Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 05-04-2003, 08:31 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Default Question about spring rate measurement units
I know that my JIC front/rear spring rates are 7/6 but what exactly are the units? 7 what and 6 what? And what kind of units are used for spring rates measured in the 200-300 range?
Ed
edkwon is offline   Reply With Quote
Old 05-04-2003, 08:52 PM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
kilograms per mm.
You have to do the conversion lbs/inch.
ss
edit: IIRC it should be -
7 x 2.20462 x 25.4 = 392 lbs/in
and
6 x 2.20462 x 25.4 = 336 lbs/in
subysouth is offline   Reply With Quote
Old 05-04-2003, 09:13 PM   #3
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Ah thanks for the numbers and math
Ed
Old 05-04-2003, 10:38 PM   #4
Claudius
Member#: 36243
1997 'preza GT Turbo
Just to add to the confusion spring rates are also sometimes expressed in N/mm, which is kg * 9.81, so basically in your case it would be 70/60. SOunds like about the limit in stiffness for a car on road tyres. The rears might be a little on the hard side...
How does the car behave with those on? I would imagine rebound to be a little on the fast side?
Claudius is offline   Reply With Quote
Ground control setup about to order (question about spring rate and length) crofrog Mid Atlantic Impreza Club -- MAIC 11 05-18-2009 10:08 PM
Truth about Spring Rates? SilverXing Brakes, Steering & Suspension 7 05-18-2004 10:44 PM
Question about spring rates? JohnyS Vancouver Impreza Club Forum -- VIC 1 05-16-2004 02:54 AM
ATTN: anyone who knows about spring rates TGycageL0002 North West Impreza Club Forum -- NWIC 8 03-14-2002 02:20 PM
Question about spring rates and dampening rates Memnoch Brakes, Steering & Suspension 7 02-02-2001 11:30 AM
