spike a little bit vsboxerboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-05-2004 02:11 AM
