Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-28-2000, 04:32 PM   #1
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Question Unorthodox pulley
Have an Unorthodox underdrive pulley for my car. Someone said it took some power off his A/C. Anyone else have any negative comments before I get this thing installed?
subymamma is offline   Reply With Quote
Old 10-28-2000, 04:36 PM   #2
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
Post
The power made by the engine is split into driving the wheels and driving the accessories. The Unorthodox pulley is lighter than the stock one, and so less power is given to the accessories (and, supposedly, more to the wheels). Hence, slight dimming of lights at idle may occur, and if you have an upgraded stereo (amps, subs, etc.) it may be affected as well. The AC should be OK for the most part.. the only complains about the pulley are that at idle, some of the accessories lose some of the power. I'm not sure of the exact effect of it on AC though.
fellfrosch7 is offline   Reply With Quote
Old 10-29-2000, 10:37 AM   #3
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Well, I have the UDP and the upgraded stereo package from the dealer etc. Have noticed zero changed except for the good bit.
Midwayman is offline   Reply With Quote
Old 10-29-2000, 11:12 AM   #4
Faraz
What?...
Do they speak English in What?
Member#: 1459
2008 WRX 5door MT
WR Blue
Post
if you're going to run a after-market stereo setup don't get one ... even without a stereo the performance gains are very minimal ...Shiv, Ralispec, and i think TRi Tuning (not sure) ....all don't reccommend it either.
Faraz is offline   Reply With Quote
Old 10-29-2000, 11:22 AM   #5
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Lightbulb
So, this is what it sound like in a nutshell to me: Don't expect phenomenal results, and as long as you run alot of auxiliary electrical stuff, you shouldn't have any bad stuff that you can't tolerate????
Old 10-29-2000, 11:24 AM   #6
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Exclamation
Bad proofreading! Let me correct myself!!
As long as you DON'T run alot auxiliary electrical stuff, you shouldn't get alot of bad stuff!
Old 10-29-2000, 01:30 PM   #7
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
Post
if u get unthorodox's UDP, as long as u dont have a stereo system that doesnt go over 400 watts RMS ur ok in that respect, with it ur engine will rev better and ull get about a 5hp gain in power.
SubyRacer is offline   Reply With Quote
Old 10-29-2000, 03:37 PM   #8
Gambit
Member#: 102
Post
U're basically freeing loss hp due to a/c and alternator. I think it helps alot in quick acceleration and when you blip the throttle for heel and toe shifting. Some ppl stays away from it some loves it and claim that they have no problem. My UDP is going to be 1 year old now this coming december. So far so good.
Gambit is offline   Reply With Quote
Old 10-30-2000, 12:11 AM   #9
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Sort of... the gains arent alot. Basically there are better power for $$$ mods. Some people are concerned because the udp doesnt have a hamonic dampener. This *may* cause long term reliability problems. Though the other camp says that the 4flat layout is inherantly balanced and doesnt need it. Your call.
Old 10-30-2000, 09:59 AM   #10
Dr. Spud Funk
Member#: 2790
2007 BMW F800S
Sonnengelb
Talking
Yo, Subymamma! Why don't you just put that "Subaru Blue" Unorthodox Racing Pulley on you Suby, and see if it works out? If it doesn't, you can always take it off, and I'll buy it from you!
Dr. Spud Funk is offline   Reply With Quote
Old 10-31-2000, 12:29 AM   #11
DaveK
Member#: 2338
1988 323 GTX
black
Post
I just put the UDP on my car a few weeks ago. I have a Sony 50watt cd player and a 200 watt clarion amp. I've had no problems with dimming headlights, but I haven't used the A/C since I installed it.
DaveK is offline   Reply With Quote
Old 10-31-2000, 07:53 PM   #12
subymamma
Member#: 2575
2008 Forester 2.5X
Dark Gray Metallic
Post
Hey, DaveK, try that air and let me know how it works! In Florida a car needs three things that are essential:
1. motor
2. tires
3. A/C
4. A/C
I gotta know if my A/C will be compromised!
DR. FUNK: How do You know what color my Subie pulley is? Huh????
Old 10-31-2000, 07:56 PM   #13
Gambit
Member#: 102
Post
Your A/C wil be compromised for sure. But how much depends on you. For alot of us with the pulley it is not enuf to warrant the coupla hp it frees up. YMMV
Old 10-31-2000, 08:45 PM   #14
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Yeah, if you're sitting in rush hour traffic with the revs at idle speed, you won't be getting any air conditioning with the pulley. Putting the fan on 4 & having the system in recirculation mode helps a bit, but it definitely doesn't help much on a hot summer day!
RidinLow is offline   Reply With Quote
Old 11-01-2000, 08:32 AM   #15
gumball
Member#: 1209
Exclamation
I can defintely 2nd the A/C comment- I've sat in traffic w/ the U/D pulley on a sweltering DC day and boy, even w/ recirc on and the fan blasting the air is not that cool unless I gun the engine.
gumball is offline   Reply With Quote
Old 11-01-2000, 09:36 AM   #16
Liquid Calm
Member#: 2744
2005 STi
WRB/Gold
Post
I will chime in to I have the UDP to and yes @ idle you have pretty much no ac I you hold the RPM'S @ about 1000 you will have ac but for a long sit in trafic your foot will get tierd
Liquid Calm is offline   Reply With Quote
Old 11-01-2000, 10:36 AM   #17
Dr. Spud Funk
Member#: 2790
2007 BMW F800S
Sonnengelb
Wink
That's right, Subymamma! I know where you live, I know what you drive, I know what you did last summer, and, I know what color your pulley is! Mwahahahaha!
[This message has been edited by Dr. Spud Funk (edited November 01, 2000).]
Old 11-01-2000, 10:41 AM   #18
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
just to correct someone, the reason that the auxilary stuff doesn't work as well is NOT because the pulley is lighter. It is becase it is smaller in diameter, which means that everything that spins off of it, will spin slower, but it'll be easier for the engine to turn it, hence the hp gains.
JGard is offline   Reply With Quote
Old 11-01-2000, 11:38 AM   #19
Gambit
Member#: 102
Post
Well let's shed some +ve things about the pulley. Other than less than stellar performance from the a/c, your car will response much faster. It's alot of fun to just blip the throtle and the car just goes.
Old 11-01-2000, 07:45 PM   #20
Trebors
Member#: 2503
Smile
Yeah...the lights dim a little at idle...but the big smile comes from the quicker revving and response....others have noted it..really like it.
Trebors is offline   Reply With Quote
Old 11-02-2000, 06:09 AM   #21
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Post
Anybody know of this: How about a smaller diameter pulley for the alternator? That way with the UDP the alternator wouldn't suffer as much. Plus it would be lightened. It'd prob make you all happy as to keep the A/C fully powered as well as the car stereo enthusiasts.
Anyone know who makes one? I think UR would custom make one....how about a GB??
-chrisC
silverSurfer is offline   Reply With Quote
Old 11-02-2000, 09:27 AM   #22
BoomerRS
Member#: 1271
98 RS
****in Rally Blue
Arrow
silver surfer
thats a good idea... and is similar to what AEM did for hondas but for different reasons. the stock drive pulley is damped... this is to keep harmonic vibrations from the shaft from destroying your engine (catastrophic failure!). the underdrive pulleys are not. the speculation has been that since we have a boxer engine, that this matters less to us. is this true? i am not sure. has their been testing to prove this? not that i have seen. so for hondas AEM instead offers replacement pulleys for the others and keeps the drive pulley stock. a good idea, but i bet the gains are less than replacing the drive pulley with one that is lighter and smaller (im just guessing, could be wrong). i wont put an undamped drive pulley on my car... i would worry too much, i have seen what harmonic vibrations can do (ever heard of the tacoma narrows bridge?) this is just me, im a bit conservative. hundreds if not thousands of people have the unorthodox pulley on their RS, and i have not heard of one failure... only time will tell, failures would not be immediate, but thousands of miles down the road.
BoomerRS is offline   Reply With Quote
$180 Good for Unorthodox Pulley?? BrysImpreza Normally Aspirated Powertrain 2 04-10-2001 11:44 AM
unorthodox pulley IMPREZA GUY Normally Aspirated Powertrain 4 03-30-2001 09:52 AM
Will an Unorthodox Pulley fit on a 2.2L? Lone Wolf 75 Normally Aspirated Powertrain 13 11-14-2000 12:16 AM
Unorthodox Pulley Install - how do you break that F*&#ing bolt???? Tim Harris Technical Forum Archive 19 06-02-2000 09:55 PM
Loss of A/C at idle with Unorthodox Pulley? Impresario Technical Forum Archive 4 05-16-2000 07:18 AM
