![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 35049
VIC
Vehicle:2011 Mercedes C63 OE Tune 538/500 |
I've asked around even to shops where they put on tires (They said it would be fine) but some of my friends are doubting it so I thought I would ask here too..... I got a buddie of mine that is giving me for free his 4* 235/45-17" tires off his old M5 that he sold a while ago, it has about 60% tread left.... I would like to get the Rota SDR's which are 17" x 7.5"... what do you guys think? Risky?
#2 |
Member#: 5596
TXIC
Vehicle:2010 Honda Fit Sport Black |
The tires will fit on the wheels, but they are a little too big for the Subarus.
The overall diameter will be 1.8% larger than stock. So, your gearing will be taller, and speedometer/odometer will be underreporting by such. They shouldn't rub if your wheels have stock or close to stock offset. -Ray |
#3 | |
Member#: 35049
VIC
Thanks a lot for you input, I'll look further into this matter. The Rota SDR's i want have an ofset of 48. |
#4 |
Member#: 5596
TXIC
Most people don't have any problems running 225 tires with a 45-48 offset on a sedan. Your tires will be another 2-5mm closer to the fender as those. Plus, your tires are larger, about 3-5mm taller than most people, so you just might see some rub in the rear.
Anyways, sometimes the only to find out is to try putting them on your car. Personally, I probably won't do it, but it's your call. And are they even good/expensive tires to start with? |
#5 |
Member#: 17569
Vehicle:2011 Impreza WRX STI DGM |
I have rota battles which are the same size (17x7.5) and i have 235/45/17 bfgoodrich tires on them had them for about 8 months allready no problems, and no rubbing even with 4 ppl in the car.
#6 |
Member#: 1594
Vehicle:1995 WRX 2011 WRX |
I'd suggest you go 235/40-17 instead for the 45 series.
Jon |
#7 |
Member#: 11221
Vehicle:2002 2.5 RS Black as Midnight!!! |
Hey...he's getting FREE tires....off an M5. M5 = BMW = good tires.
I say go for it...if it rubs, you might be able to roll the fenders a little, or live with it. Personally I'd put free tires on and try it...i mean, what, you lose 35-40$ mounting and balancing. |
#8 |
Member#: 1594
They'll also make your gearing even worse.. just so you know. Your speedo will be quite off as well.
Speedo reading will be off by 1.8% so when you're speedo reads 60mph, you're actually doing 61.1 mph. Do as you please, I'd strongly suggest you don't though. |
| Thread Tools | |
| Display Modes | |
| 255/45/18 tires, will they fit? | bae | Newbies & FAQs | 15 | 01-20-2010 09:16 PM |
| 235x40x17 will they fit on 7.5 inch rim? | elohdaeh78 | Tire & Wheel | 11 | 05-26-2008 02:55 PM |
| 235/40ZR18's will they fit on 18 x 7.5" rims? | MarylandEcstasy | Tire & Wheel | 3 | 01-18-2007 06:38 PM |
| 245 tires in STX, will they fit on WRX? | trhoppe | Motorsports | 13 | 10-04-2002 08:12 AM |
| BFG VR-4 tires, will they fit? | jlyttle | Brakes, Steering & Suspension | 10 | 02-03-2001 03:20 PM |
