Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 05-02-2003, 02:43 PM   #1
Member#: 33517
2005 FXT(i)
Default wheel spacers add to offset?
If so how much?
Say a mm will add ____ offset.
SinhCredible is offline   Reply With Quote
Old 05-02-2003, 03:56 PM   #2
Member#: 2536
2012 STi Hatch
just out of curiosity, are you asking this because you want to add spacers to a wrx?
in general, the wrx already requires a wheel with high offset (depending on size of the wheel)... i've never really heard of people adding spacers on wrxs, but then again, i don't get out much
Takashi is online now   Reply With Quote
Old 05-02-2003, 04:13 PM   #3
Member#: 26779
2007 WRX
I may be incorrect, but I believe adding a 1mm spacer would DECREASE the offset by 1mm.
ButtzWRX is offline   Reply With Quote
Old 05-02-2003, 04:27 PM   #4
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Wheel spacers lower your offset. Wheel offset is expressed in millimeters. So if you have a 50 offset wheel and use a 5mm spacer, you'll be at 45 offset. People use the spacers to generally gain clearance to use wider wheels/tires and not rub on suspension parts.
dwx is offline   Reply With Quote
FS: wheel spacers/5x100 to 5x114 conversion hella_sti Wheels/Tires 3 04-29-2009 03:48 AM
what size wheel spacer for +45 offset gmanwrx Tire & Wheel 17 03-17-2008 09:39 PM
wheel spacer ok to use? unethikl Tire & Wheel 6 07-21-2007 08:14 PM
Wheel Spacer Rings for Offset bobafett Brakes, Steering & Suspension 3 11-03-2002 02:06 AM
offset and wheel spacers rob Brakes, Steering & Suspension 17 10-30-2001 11:08 AM
