Old 05-01-2003, 12:18 PM   #1
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default Is the Fuel pump controller necessary for WRX swap?
Hi, I am going to be swapping a 02 WRX engine into a 94L and am not sure if my wiring harness hass the fuel pump controller. I need to know if it is necessary to run the car, if not what are the side effects? could someone also show me a pic of one so that i can be sure whether or not I have one?
Thanks, Micah
Old 05-01-2003, 01:10 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes the 94 is too small
Old 05-01-2003, 01:16 PM   #3
Aspen
Member#: 145
Banned to
Housework for Summer
no not necessary, it will run without it.
side effects: might run rich in the lower ranges.
Aspen is offline   Reply With Quote
Old 05-03-2003, 11:00 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
could a rrfpr control this? or maybe a S-AFC? and what do you mean too small? I don't know what this is in reference to.
thanks, Micah
Old 05-03-2003, 01:08 PM   #5
Austin
Member#: 7089
2016 STi
The fuel pump controller is a small box, about the size of a deck of cards, physically located on the passenger side of the trunk behind the trunk liner, about 3" below the trunk lid.
Austin is offline   Reply With Quote
Old 05-06-2003, 03:18 PM   #6
subtnr
Member#: 36406
I would highly recommend using the WRX fuel pump controller.
Without getting too technical, the computer won't be able to calculate and deliver the right amount of fuel your engine needs to run RIGHT!
subtnr is offline   Reply With Quote
Old 05-07-2003, 12:27 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
how much does one cost? and could I see a picture of one? I may have it and don't know it.
Please help, Micah
Old 05-10-2003, 03:14 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
does anyone have a picture of one? I may have it and may not know it. Please help!!
Old 05-12-2003, 12:23 PM   #9
Aspen_2.5RS
Member#: 3310
Post
I need this information as well. Basically what it would cost new and if anyone has one laying around from a wreck.
Guess I'll call the dealer soon.
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 05-12-2003, 03:03 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
www.4subarusuzukikiaparts.com
www.car-part.com
www.copartfinder.com
I would highly recommend against buying directly from the dealer. It will be atleast 200% more than the cost at a yard. 4subaru will almost undoubtedly have it, but it will probably be priced higher than the other places.
-Jon
Old 05-12-2003, 07:37 PM   #11
Aspen_2.5RS
Member#: 3310
www.car-part.com
-Jon
Jon,
Thanks for the information. Yeah, I didn't plan on buying it from the dealership, I just wanted to find out what they charged so I could get an idea of what a reasonable cost would be for it.
Thanks again,
Cam
Old 05-13-2003, 04:22 PM   #12
Homemade WRX
Member#: 33782
96 bastard child
so does anyone have a picture of one or can give me a detailed discription or deminsions of the unit itself.
Thanks, Micah
Old 05-13-2003, 04:30 PM   #13
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I'll gladly take a picture of it once I have mine in hand. However, since my donor car hasn't been located yet, I can't give you a picture.
-Jon
Old 05-19-2003, 10:39 PM   #14
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Yes you need it...You will throw a check engine light if you don't have it...The controller talks to the ECU...I paid $120 for it from the local dealer...Its part of the WRX chassis harness and yes it bolts behind the passenger side trunk trim, in the hollow space...Its a little computer made by DENSO...
Zee
Sunrise City Rider is offline   Reply With Quote
Old 05-19-2003, 10:47 PM   #15
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Just something else to think about. Someone with a v7 swap into a gc didn't use a fuel pump controller, it's also needed for that, and supposedly the car runs great, although there is a check engine light. I can't imagine it's something that an aftermarket ecu couldn't fix. Anyway, personally i'd get one, after all if your spending all the money on the swap, what's another 120 just to be sure and for peace of mind. Good luck.
Soon2Bgreat is offline   Reply With Quote
Old 05-21-2003, 07:01 PM   #16
Homemade WRX
Member#: 33782
96 bastard child
yes I agree what's another 120 but that Denso tip may be helpful.
Thanks, Micah
Old 05-23-2003, 11:54 AM   #17
Imprezd
Member#: 3357
What's another $120, ... the problem is that little things like that end up being alot of money in the end . That's the whole deal with doing a swap it always cost more than what you think.
I'd figure gas mileage might suffer a bit if you don't use it. .due to the fact that hard wired it would be at full blast all the time.
Impezd~
Imprezd is offline   Reply With Quote
Old 05-23-2003, 01:12 PM   #18
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Just as a little FYI, here is a list of the "little" things that I have purchased thus far:
WRX rotors, calipers, pads, and brackets $200.00
AWD hubs $135.00
RS hood $185.94
RS front axles (pair) $90.00
RS rear axles, 05/2000+ (pair) $90.00
pedal assm. (with clutch master cyl.) $125.00
WRX wagon front control arms $130.00
Stock turbo-back exhaust $150.00
CM oil filter (25-282) $95.00
Steering rack bushings $24.00
The drivetrain isn't even here yet so I'm sure more will be added...
-Jon
Old 05-23-2003, 01:25 PM   #19
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Don't forget the $150 Rear 02 Sensor...
Zee
Old 05-23-2003, 01:31 PM   #20
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
That _should_ be included... ( I hope)
-Jon
Old 05-23-2003, 02:23 PM   #21
Homemade WRX
Member#: 33782
96 bastard child
dos anyone know of a sustitute system that can control the fuel? could a rrfpr or a S-AFC work?
Thanks, Micah
Old 05-23-2003, 02:44 PM   #22
Imprezd
Member#: 3357
just hard wire the Fuel Pump you should be fine.
Old 05-25-2003, 10:36 PM   #23
Mumbles
Member#: 248
Mumbles is offline   Reply With Quote
Old 07-14-2003, 10:57 AM   #24
Homemade WRX
Member#: 33782
96 bastard child
what is the part number off of the fuel pump controller so that I can look it up on one of the websites recommended.
Thanks, Micah
Old 07-14-2003, 11:28 AM   #25
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
so is the controller needed then? what if you use the wrx fuel pump and an SAFC?
scoobyimprza is offline   Reply With Quote
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
where is the fuel pump controller?? potsy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-30-2008 12:43 AM
Is the fuel pump screen for an '01 RS the same as a '93? EcksJay Subaru Conversions 3 10-08-2005 10:12 PM
need help with the fuel pump controler on my swap simprezl25 Subaru Conversions 1 09-01-2005 01:29 PM
Fuel Pump Controller Issue on WRX Swap Zephyr Normally Aspirated with bolt-on Forced Induction Powertrain 12 07-23-2003 10:21 AM
