Old 05-02-2003, 12:45 AM   #1
Rubasu
Member#: 1418
MY00 2.5RS
Default need more fuel.......??
Curious as to at what point an N/A RS will need a rising rate fuel pressure regulator? I currently have:
Borla Headers
Random Tech. Cat
2.5 inch Cat Back
Intake
Pulleys
and am sending out both an Intake Manifold and throttle body out to be bored and honed. Will I see any difference If I were to add a Pressure Regulator now or is it not worth it.
Thanks
Rubasu
Rubasu is offline   Reply With Quote
Old 05-02-2003, 02:24 AM   #2
joefocker20
Member#: 13745
2015 STI
Not worth it yet..
joefocker20 is offline   Reply With Quote
Old 05-02-2003, 10:40 AM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You already have a rising rate FPR stock, its 1:1 but its rising rate. A replacement RRFPR is designed to flow more fuel at higher pressures (2:1, 4:1, etc) at greater than atmospheric pressure, a N/A car (w/o some serious ram-air action) will never go more than a psi (two is pushing it). An adjustable FPR which allows you to raise baseline fuel pressure is what you want and even then its just a band-aid for poor fuel system management.
Need More Fuel? scoobywgn0_0 Normally Aspirated Powertrain 0 11-01-2005 02:34 PM
OK, I really need more fuel dopefish Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-21-2003 05:36 PM
i need more fuel captin. drifterx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-17-2003 04:52 PM
Need more fuel RotarFreak Normally Aspirated Powertrain 11 11-19-2001 03:57 PM
I need more fuel pressure Scotty!!! ARG Technical Forum Archive 17 06-11-2000 09:55 AM
