Old 05-01-2003, 06:53 PM   #1
GOT_WRX
Member#: 7241
Default Wheel balance
I've gotten my wheels balanced again through warranty because it was causing vibration through steering wheel at around 70mph.
Now, I get that same vibration at 80mph. One concern is that my dealer says there is no vibration when they test it. I found out that when the tire is cold, it does not vibrate at any speed, but when it gets hot, it starts vibrating. So all they have been doing was driving the car when the tire was cold.
I currently have 36psi on the front, 32 psi on the rear wheels. Possibly bad wheel? They won't rebalance the wheels because they couldn't feel the vibration and I am worried if I ask them to drive more than 30 min in the afternoon (possible abuse?).
Possibly bad tires?
Any input would be appreciated.
GOT_WRX is offline   Reply With Quote
Old 05-01-2003, 07:28 PM   #2
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Go to any shop that has a Hunter 9700 road force balancer. That will be able to find out more about the tire than any standard balancer... www.hunter.com
cavymeister is offline   Reply With Quote
Old 05-02-2003, 07:56 AM   #3
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Move your fronts to the rear and see if you have a vibration in the steering wheel still. If you don't, move one at a time of the original front wheels back to the front to see which one is bad.
WRX03 is offline   Reply With Quote
Old 05-02-2003, 04:17 PM   #4
GOT_WRX
Member#: 7241
So only front wheels cause steering wheel vibration?
If I find and leave the bad tire on the rear axle, is it going to cause any problems ? (bearing?)
I am thinking it has something to do with tire pressure/air expansion difference between the tires.
Revolutions wheel balancing problems wrxxed Brakes, Steering & Suspension 9 12-06-2002 10:01 PM
To Start: Alignment and Wheel Balance package. (hunter gsp 9700 balancer) munkis Tri-State Area Forum 29 05-12-2002 10:46 AM
where can get my wheel balanced?? VSM EXtasy Mid Atlantic Impreza Club -- MAIC 1 12-10-2001 10:31 PM
Special wheel balancing machine Petrie Vancouver Impreza Club Forum -- VIC 4 08-02-2001 10:09 PM
Wheel balancing/inside mount question.... gtguy Brakes, Steering & Suspension 6 01-19-2001 09:34 PM
