Old 05-18-2001, 04:27 PM   #1
goose
Member#: 3578
Post changing tranny fluid - instructions?
Ok, I'm about to change my tranny fluid- I'm guessing it's pretty straight forward, jack the car up, take out the drain plug, drain, replace plug, put the car back down, and refill- just ot be on the safe side, I'd like to make sure of it though- anyone got any tips on doing this? thanks-
goose is offline   Reply With Quote
Old 05-20-2001, 08:05 AM   #2
Sambo
Member#: 6154
Post
Get a new compression gasket. They _should_ be free from almost any dealership, and it is the same gasket the oil pan uses.
Buy/borrow/make a very long narrow funnel for re-fill.
-Sambo
Sambo is offline   Reply With Quote
Old 05-20-2001, 08:49 AM   #3
goose
Member#: 3578
Post
thanks!
Old 05-20-2001, 08:55 AM   #4
goose
Member#: 3578
Post
do I still need the gasket if my car is new? I've only got like 8,000 miles or so on it (17,000 cliks, my conversion ain't so good) I'm not changing it as part of maintenance, just switching to a synthetic with a friciton modifier to see if it's nicer on the synchronizers
Old 05-21-2001, 09:28 AM   #5
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Post
goose--on my car (2000 RS) the tranny drain plug ring is NOT the same as the engine oil drainplug ring. I did not replace it as it is not a crush ring like the oilpan drainplug ring is, it's basically a thin washer-type seal. replace or not, i don't think it would matter, i have no leaks.
as far as jacking the car, i'd not do that. on the 2000 RS the drainplug is at the very front of the tranny. if the front of the car is jacked up, it's possible not all the fluid would drain since it would be tilted backwards. you CAN squeeze under the car enough to get the plug out without jacking, though it's not comfortable. I suppose another option would be to jack up the car, remove the plug, lower the car to drain completely, jack up again, replace plug, lower car to fill.
donjuan is offline   Reply With Quote
Old 05-22-2001, 06:33 AM   #6
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
is your car a manual or auto? autos need ashop???? to change...
Brat
bratmantlz is offline   Reply With Quote
Old 05-22-2001, 04:01 PM   #7
goose
Member#: 3578
Post
5 speed all the way , I was planning on just jacking the bastard up, lowering it, and letting everything drain out- crap, I hope this 75w90NS stuff works...
Old 05-24-2001, 06:45 PM   #8
Sambo
Member#: 6154
Post
Mine was a compression gasket, but I have an older car than yours.
The advise on NOT jacking up the car is good. If you jack it up you might risk getting a false reading on re-fill.
-Sambo
Changed tranny fluid at 9K, it is noticibly darker than new fluid. Please help! 4EAT Obsessive Transmission (AT/MT) & Driveline 4 07-07-2010 12:04 AM
Changing brake fluid instructions? Subiemax Brakes, Steering & Suspension 2 06-03-2008 10:58 PM
changing tranny fluid and differential fluid for first time Durmiente Transmission (AT/MT) & Driveline 16 05-23-2007 02:06 PM
('93-'01) When am I supposed to change tranny fluid? Die Civic Impreza Forum 2 07-16-2001 04:08 PM
changing Tranny Fluid goose Newbies & FAQs 3 05-16-2001 12:10 AM
