Mid Atlantic Impreza Club
Old 05-09-2003, 03:26 PM   #1
GOT_WRX
Member#: 7241
Angry Err..Dumb Mechanics at Farrish
I've been waiting for the clutch assembly to arrive so I can get my car fixed under warranty (cold shudder) and yesterday, I received a card with a bunch of part names/numbers on it saying they had received them.
I looked at the part numbers and they looked familiar.. I also had a copy of TSB for the clutch problem and guess what...
they ordered 2.5RS clutch assembly for my WRX.
ARGH!! The service guy doesn't know anything about the WRX, and he says "I believe the mechanics ordered the right part".
Does anyone know if it's possible to install RS clutch flywheel/cover/disc into WRX? I hope I don't get stuck with a bunch of wrong parts in my rex.
GOT_WRX is offline   Reply With Quote
Old 05-09-2003, 03:51 PM   #2
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
well worse comes to worse...you can give me your extra 2.5RS clutch! sorry bout all that bro, if its under warranty though, wont they have to get the right parts and put them in? You shouldnt get stuck with these parts...
SpamMansXe is offline   Reply With Quote
Old 05-09-2003, 04:28 PM   #3
plunk10
Member#: 32342
2004 :derp:
Good thing you caught that error. Keep that in mind if your clutch breaks after a few hundred miles.
Subaru would then probably try to void your warranty blaming, say, a custom stereo, or an exterior sticker caused the clutch failure.
plunk10 is offline   Reply With Quote
Old 05-09-2003, 04:42 PM   #4
SpamMansXe
Member#: 15920
1999 White Mock 22B
Old 05-09-2003, 04:55 PM   #5
GOT_WRX
Member#: 7241
I will research the part numbers in details to show them they aren't the right parts. I will be the living hell to them
Other than that, yeah, SOA can void warranty due to the extra stickers on the body:
SOA: Um sir, one of your stickers was a bit peeled off which caused extra drag, which then cause more heat, and engine load. We will have to void your warranty sir.
Old 05-09-2003, 05:08 PM   #6
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
You cannot swap the clutch components between the RS and WRX. They work the opposite of each other. The RS release bearing pushes on the pressure plate, while the WRX release bearing pulls on the pressure plate.
jake
KONKILR is offline   Reply With Quote
Old 05-09-2003, 05:15 PM   #7
GOT_WRX
Member#: 7241
Originally posted by KONKILR
You cannot swap the clutch components between the RS and WRX. They work the opposite of each other. The WRX release bearing pushes on the pressure plate, while the WRX release bearing pulls on the pressure plate.
jake
Thanks for the info. If that's the case, when they try to install the parts, they will probably scratch their head and wonder why the parts wouldn't fit.
It's been a week and half since my parts were ordered. I guess they found out the mistake and ordered them again.
Old 05-10-2003, 02:31 PM   #8
Bottom Feeder
Member#: 2808
Why are they getting in touch with you when warranty parts for your car have been ordered and received? What does that have to do with you? You shouldn't have to be in that information loop.
Bottom Feeder is offline   Reply With Quote
Old 05-10-2003, 10:57 PM   #9
GOT_WRX
Member#: 7241
They gave me a receipt when I got my car back the same day (cuz it takes time for them to order/get the parts), so I got my car back the same day. On that receipt, they have parts ordered with the part numbers.
Again, at the time of the post, I got a postcard with part numbers from the dealer, saying the parts were in so I can schedule a time to drop my car.
I just looked up those numbers to make sure they were getting the right thing, but apparently, they ordered/got wrong parts.
I just didn't want any wrong parts installed in my car that could cause further problems. or maybe was too paranoid because Farrish recently started selling subaru's and they aren't that experienced. I regret this the most. Should've gone to somewhere else when I got my car.
All in all, it will be fixed , which is good.
Old 05-11-2003, 01:08 PM   #10
2pt5RS
Member#: 10853
2013 BRZ LTD
jake
which one is for the RS, and which one is for the WRX??? you say both are what the WRX clutch does
Matt
2pt5RS is offline   Reply With Quote
Old 05-11-2003, 01:16 PM   #11
rhdude
Member#: 6637
2009 Acura MDX Sport
WRX= pull style clutch
RS= push style clutch...
rhdude is offline   Reply With Quote
Old 05-11-2003, 08:56 PM   #12
Lt. Dan
Member#: 3597
1985 RX-7
gunmetal
Eh, I wouldn't exactly blame the mechanics for that screw up as much as the parts guys... When I was a tech, I never actually looked up the parts I needed. I just walked back and said "I need this part for this model vehicle"... MOST of the time, they got it right, but people do make mistakes...
Dan
Lt. Dan is offline   Reply With Quote
Look what came off the truck today at Farrish Subaru.... GodWhomIsMike General Community 63 09-28-2008 11:29 PM
Shop Day....err.....Driveway Day at mi casa texas05sti Texas Impreza Club Forum -- TXIC 7 04-02-2007 12:53 PM
Bad experience at Farrish Subaru. Northern, VA Valhakar Mid Atlantic Impreza Club -- MAIC 21 06-14-2004 05:41 PM
WRB WRX getting tranny work done at Farrish in Fairfax? KanosWRX Mid Atlantic Impreza Club -- MAIC 5 10-02-2003 11:37 AM
