Old 04-30-2003, 11:24 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default General question about coilover camber plates
I just picked up my set of JIC FLTA-2s and I was trying to spin the top hats on the front struts and unlike the rubber tophat mounts on the stock struts or Sti top hats, i see no ball bearing assembly and the whole shaft wants to spin when i turn thetop hat. is this normal or will i have to worry about the coil sleeve wanting to spin with the struts, messing with the height every time i turn.
Looking at the pic of the front strut, when you turn the wheel, where along the axis the hell is the front strut supposed to spin?
Ed
edkwon is offline   Reply With Quote
Old 05-01-2003, 11:43 AM   #2
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
bump, where the heck are all the coilover ppl this morning?
Ed
Old 05-01-2003, 12:40 PM   #3
downeyer
Member#: 10784
Platinum Silver Metallic
Ed,
My Zero-2Rs had a ball joint at the top to rotate and turn the top hat during assembly. Not sure why these do not. I'm sure there's some method to the madness.
The way I adjust height is to loosen collar C and rotate the entire threaded shaft and strut with A or B (use A to lower, B to raise). The shaft rotates independantly of top that, lower mounting bracket, and spring.
We'll figure it out on Saturday or give me a call tonight.
-Eric
downeyer is offline   Reply With Quote
Old 05-01-2003, 02:39 PM   #4
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
I called JIC USA and they answered my questions. My front struts are supposed to spin along the damper shafts and thats how they're supposed to turn. I'll see ya on Saturday
Ed
Want to win in autox? 05 STi Ground Control Advance design coilovers/camber plates trhoppe Private 'For Sale' Classifieds 6 08-22-2005 09:12 AM
98-01 D2 Coilover! Camber Plate! NEW/USED Apoll_13 Private 'For Sale' Classifieds 6 03-25-2005 11:24 PM
Question about rear camber plates in 93-01 wagon stentorian Brakes, Steering & Suspension 0 02-23-2004 02:21 PM
Coilover camber plate removal? wlelandj Brakes, Steering & Suspension 2 07-23-2003 02:10 PM
JIC coilover Camber plate Qustion Davenow Brakes, Steering & Suspension 1 12-20-2002 09:45 AM
