Old 05-05-2003, 08:54 AM   #1
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
Default DOHC heads on 99+ EJ25?
Has anyone done it?
Would it be a legal UD/BD in ST class?
Reason I'm asking is because I've heard that the DOHC heads flow bettern than the SOHC heads.
trojan9x is offline   Reply With Quote
Old 05-05-2003, 09:47 AM   #2
trojan9x
Member#: 3169
maybe this could be moved to the Normally Aspirated forum
Old 05-06-2003, 09:49 AM   #3
trojan9x
Member#: 3169
nothing at all?
Old 05-06-2003, 09:30 PM   #4
ScoobyShak
Member#: 573
2008 STi
Uh.
Who would have told you this?
J/k. I too would like a deffinate answer. Or should I put it more conformation as for I was told this is true. Also for the up/bd thingy.
Dan
ScoobyShak is offline   Reply With Quote
Old 05-09-2003, 10:53 AM   #5
trojan9x
Member#: 3169
nothing?
Old 05-09-2003, 01:50 PM   #6
98imp
Member#: 32316
98 2.5RS
Blackish...
Teagues Auto
This guy would know if anyone.
98imp is offline   Reply With Quote
Old 05-09-2003, 02:00 PM   #7
trojan9x
Member#: 3169
e-mailed them, hopefully will here back soon
Old 05-12-2003, 10:54 AM   #8
trojan9x
Member#: 3169
response from teagues auto
Originally e-mailed by Dale Teague (Teague's Auto)
It would be better to port and polish the single overhead cam heads. It would give better results in the long run. You can also do cams with the single overhead cam motor. It is a lot less expensive to do the cams on the single than the dual. The results you would get with the dual are not worth the labor it would take to swap them.
Old 05-12-2003, 07:08 PM   #9
DanThom
Member#: 23396
2003 WRX Sedan
My wife's '98 Legacy GT got a new shortblock at 18,000 miles and it ended up being the GenII block. Net effect? Nothing. The car ran like it did before.
I'm sure that a balls-out buildup of the motor might have yielded higher output than the SOHC GenII motor with better longevity than the GenI block, but for an otherwise stock car it made no difference.
DanThom is offline   Reply With Quote
NA EJ25 DOHC heads on a EJ205 block unforgiven2144 Built Motor Discussion 8 08-01-2009 06:47 AM
EJ25 DOHC heads on SOHC EJ22 FuJi K Normally Aspirated Powertrain 5 04-22-2004 09:27 PM
2.5L DOHC heads on EJ22T block 4wheelflyer Subaru Conversions 35 11-27-2003 01:37 PM
DOHC heads on a 2.2L I am pretty positive they fit but... MPREZYA Normally Aspirated Powertrain 2 11-28-2000 06:30 PM
98 DOHC heads on 99/00 bottom End The_extreme Technical Forum Archive 21 06-21-2000 08:30 PM
