Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 05-03-2003, 11:03 AM   #1
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
Default can't get full boost... uppipe?
so i got a uppipe put in and yesterday i was driving and reliezed i can only hit 0.7bar (10psi). does this mean i have a uppipe leak? i can't really hear and leaking sounds.
anyone have a little bit of time to help me find my problem? i have an autox tomrrow and it would be nice to be able to get full boost. if anyone can help let me know. i will drive to your house.
-Jason
angryfist is offline   Reply With Quote
Old 05-03-2003, 11:27 AM   #2
Mr.Freeze
Member#: 12692
bust a move check it
out i'm rockin' steady
have you touched the stock boost lines? they may be in a wrong order...I screwed this up before and boost was regulated through the wastegate at about 9psi for me. I'm referring to the T connection from the turbo nipple to the wastegate to the ecu. IIRC the hose connecting to the turbo nipple should have a little brass thing-a-ma-jig in it.
Mr.Freeze is offline   Reply With Quote
Old 05-03-2003, 02:34 PM   #3
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
im not really sure of the fitting your talking about. is it the the vacum hose that goes from somewhere under the soleniod valve cover and T's off to the wastegate and to a nipple by the intake port of the turbo. what other hose would that be mistaken for or interchanged with?
the boost seems like its regulated somehow. it doesnt really get to .7 bar but right under so probably about 9 psi.
Old 05-03-2003, 04:55 PM   #4
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
Thanks Mr. Freeze. that was the problem. i didnt think that would make a difference because its a vacum line, but it worked.
Thanks again for the help,
Jason
mmm... boost
Old 05-03-2003, 08:38 PM   #5
Mr.Freeze
Member#: 12692
Cool Jason,
Glad to see you got it worked out...damn tricky vacuum lines!
Nirmit
Old 05-03-2003, 10:01 PM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
Ah, so you fell victim to one of the "classic blunders". Just make sure you don't wage a land war in Asia.
supermarkus is offline   Reply With Quote
After Going from Economy Mode to custom map, I Can't Reach Full Boost! bl0wnb0xerbabiE AccessPort 6 09-17-2009 05:31 PM
Help!! I can't get full throttle after CAI install. 112nick Normally Aspirated Powertrain 8 04-02-2005 01:15 PM
Can't reach full boost BlckRabbt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-04-2003 09:58 PM
Blitz SBC-DC problems Can't get stock boost now. Drivingchallenge Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-17-2002 01:32 AM
Can't reach full boost in 1st gear with new BOV, HELP!!! revelation Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-25-2002 12:33 AM
