Old 05-03-2003, 03:47 PM   #1
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
Default I need help with utec logs. PLEASE HELP!
Problems were solved. Thanks again Jorge!!!
dman918 is offline   Reply With Quote
Old 05-03-2003, 10:06 PM   #2
dman918
Member#: 11202
2009 Infiniti G37X
Please help me out here.
Old 05-04-2003, 02:24 PM   #3
WRXsPWN
Member#: 35989
2011 Sti sedan
if u put in a fmic and your boost went down that is where your issue is. the boost really shoulda gone up if u replaced your stock topmount with an after market freer flowing fmic. that would tell me that you have a leak in the 45 miles of hose you added for your fmic. try removing the hosing and reinstalling the tmic and see if you get your boost back and lose the turbo lag. or try to tighten every connection. if you do try the old tmic and have adjusted your abc already be carefull you dont overboost.
on my initial turbo convertion to my supra i had a simmilar issue with 4 lbs of boost and crazy lag. i had a hose leaking that was totally impossible to tell but when i went though and took it all off for emmisions i found one hose had pvc looking residue past where the clamp was which i assumed was the location of my leak
WRXsPWN is offline   Reply With Quote
Old 05-04-2003, 02:54 PM   #4
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
The boost shouldnt drop to much, if it did then check your hose clamps. You just get more lag with a FMIC, thats all.......
As for flutter, read this. I just posted this in another thread below this one where a guy heard the same noise...:
The flutter is coming from the turbo. Its NORMAL. Believe it or not, its your wastegate.
I know this because I had your almost your same setup (just different exhaust parts) and I got that wierd flutter / chipmunk laugh sound when I shifted and also when I built a little boost and let off the throttle.
I always thought it was wastegate flapping but no one believed me. Well I switched to a PE1820 turbo and the noise has gone away. It must be something about the VF30's that make the wastegate so noisy.......
To make sure that I'm not wrong here, take a drive in your car and listen for the BOV. If you hear the BOV go off and you also hear the flutter than you should be good. If you cant hear the normal BOV sound but you hear the flutter, then maybe its your BOV and the sound is compressor surging.
Good luck!
-Brian
STR8OUT is offline   Reply With Quote
****need Help With Cel Codes-please Help************** stito Subaru Conversions 4 07-29-2007 04:55 AM
Desperate for Help with Cobb AP.. Please help Flyguy3663 Engine Management & Tuning 5 10-08-2005 04:14 PM
Things didn't go well during my first two UTEC logs, please help. 02R6 Engine Management & Tuning 22 09-18-2003 01:02 PM
check out my utec logs, please help! datdudedennis Engine Management & Tuning 31 05-01-2003 07:21 PM
Help With UTEC LOGS. tuca33 Engine Management & Tuning 1 03-04-2003 04:28 PM
