Old 05-01-2003, 06:53 PM   #1
02bump'nWRX
Member#: 22182
2002 WRX, 1970 VETTE
Default DO I NEED different lugnuts for rota battles??
Before anyone askes i did a search and i coldn;t find a deffinante answer. So do i need different lugnuts. I want to get my wheels on tomorrow but i will have to wait if i need lugs. Thanks
02bump'nWRX is offline   Reply With Quote
Old 05-01-2003, 09:05 PM   #2
jpmarotta
Member#: 20391
'01 Range Rover HSE
NESIC TrackHoh #555
Thumbs up I'd get them...
... just in case.
The stock lugs are short, and you'll need a thin-wall 19mm socket to get them out.
If you get aftermarket lugs, they will probably come with some sort of "key" which will 1) act as a thin wall socket, 2) act as a theft deterrent and 3) will most likely have larger contact area where the lug meets the wheel.
-Jason
jpmarotta is offline   Reply With Quote
Old 05-01-2003, 09:08 PM   #3
JC'scooby
Member#: 25803
2002 REX
yes yes yes
they have a different pitch angle. If you torque down the stock ones you could crack the wheel
JC'scooby is offline   Reply With Quote
Old 05-02-2003, 09:07 PM   #4
SubSonic
Member#: 35245
2003 WRX Sedan
WR Blue Pearl
can you explain this a little more? I installed my battles with oem lugs and they seem fine.
Should I change them?
Steven
SubSonic is offline   Reply With Quote
Old 05-02-2003, 09:56 PM   #5
rkkwan
Member#: 5596
2010 Honda Fit Sport
Originally posted by JC'scooby
yes yes yes
All acorn-style lugs have the same pitch angle. I doubt the Rotas are different. This above information is likely incorrect.
-Ray
rkkwan is offline   Reply With Quote
Old 05-03-2003, 03:13 PM   #6
BJRs2point5
Member#: 21698
2005 STi
CGM and GOLD
I too am using the stock lugs on my battles. 15,000 miles of HARD driving and all is well.
peace- Brian
BJRs2point5 is offline   Reply With Quote
Do I need EXTENDED LUGNUTS? platnumn Brakes, Steering & Suspension 16 06-09-2009 11:31 AM
Do I need different cables to play GT4 in 1080i? Gerkins31 Off-Topic 9 01-09-2006 08:46 PM
HELP! I need a lugnut for a Rota Tarmac quick! Matt A New England Impreza Club Forum -- NESIC 7 07-13-2004 09:29 AM
Can I use Factory Lugnuts for ROTAs? desiwrx02 Brakes, Steering & Suspension 7 09-12-2002 11:16 PM
I need lugnuts for Rota Battles foolio Brakes, Steering & Suspension 13 07-20-2002 09:49 PM
