Old 05-02-2003, 01:16 AM   #1
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
Default SBC-iD and Radio install... now electrical issues
I installd my SBC-iD. Everything works except my cluster lights and my stock booost gauge dont light up now. I tapped into the Yellow/Green wire to get power.
Also, me and a friend installed a head unit in his rex, followed the directions perfectly, and now his dome lights and clock dont light up. I changed the power source to the ACC, now he has all his lights but nothing saves.
Matt
Oo DaRk StAr oO is offline   Reply With Quote
Old 05-02-2003, 01:49 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
For your SBC-ID, where did you tap power from? I tapped from the radio and never had any issues. For illumination, you should be tapping the orange/white wire IIRC.
For your friend's HU, the reason why nothing saves is that you tapped the ACC wire which only provides +12V when the key is in the ACC or ON position. When you turn the ignition off, the HU loses power and it's memory is lost. You need to tap a constant +12V source. Should be a blue/red wire IIRC. . .you can just use a multimeter and test the wire to find a constant +12V with the ignition off.
Here's a link for a '02 wire harness from the radio: http://www.northursalia.com/m.../radiowrx.html
Calvin
cnk is offline   Reply With Quote
Old 05-02-2003, 01:50 AM   #3
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
For the SBC-iD when I stepped on the gas and boost developed it would reset.
For the headunit. I tried connecting to the yellow and nothing happened.
Old 05-02-2003, 01:52 AM   #4
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
Can you take a pic of your SBC-iD setup with the wires by any chance?
Old 05-02-2003, 01:54 AM   #5
cnk
Member#: 10757
I edited my original post so take a look. The original wires I mentioned were from my HU harness and not the factory wires. Unfortunately, I removed my SBC-ID a few months ago when I got Ecutek. You should be able to follow the chart above to figure out what you need.
Calvin
Old 05-02-2003, 02:01 AM   #6
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
so theoretically all I have to do is ground, and then plug into which color?
And for the headunit I used that chart to no avail.
Old 05-02-2003, 02:10 AM   #7
cnk
Member#: 10757
You can use the ground wire from the HU harness. . .should be black. As for the chart, it was a little difficult for me to follow as well when I did my HU install, but if you stare at it for a bit it should make sense after a while. Some of the wires are flipped IIRC though.
Calvin
Old 05-02-2003, 02:12 AM   #8
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
which color for power I neeed my boost gauge and Cluster to light up?
My SBC-iD is bothering me
I have everyhing except the power right I think
Old 05-02-2003, 02:18 AM   #9
cnk
Member#: 10757
IIRC there are 2 wires you need. . .1 for +12V constant and 1 for illumination. According to Ravenside's web site, you tap the blue/red wire. I'm looking at the wiring schematic from the Subaru wiring guide and it shows +12V constant as a LR, which is light red I would assume. Illumination should be the orange/white wire.
Calvin
Old 05-02-2003, 02:24 AM   #10
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
So put them all together I guess
Old 05-02-2003, 02:35 AM   #11
cnk
Member#: 10757
No. . don't put them all together. If you're not sure, the safest thing to do is to test with a multimeter. The +12V constant will show up as +12V even with the car off. The illumination should not pass any current until you turn on the parking lights.
Calvin
SBC ID and Power Meter ID and Turbo Timer jaywrx Private 'For Sale' Classifieds 13 08-15-2003 05:33 AM
I Installed a SBC-ID and Need Help. tuca33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 10-22-2002 11:43 PM
Blitz SBC-ID and power meter id installed DreamWalker Interior & Exterior Modification 0 10-31-2001 01:39 PM
Blitz SBC-iD and Power Meter installed on WRX. shawrf1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-20-2001 12:40 AM
what do you guys think about the Blitz SBC-id and Power meter-id? illmatic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-26-2001 12:02 AM
