Old 05-01-2003, 06:39 PM   #1
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Default need air conditioner advice please
The air conditioner on my '95 Legacy seems to have failed. Before I take it in, is there any easy way for me to try to figure out what is wrong with it and possibly fix it?
thanks
Mike Wevrick is offline   Reply With Quote
Old 05-01-2003, 08:29 PM   #2
Akiata
Member#: 297
Default Re: need air conditioner advice please
what is it doing?
thanks
Most likely not.
Akiata is offline   Reply With Quote
Old 05-01-2003, 08:35 PM   #3
mch
Member#: 30039
2002 wrx wagon
dirt slvr
no.
mch is offline   Reply With Quote
Old 05-01-2003, 09:37 PM   #4
Thumper23
Member#: 11571
just to reiterate what everyone else has said, no
Thumper23 is online now   Reply With Quote
Old 05-02-2003, 12:18 AM   #5
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Default Re: Re: need air conditioner advice please
Originally posted by Akiata
what is it doing?
basically, nothing; no cold air
oh well, I guess I will take it in
Old 05-02-2003, 12:44 AM   #6
Akiata
Member#: 297
Is the belt on the compressor?
Is the plug on top of the compressor unplugged?
Is the fuse blown?
Does the compressor run but you just don't get cold air?
Old 05-02-2003, 01:51 AM   #7
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Is the fuse blown?
Agreed.. If the compressor is running but no cold air, feel some of the lines and see if they are cold. If none are cold, then you should get one of the pressure guages and see if you have and refigerant (also do this if the compressor clutch isn't engaging) pressure. If there's a leak, and there's little or no pressure, then the compresor will not run (low pressure switch). If the compressor spins, and you get no pressure at the fittings, then there's more than likely a blockage somewhere.
cavymeister is offline   Reply With Quote
Old 05-02-2003, 02:01 AM   #8
Akiata
Member#: 297
I wouldn't recommend messing with the refrigerant. Unless its one of those things I posted above it may be a little over most peoples heads and should be taken in.
Or just take it totally out and save weight.
Old 05-02-2003, 08:47 AM   #9
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Is the fuse blown?
yes, no, no, and yes
Everything seems to be working but I get no cold air and the lines are not cold. I don't want to fool with refrigerant so I guess I will take it in. Thanks for the advice, folks.
OT: Need School/Career advice please. (girl for your troubles inside) Ruh-Roh Off-Topic 19 11-24-2008 12:40 AM
Need Air Conditioner Lines (near firewall, thanks ebay tmic :-| ) anarchyburger Private 'Wanted' Classifieds 6 08-19-2008 09:49 AM
Need your expert advice please (alignment problems) subyboy828 Brakes, Steering & Suspension 14 01-14-2008 01:37 AM
XPel Clear bra air bubbles - advice please johnnyp Bay Area Impreza Club Forum -- BAIC 9 06-30-2002 10:43 PM
