Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 05-01-2003, 02:47 PM   #1
RA29
Member#: 30598
2000 Lancer Evo 6
Hot Pink
Default DCCD doesnt allow full 100% rear?
I thought i read somewhere that the DCCD system allows a full 100% rear wheel drive?
The magazines all say that DCCD allow only a max of 65% rear with 15% variance from the 50/50 split. But the earlier tech articles said that DCCD allows 100% to be moved to the front or rear.
Which is correct?
RA29 is offline
Old 05-01-2003, 02:48 PM   #2
ImprezaRSinCT
Member#: 1810
14 Acura TL w Tech
15 Honda CR-V EX
I have never seen the 100% stat, everything I've ever seen.heard was 35/65 max.
ImprezaRSinCT is offline
Old 05-01-2003, 03:01 PM   #3
Impreza01
Member#: 152
2002 Impreza WRX
RA29
The DCCD only does 35:65 max split. The only car to have the ability to do 100% front then rear is a Nissan Skyline GT-R R34.
Impreza01 is offline
Old 05-01-2003, 03:02 PM   #4
JDM nut
Member#: 34529
04' WRX STi
White/Silver
Ditto.
Normally the system operate at 35/65, can be switch to 50/50 by the computer in auto mode or can be manually switch to 50/50 by the user.
JDM nut is offline
Old 05-01-2003, 03:26 PM   #5
RA29
Member#: 30598
2000 Lancer Evo 6
Hot Pink
In the picture on this thread, it shows 100% front or rear?
http://www.scoobynet.co.uk/bbs/threa...=143750&Page=1
RA29 is offline
Old 05-01-2003, 03:29 PM   #6
Golfa
Member#: 21394
Sold 2004 STi
08 WW Evo X
welcome to earth...what articles have you been reading...
Golfa is offline
Old 05-01-2003, 03:36 PM   #7
JDM nut
Member#: 34529
04' WRX STi
White/Silver
A little correction. The AWD system in the Skyline GTR is normally operate at 0% front/100% rear, the max amount of power to the front wheel is 50% as needed. It can never operate in 100% FWD.
Also the R34 is not the only GTR that can do this. All 3 modern GTR (32/33/34) operate the same way.
JDM nut is offline
Old 05-01-2003, 03:41 PM   #8
somebody else
Member#: 21618
Default Re: DCCD doesnt allow full 100% rear?
Subaru Of America told me, personally, to my face, 65/35 February. The printed specs have always stated same.
Yeah. What he said.
--scott
somebody else is offline
Old 05-01-2003, 03:44 PM   #9
rallykeith
Member#: 34989
06 2.5i wagon
88 RX
Really? The picture I see shows a 100% lock ratio. That means the Front and rear are Locked 100% together, or are at a 50/50 power split.
rallykeith is offline
Old 05-01-2003, 04:28 PM   #10
RA29
Member#: 30598
2000 Lancer Evo 6
Hot Pink
I think i got confused and assumed Locking=Torque split
So when it is locked 100% to front or rear, how does that relate to the torque split?
RA29 is offline
Old 05-01-2003, 05:14 PM   #11
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I actually thought the same thing until recently, I never really had an interest in the DCCD. I'm not sure about the new DCCD, but here's what it does in the older cars.
When the dccd is open, it acts a 35/65 torque split ***OPEN DIFFERENTIAL***, as in not LSD. So basicly very rear wheel like in that you can break loose the rear end of the car and drift, just like a RWD car. The other end of the spectrum is a 50/50 strong lock, I don't think it's 100% fully locked, just very tight (not sure though). So the old system had about 7 transistions steps between those points, so you could tune it for what you were doing. The open setup is excellent for agressive track use especially if you have good front and rear LSD's, while the locked position is great for dirt, snow, drag launching, etc.
Kevin
Red Rocket is offline
Old 05-01-2003, 05:20 PM   #12
WRXPRESS
Member#: 393
1986 944T & Outback
Yellow & 99 Ducati 900ss
the subaru spokeswoman at the New York auto show told everyone that it could change to a full rear wheel drive for that true sports car feel.
I don't think she appreciated my loud HA! wrong! when she said that.
WRXPRESS is offline
Old 05-01-2003, 05:30 PM   #13
JDM nut
Member#: 34529
04' WRX STi
White/Silver
Those spokeswoman knows way less then car salesman do
We all know how much car salesman actually knows They barely know how much the car is or what color it comes in, let alone how the DCCD works. You'll be lucky if he knows the car is 4WD........
JDM nut is offline
Old 05-01-2003, 05:34 PM   #14
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Yes, while technically she was wrong, at the limit the car will behave like a RWD. There is less weight on the rear wheels, and when they get more torque, they will want to break loose much, much sooner. Once they are loose and spinning, due to the open diff you are very effectively at 100% RWD - enjoy!
Drift away!
Kevin
Old 05-01-2003, 06:02 PM   #15
PeterJ
Member#: 14727
2002 impreza RS
Arrow
I thought that I read somewhere that if you pull sllightly on the hand break to get the sensor to engage, you will be 100% rwd. Because of the way the center diff disconnects, the shaft that goes to the front spins free, but the rear is still engaged. Thats why you can still stall the car during hand break turns even though the center diff "diconnects".
PeterJ is offline
Old 05-01-2003, 06:13 PM   #16
Janq
Member#: 33246
PeteJ,
You misinterpreted what you read.
Pulling the e-brake temporarily disengages the center diff throwing it into "DIFF FREE" open mode while the e-brake switch is tripped. While doing so all standard braking will be circuited to the rear wheels only.
This is documented in the owners manual as applicable to the DCCD;
For complete information on the DCCD as detailed in the owners manual click here.
- Janq
Janq is offline
IL: 6-speed STI complete trans swap with dccd, axles, drive shaft and rear diff wickedwrxwagon Drivetrain 9 12-29-2009 11:37 PM
car wont move unless dccd is on full lock fourage20 Transmission (AT/MT) & Driveline 12 12-26-2008 02:57 PM
2006 Sti DCCD control gives you 95% rear wheel drive??? ScoobyInc Transmission (AT/MT) & Driveline 55 12-08-2005 07:04 PM
is there a dccd on (any) sti -jdm?- that allows for 100% power to the rear... bigworm Transmission (AT/MT) & Driveline 3 10-20-2005 08:47 PM
full wrx rear end 04blue-meanie Private 'For Sale' Classifieds 1 10-08-2005 04:12 AM
