Old 06-06-2001, 07:58 PM   #1
UP00IMPREZARS
Member#: 6866
Post wheel bearings and brakes?
I have a 2000 RS with 54k on it and the wheel bearings seem to be going bad already as i am also going through my second pair of brake pads. Is this something anyone has had problems with that soon?
UP00IMPREZARS is offline   Reply With Quote
Old 06-06-2001, 08:18 PM   #2
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
New or used MY00 RS??
Wheel bearings go when they want to. Usually caused by water/dirt contamination. I caught mine early, but I have 45,000 miles on my car before the bearings started making some noise.
Brake pads depend on how you use them. When you change the pads, check the calipers for excessive dirt or rust and check the piston boots as well. For reference, my car has 45,000 miles and still has 1/4" of pad material on the original pads.
Revision is offline   Reply With Quote
Old 06-06-2001, 08:20 PM   #3
inpreza kid
Member#: 3334
Post
i don't have quite as much milage as you, i have around 9k. replaced both wheel bearings in the back and front is going bad so i'll have to get them replaced pretty soon. oh yea. brake pads. i'm on my 2nd set aready. i have carbon fiber ones but i haven't found the time to install them yet.
inpreza kid is offline   Reply With Quote
Old 06-07-2001, 10:11 PM   #4
hose
Member#: 2897
98 L
Post
If your running aftermarket wheels with the wrong offset your bearings will also suffer. I found this out the hard way and went through 3 rear wheel bearings @ $300+ each.
hose is offline   Reply With Quote
wheel bearing or brakes watchunglava Brakes, Steering & Suspension 2 04-20-2009 10:19 PM
Wheel Bearings and Wheel Fitment lil'rex Interior & Exterior Modification 39 05-18-2008 02:00 PM
bad wheel bearing or brakes? dan avoN7 Brakes, Steering & Suspension 5 10-18-2006 08:36 PM
The Mystery of the Self Healing Wheel Bearing and Other Tales (pics) Necromancer Bay Area Impreza Club Forum -- BAIC 10 07-15-2001 02:02 AM
New wheel bearing and hub: what cost? SFsube Technical Forum Archive 3 07-14-2000 09:28 AM
