Old 05-11-2003, 07:18 AM   #1
gqzboy
Member#: 22007
2006 WW Evo IX
AE86 Lime Green
Default rear rotor install problem
Hi guys, i have switched out my rotors to stock replacement rotors from stoptech, i use the 8mm bolt plus lossen the e brake gear to remove the rear rotor.. after the install, i tighten the gear all the way where the parking brake is against the rotor, then go down 4 notches from that point to make sure there is clearence from the parking pad to the rotor.. here is the problem
Did i do anything wrong? or there are special things i have to look for when installing the rear rotors back on? because now i'm hearing clicking continously, and i'm kinda scare to drive. it only clicks when the wheel is rolling above 5mph i shall say. And one time my abs light came on as well.
Can anyone tell me what might be happening? i notice my ebrake handle in the cabin is also tighter, i might loosen couple of more notch tomorrow and take a look at it again
gqzboy is offline   Reply With Quote
Old 05-11-2003, 10:58 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
I would think that the clicking is probably the parking brake pad rubbing on the rotor. Usually when you work on the rotor with a parking brake, you tighten it and then loosen it until you can freely spin the rotor without resistance. At least that's the way with a Front Wheel Drive car. I haven't changed the rotors on a AWD car yet so not really sure.
Calvin
cnk is offline   Reply With Quote
Old 05-11-2003, 12:58 PM   #3
Akiata
Member#: 297
I'm not exactly shure what you did.
Did you loosen the little ring with teeth behind the rotor? If so that is part of the ABS.
To remove the rear rotor all you need to do is take the wheel off then pull the rotor off (parking brake must be off). Sometimes they are stuck on there and you will need to use a bolt in the two threaded holes to push it out.
Akiata is offline   Reply With Quote
STi Brembos: Problems with Rear Rotors Rexer06 Brakes, Steering & Suspension 5 03-31-2008 06:04 AM
2003 wrx rotor install problems please help siriusalpha3 Brakes, Steering & Suspension 0 02-08-2006 08:20 PM
Rear rotor/hub problem!?? ThrottleBender Service & Maintenance 7 01-06-2006 10:55 PM
Kartboy rear bushing install problems Legacy777 Transmission (AT/MT) & Driveline 12 05-13-2005 11:15 PM
AEM big brake rotor install problem Subaruist Brakes, Steering & Suspension 17 10-08-2002 10:12 AM
Message Board Statistics All times are GMT -4. The time now is 05:33 AM.
