Old 05-02-2003, 08:50 PM   #1
SinhCredible
Member#: 33517
2005 FXT(i)
CGM
Default anyone got 17x7.5 rims with +40 offset or close to that?
I know this should be in the tire/rims forum but there isn't much traffic in there. I'm thinking about getting rims that had a +40 offset. Do you guys think i might be asking for trouble?
SinhCredible is offline   Reply With Quote
Old 05-02-2003, 09:20 PM   #2
jaypride
Member#: 33424
2004 STI
Blue/Gold
That is quite as ways off from the stock 53 mm offset. It could be trouble.
jaypride is offline   Reply With Quote
Old 05-03-2003, 12:44 AM   #3
Turbo X
Member#: 26249
02 Impreza WRX
It could be trouble if u wanna lower your ride 2+inchs and it also depends on the spec of tires u getting. U wanna stay as close as 48+ to 53+ on your offset so your fender won't rub and your wheels won't stick out. Hey but I am running a 38+ offset on mine right now with stock height, the drive seems to be fine with no rubbing or such. The thing with the 38+ or 40+ offset tho, the wheels does stick out a little bit. Therefore, if u plan to do a huge drop on your rex, u REALLY want to stick with the least 48+ offset so u don't rub under aggressive driving. Hope that help. Late. (BTW, I don't plan to drop my ride just yet cause of the lip and the bearable tire gap; and sometimes u just don't find the rims u like in the right offset.. )
Turbo X is offline   Reply With Quote
Old 05-03-2003, 08:56 AM   #4
jaypride
Member#: 33424
2004 STI
Blue/Gold
There was another thread about this and someone was saying it could put extra stress on your wheel bearings too.
Old 05-03-2003, 12:37 PM   #5
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Not "could put extra stress on your wheel bearings," but will. The car will also steer and handle differently. It will be dartier, and require more tending to the steering. Plus, a +40 offset will look goofy, IMHO.
Kevin
gtguy is offline   Reply With Quote
Old 05-04-2003, 04:56 PM   #6
Austin
Member#: 7089
2016 STi
I run a +33 offset in the front and a +43 offset in the rear, with 17x7.5" wheels.
Wheel bearings are still fine, after 50 some odd thousand miles...
No problems with rubbing... I run over 3 degrees of negative camber in the front and over 2 degrees in the rear.
Austin is offline   Reply With Quote
235/40 or 225/45 RT-615s on 17x7.5 rims? wistful Tire & Wheel 2 04-16-2006 11:25 PM
S-techs or H-tech with 18 x 7.5 rim / 225/40/18 tires wrxhunter Member's Car Gallery 0 04-02-2005 08:11 PM
anyone got pix of gc8 w/rota formels or those bbs that were optional on the bugeyes? legacy2003 Member's Car Gallery 8 07-26-2004 11:21 PM
17x7.5 rims with 215-45-17 Mr. Mercado Member's Car Gallery 8 02-13-2004 10:22 AM
+40 offset ok with 17X7.5 rims? SinhCredible Tire & Wheel 2 05-02-2003 07:49 AM
